Right Wrist Pad Area Overheating
ozmann
#61 Post by ozmann » Wed Sep 20, 2006 9:37 pm
asiafish wrote:Compare the T4x to the X6x/X4x and you will see that while much thinner than the Dell, it is still much thicker than the X-series. The fact remains that the palmrest is an area where a hot item can be placed without causing damage to other delicate components . If you want better cooling in that particular space, then you need a thicker palmrest, and with a thicker palmrest people will complain about their ThinkPad getting bulkier.
Umm, I think the wireless card (the main source of the heat) is under the palm rest because of user access, rather than protecting other components. IMHO, the problem is lack of adequate cooling on the right side, including lack of appropriate venting. Seems like a design problem. If it were necessary, I gladly would trade a bit extra thickness for less heat.
T40p. T42 and X40
X60s 1704-69U, 2GB Ram, 100GB HD
asiafish
thinkpads.com customer
#62 Post by asiafish » Wed Sep 20, 2006 9:46 pm
Not me. The heat is not excessive or painful, just, well, a bit hot. I'll take a bit hot in exchange for thin and light.
Of course, thats why I own an X41 instead of a T series, Dell or whatever.
Richard Dawkins, 2002
ozmann
#63 Post by ozmann » Wed Sep 20, 2006 10:07 pm
asiafish wrote:Not me. The heat is not excessive or painful, just, well, a bit hot. I'll take a bit hot in exchange for thin and light.
Alas, the palm rest on my X60s is much hotter than on my X40. Have you tried a X60s with the Atheros card?
T40p. T42 and X40
asiafish
#64 Post by asiafish » Wed Sep 20, 2006 11:51 pm
Finally got to play with one in fact. Its hot, but for a machine of that size, I'll still take the heat. Sadly, the owner wasn't willing to trade straight up his X60s for my X41.
smvp6459
#65 Post by smvp6459 » Sun Sep 24, 2006 9:02 pm
Not sure if anyone else has noticed a difference but...
I have the Intel card in the X60s and I noticed when I switched my APs in Access Connections from default (which is ABG) to G or B & G the right palm rest became noticeably cooler. It isn't room temperature but it's a couple of degrees cooler than the CPU (40-43) whereas it used to always be a few degrees warmer than the CPU (45-49).
I'd be curious to see if it affects anyone else.
SkiBunny
#66 Post by SkiBunny » Sun Sep 24, 2006 9:49 pm
smvp6459 wrote:I switched my APs in Access Connections from default (which is ABG) to G or B & G
I cant find it (but i have atheros) so please, how exactly did you do that?
smvp6459
#67 Post by smvp6459 » Sun Sep 24, 2006 10:54 pm
SkiBunny wrote:I cant find it (but i have atheros) so please, how exactly did you do that?
I don't know if you can control it with the Atheros card, but with Intel wireless here's how I did it:
-Press Fn-F5
-Go to the bottom left corner and click "Open Access Connections"
-Go to the "Locations" menu and select the "Manage Profiles" option
This should bring up your various wireless location
-Right click the AP you want to use
-Select the "edit" option
-Select the "Wireless Settings" tab
Next to the option "3. Wireless Mode" there's a drop down box
-Select "802.11G" or "802.11B" depending on your connection.
Again, I'm not sure if this will help the Atheros card but it seems to have cooled down my Intel card.
You can also get directly to the wireless setting of the AP you're currently using by clicking on the picture of the wireless router at the Access Connections creen.
WirelessAndy
#68 Post by WirelessAndy » Tue Sep 26, 2006 9:57 am
smvp6459,
Are you able to measure the palm rest surface temperatures (not internal) with an non-contact thermometer while using this A/B/G tweak?
smvp6459
#69 Post by smvp6459 » Tue Sep 26, 2006 11:03 am
I have no tool to measure the external temperature, but my palm tells me it feels cooler.
keruibo
Atheros setting a/b/g mode and temp
#70 Post by keruibo » Tue Sep 26, 2006 8:52 pm
I have the atheros card (now), and I tested using Access Connections to change the wireless mode to see if it has an effect on temperature.
For me, it doesn't. Whether running on "Auto" or "g" mode, the APS temp is 52C.
FWIW
X60S, 3GB RAM, Vista x32
X61T, 4GB RAM, Vista x64
X61, 4GB RAM, Vista x64/Windows Server 2008 x64
X30, 1GB RAM, Windows XP
