Bluetooth mouse for the T60?
bri
#31 Post by bri » Wed Aug 02, 2006 7:58 pm
Yea it's weird that they have two versions without a clear distinction. The media pad is not required, the three pieces are linked as individual devices and so you can mix and match. I'm using the keyboard at work with my work computer and the mouse at home with my Thinkpad. This is just for convenience sake where they get the best use and I don't want to carry them back and forth. I only use the number pad for heavy data entry which I never have to do, so the Media Pad is in a drawer somewhere. The keyboard is AWESOME, it's just like a very high quality laptop keyboard. The T60 keyboard is just so-so, no comparison to the great keyboards on the X20 and T40 I had, and the DiNovo keyboard is very nearly as good as those 'gold standard' Thinkpads.
now: X61, T42p
before: 600E, T23, X20, T40, X40, X31, T60
FS: Travel Bezel, 100GB drive (OEM Lenovo)
xaveon
#32 Post by xaveon » Thu Aug 03, 2006 3:31 am
Well I did a lot of research when I got my T60p. To help you guys out:
There are two versions of the DiNovo, one is regular "Fast RF" and one is Bluetooth, I have the Bluetooth version, is it was absolutely perfect! When looking at the DiNovo keyboard one might think that it's too thin to provide enough response while typing. I've found that it provides great feedback and just the right amount of "springiness".
As for a portable mouse. I got this off of eBay. The quality isn't as great as Logitech's (the mouse clicks doesn't feel as nice), but it's bluetooth and it has a USB cord that you can plug into USB to use and recharge. So just use the mouse over bluetooth until it dies and then plug it to a USB slot and use it while it's charging. I wish Logitech would come up with a solution like this. Hope this post helps.
Features:
* Meets Bluetooth V 1.1 compliant and HID Profile V 0.95C
* RF band: 2.402 - 2.480Ghz
* Operation range: 10m (Bluetooth class 2)
* Interface: USB 1.1
* 800 dpi Optical technology provides superior precision and smooth navigation
* Windows 2000/XP & Mac OS V10.3
* Internal antenna
* Low power consumption, Support USB Rechargeable Function to recharge the battery and operate at the same time
* Sleep mode when not in use to save power
* Power On/Off button on the top to remind the user to switch off the power
* Unique Rubber Double Injection Cover
* Rechargeable via USB cable
* Battery life: 50 hours by continuing operation
* Recharge time: 3 hours
* Antenna: internal
* Data rate: Up to 723 kbps
* Bluetooth Class II
* Spread Spectrum: Frequency Hopping Spread Spectrum
* Radio Frequency: 2402~2480 MHz unlicensed ISM band
* Paring LED
* Support Bluetooth HID profile
* Battery: 2x AA Alkaline Battery
* System: Win XP / 2000 / ME / Win98 SE
* Dimension: 109x6750x36 mm
* Weight: 125g
* FCC CE certified
Anthony S
New Targus BT mouse
#33 Post by Anthony S » Thu Aug 03, 2006 7:17 am
Targus has just announced a new Bluetooth mouse that can be recharged via a USB cable.
http://www.targus.com/us/product_detail ... ku=AMB03US
Current: T60p (2007-93G). Previous: T23 (2647-9LG).
Users browsing this forum: BigT0ny and 4 guests
