Enable ATI Powerplay Control in NHC
Activate Powerplay
Show ATI clock in the Taskbat Icon ToolTip
... completely regardless of how I configure the settings in Windows XP Start --> Control Panel --> Display --> Settings --> Advanced --> Powerplay (tab) and "Activate Powerplay" or not. The above all applies to when I run directly off mains; I haven't tried how NHC behaves if I run off battery.
In the same NHC Graphic Card Control section, I am allowed to enable (and alter) both ATI Clock Control #1 and #2 (although I have not yet understod when #1 resp. #2 are used?).
I am using a T42p, 2373-Q1U w/128 MB ATI Mobility FireGL T2. I have installed the T43p ACPI file referenced to above (and modified it for my T42p), and fan-control in NHC functions fine. I use NHC as being auto-started in Windows (hence I am not running NHC as a service). In the the NHC manual (Graphic Card Control section) I find no explanation why the above boxes are all disabled? What I simply want is this look!
According to "Properties for ATI Mobility Fire GL T2" the driver version used here is 6.14.10.6547, dated 16-11-2006. I don't have the Mobility Modder.
What I want to do is let NHC control Powerplay, in particular when I run off mains... simply to reduce GPU heat dissipation as much as possible. I mainly use the T42p to browse the internet, e-mail and type... so very little GPU power is necessary. All help would be greatly appreciated!
Thanks in advance, and best regards,
Johan
PS: I am not sure if this problem might be related to the T43p ACPI-file; this link seems to indicate so? Also, This, this and this link may also shed some light on the problem - for those who can read German...! (which I cannot - sufficiently).
UPDATE: I just discovered this thread pointing to this thread which finally points to this thread where in particular the post by troubadix of Fri Oct 28, 2005 may perhaps shed some light on this issue...? How/if all this relate to NHC ver. 2.06 is however a little unclear (to me!).
[/img]
