NHC 2 is out!
I did activate that in the Catalyst once. But it did not work!skanky wrote:they're greyed out unless you check "Activate Powerplay"..
also im using the modded 5.6 catalyst drivers, not sure if the standard IBM ones would work or not?
Where do i get the modded ones? What advantages do they offer?
T42, T60p
Spawn123456
Update for the t4x file
Hi there,
i finally updated here the cs file. See the readme for details.
@Milos
Thanks a lot for your ideas.
Carl
@Milos
Carl
Re: Update for the t4x file
Hi! Thank you for this great work. Your script works fine until I reboot my machine. Then I get message "ERROR - ACPI Control System problem detected". When I turn on debugging of ACPI in NHC, I get "IBM.t43p.FAN.refresh()... ERROR".Spawn123456 wrote:Hi there,
@Milos
Carl
I have to manually change Notebook Fan Control mode from 2 (NHC) to 3 (ACPI) and back. Then it works OK again.
Any ideas, what to change, so I do not have to make those manual steps every boot?
Thanks for reply
billyrom
Spawn123456
billyrom wrote:Hi! Thank you for this great work. Your script works fine until I reboot my machine. Then I get message "ERROR - ACPI Control System problem detected". When I turn on debugging of ACPI in NHC, I get "IBM.t43p.FAN.refresh()... ERROR".Spawn123456 wrote:Hi there,
@Milos
Carl
Thanks for reply
billyrom
Hi Billyrom,
I only got this error twice after the hibernating mode. I don't know why this happens, and it doesn't happen all the time. I can only guess, that the EC is blocked by the bios. If this happens everytime after reboot, try the ibm_long_refresh.cs file. (You can find it at the same place) I've increased the time, how often the fan level is checked from 1 to 5 seconds. But that's a little dangerous, because it slowes down NHCs reactions to higher temperatures.
One last question: do you use the free version, or the service version of NHC? Because since I have the service version it didn't happen again.
Spawn
P.S: I'm locking for a sleep function in C-sharp. As I can see for now, this is possible, but somehow blocked by NHC.
Wow. Didn't expect such quick reaction.Spawn123456 wrote:billyrom wrote: Hi! Thank you for this great work. Your script works fine until I reboot my machine. Then I get message "ERROR - ACPI Control System problem detected". When I turn on debugging of ACPI in NHC, I get "IBM.t43p.FAN.refresh()... ERROR".
Thanks for reply
billyrom
Hi Billyrom,
Spawn
It happens every start of NHC after boot of OS (restart or power on). After standby or hibernate I do not have such problem. I use free version of NHC, so there may be the difference.
I think, 5 seconds is short enough time, so I will try "long_refresh" and post my results.
UPDATE: long_refresh do not work
Thanks again
billyrom
Spawn123456
Hi billyrom,
Wow. Didn't expect such quick reaction.![]()
UPDATE: long_refresh do not work- the same error after start.
Thanks again
billyrom
I've written an cs. file which does not update the fan during the first 15 seconds. (You find it at the same place it's the ibm_fan_delay.cs file). If there is still this error please increase the fan_delay by your own. To do this open the ibm_fan_delay.cs in notepad and scroll down a little bit until you find the line
const int fan_delay =15;
here you can increase the delay by replacing the 15 to the number of seconds you want (I suggest to test it with a very big value)
Please post if it fails or works.
Carl
Hi Carl,Spawn123456 wrote:
Hi billyrom,
Carl
only effect of initial delay is that the error message will appear adequately later after start of NHC. As you suggested, I tried some bigger values of fan_delay constant (120 and 240), but this was the same.
In my opinion this is not question of delays, but the way, how NHC takes control over acpi. As I wrote formerly, no matter what values the delays are set, I have to change Notebook FAN Control mode to ACPI and back to NHC and then it starts to work. Of course, the same I can achieve, if I do not forget to set mode to ACPI before the restart of notebook, then after reboot change back to NHC.
I have found some earlier version of scripts (files have date 13.10.2006 - maybe @Milos') where there was two .cs files in archive - one for bluetooth and one for non_bluetooth models - and there is also readme file, which reads "ACPI (set_fan_speed) doesn't work after reboot". I assume, actual scripts are based on those two.
Billyrom
Spawn123456
billyrom wrote: Hi Carl,
Billyrom
Hi Billyrom,
ok the delay didn't work. I just uploaded a ibm_save_init.cs file. It does exactly what you did on initialisation.
And yes this script is based on the old one. I thought the error was fixed, cause it didn't happen on my machine during the last month.
Hi Carl,Spawn123456 wrote: Hi Billyrom,
it works! Hats off to you!
You have my big thanks.
billyrom
Spawn123456
What is the correct link? rcswww.urz.tu-dresden.de/~s3924347/ does not work.Spawn123456 wrote: i finally updated here the cs file.
Thanks, Dominique
X301 (2776-3JG) | Core2 Duo U9400 1.4 GHz | 8GB | 128GB SSD | Win 7 Pro
v. 0.82 is the version for what? the file that should be found on the link that doesn't work?Spawn123456 wrote:I've updated the ibm.cs file. The bug billyrom found could also occur at another point! So update to V0.82.
Thanks, Dominique
Spawn123456
Sorry,
the web space of my university is down, so you have to wait until it's up again or you can download it here. Take the third file from the T43p 2668-G2G.
Carl[/url]
Carl[/url]
Spawn123456
Spawn123456
Aristotle11
I have an X31, and fancontrol works, but I'd like to get the fan utility on NHC working. Powerplay is greyed out, and I don't know why. More importantly, I used the T43p ACPI and I get this error...
Error building 'C:\Program Files\Notebook Hardware Control\acpi\IBM.cs' into 'C:\Program Files\Notebook Hardware Control\acpi\IBM.dll'
ErrorNumber: CS0117
ErrorText: 'ACPI.FIELD' does not contain a definition for 'ReadByOffset'
Line: 230
Column: 32
IsWarning: False
ErrorNumber: CS0117
Line: 1158
Column: 45
IsWarning: False
ErrorNumber: CS1501
ErrorText: No overload for method 'Call' takes '5' arguments
Line: 1628
Column: 14
IsWarning: False
I edited the 2 fileS and added "X31" and my model number where it had T42 and another model number, but no go. Any ideas?
Thanks,
Aris
ErrorNumber: CS0117
Line: 230
Column: 32
IsWarning: False
ErrorNumber: CS0117
Line: 1158
Column: 45
IsWarning: False
ErrorNumber: CS1501
Line: 1628
Column: 14
IsWarning: False
Thanks,
Aris
Paul Unger
Has anyone ever knowingly blown a system board using NHC2? I'm running it on my T42 2373-3UU (1.7 Dothan, 1GB, SXGA+ Radeon 9600) -- undervolting (6 @ .700V - 17 @ 1.100V), dynamic switching, fan control, the works. It has been stable, cool, and quiet for about two years (I began with CHC way back when).
I recently bought a used T42 2373-4TU (1.7 Dothan, 512MB, XGA Radeon 7500). Having had such a good experience with NHC on my first T42 I figured I'd put it on the second one as well. Since it was pretty much the same machine (at least the CPU is exactly the same and I didn't figure RAM and graphics cards would affect things too much) I used the same numbers for undervolting, fan, etc. I should note that one major(?) difference is that the 4TU, with the low-res graphics card, has the short fan while the 3UU has the long fan.
Anyway, it ran great the first day. I shut the lid to 'hibernate' when I went to bed and everything seemed fine. I went to start it in the morning and . . . nothing. Deader than a doorknob. I tried swapping RAM sticks and HD from my second machine (which I knew were good) and nothing would bring it to life.
So, question: do you think the system board was going to die regardless, or is there *any* way NHC could have killed it?!
PS I should note that the board was replaced under warranty with *excellent* service: out on 12 February, back on 16 February! The only hiccup was that it came back with an Intel 2100 3B wireless card rather than the 2200 b/g that was in it when I sent it in. They're sending me a replacement as I write.
thibouille27
Spawn123456
i ve bought pro 06 version, but when i try to set my ACPI,
i enable ACPI sys control, but it gives me: SCPI control system is not yet configurated for this system, i dont know what i have to do with it.. i have Z61m..
i tried also downloading the core2duo patch, nothing happend only it says "pre-release-04"
please help me
This is great work, thanks for your efforts in writing the ACPI profile for NHC!
However, I have now spent a lot of time trying to get it to work and I'm still greeted by the annoying "ACPI Control System is not yet configurated for this system" message on the ACPI tab. WHAT AM I DOING WRONG? RRRHHHAAA
1) Downloaded Carl's ZIP and extracted .xml and .cs files to NHC's /acpi/ folder
2) Started NHC and went to "Show computer hardware details"
3) Made a note of the "Name" under "PRODUCT" (2672CEG)
4) Opened ibm.xml in Notepad and replaced the model name with the above.
5) Restarted NHC and checked ACPI tab. No change.
I have tried variations of the above _many_ times, including chaning where NHC looks for the model name from SYSTEM to PROCUCT to MAINBOARD but I not getting anywhere. Please HELP!
Lomax
Lomax
600E - 600X - 770X - X31 - X32 - T43p (SATA) - T60p - X200t - X200s (PVA) - Z Pro 9228
- 4 Replies
- 1429 Views
Thu Feb 09, 2017 6:38 pm
Fan trouble - 3000 N200 + Type 0769 - ESG ACPI Script for NHC > NOTEBOOK HARDWARE CONTROL
by MatMor » Sun Mar 12, 2017 12:12 pm » in 3000 Series Laptops - 0 Replies
- 2587 Views
Last post by MatMor
How can I find out if I can run Win10 or Win 7 on this T60?
by Muse » Sat Jan 07, 2017 10:29 am » in ThinkPad T6x Series - 15 Replies
- 2227 Views
Last post by sebileis2017
Thu Mar 09, 2017 11:24 am
- 667 Views
Last post by Muse
Mon Apr 24, 2017 7:22 pm
