IBM UltraBay battery issue v. holds less charge
Well, my call took 12 minutes but my new battery should be here in two to three days.
My Ultrabay Battery:
Remaining: 100%
Full Charge Capacity: 22.43 Wh
Cycle Count: 30
Manufactured: 2006-07-05
Designed Capacity: 29.16 Wh
And is it weird that Power Manager reports the UltraBay battery chemistry to be Li-Polymer, while Li-Ion is printed on the battery, and the main battery is reported as Li-Ion?
Remaining: 100%
Cycle Count: 30
Primarily adding info here...
I received my ultrabay battery two days ago, after only two charge cycles I'm looking at 79% of max capacity. I called IBM today: they were very pleasant, but the guy I got didn't seem entirely brilliant. In any case, he said that the replacement parts for this were backordered, it's unclear to me if this is because Lenovo has recalled them and doesn't have a replacement yet, or if everyone is RMA-ing these things so fast that there aren't any left. In any case, once I get a replacement I will post again.
My battery info (the bad one):
Sony, FRU # 40Y6790, Design Capacity 29.16Wh
Mfg date: 2006-07-07, First Use 2006-09, S/N 1234
Current "Full charage capacity" is 23.24 Wh
Also, I noticed that the device chemistry is listed as "Li-Polymer" -- this is entirely different from "Li-Ion" chemistry. I fly RC airplanes and we use LiPo's because they are VERY light and have VERY high energy density, but you *definitely* do not want to fully discharge them. It greatly shortens the life of the battery and risks fire -- these are bad things. I'm also confused by the Li-polymer vs Li-ION markings... LIPO batteries are much more expensive than Li-ION ones... and the weight difference is not enough to matter except in very very weight sensitive applications... (like RC airplanes that weigh less than 16oz...) I would *guess* that these are actually Li-ION batteries and not LiPos.
(aside:) The proper way to design LiPos for end-users is to not include the "buffer charge" in the usable capacity... so if a given LiPo battery can actually hold 35Wh of power, you only advertise 30Wh and make the system smart enough to switch when you get down to 5Wh remaining. That way you never actually fully discharge one of them. (I simpliied the numbers, but you get the point)...
In any case, I really hope that they get this fixed soon. Hopefully this will help build case history for anyone who actually cares. ;-)
Just keep getting replacement batteries during the 1 year warranty. Might make it costly enough for Lenovo to come up with a solution.
T61P 2.2ghz 4GB 7K200GB 15.4" WSXGA+ Vista 64
HP 2530p L7400 1.86Ghz 3GB 160GB Windows 7 Pro 64
(Hubby) HP 2510p U7500 1.06Ghz 2GB 5K120GB 12" LED WXGA XP Pro
(4 year old son) Toughbook CF-29 1.3Ghz 1.2GB 5K250GB 13.3" XGA XP Pro
FlexOink
My problem is I watch a lot of (fullscreen) DVD/DivX movies away from power, and I dont want to stop the movie every 10 min. to check how full the 2nd battery is.dsigma6 wrote:Outside of a software solution, be inconvenienced and remove the ultrabay battery before it runs out of juice.
The remaining power-percentage is calculated over both batteries, so what I did is let PowerManager notify me when the power hits 80%, which is a little bit before the point the ultrabay is out of power, so it starts the 9cell. After this notification I remove the ultrabay. This way I prevent the ultraby to be completely drained.
IBM ThinkPad T60p 2007-93G
T2600(2.16GHz), 2GB RAM, 100GB 7200rpm HD, 15" 1600x1200 LCD, 256MB ATI FireGL V5200, 9cell + ultrabay battery
The idea I'm supposed to watch the battery and pop it out at just the right time is absurd. Machines should do the work so that people think.
There's clearly a design flaw in the Ultrabay batteries. Either the new batch is losing the ability to hold a charge way too early or else the charging software is poorly designed and is killing the batteries. Either way it's Lenovo's problem. Thank goodness for warranty.
GoofyG28
I'm really hoping my slim battery will get recalled, like my main T60 laptop battery. My ultrabay battery is also by Sony.planetf1 wrote:Lenovo are now recalling a number of Sony batteries - however a check showed my ultrabay batteries as not part of the recall.
I remain convinced they're faulty. Status=red, 50% capacity in a month -- not right.
T60 - 2613-EKU (custom): Core Duo 2.0Ghz T2500, 15" LG-Phillips LCD, ATI x1400, 2GB RAM, 160GB + 100GB HDDs, fingerprint, 2 x 6-cell batteries, ALPS keyboard, Ultrabay DVD-RW, Ultrabay 3-cell battery, Ultrabay HD adapter, BT, Atheros 11a/b/g WiFi
Brand New Oem X230 Battery Losing Full Charge Capacity Fast!
by TheMagicT410 » Sat Feb 11, 2017 12:58 pm » in ThinkPad X230 and later Series - 5 Replies
- 826 Views
Last post by TheMagicT410
Sat Feb 25, 2017 3:04 pm
- 3 Replies
- 267 Views
Last post by Temetka
Wed Apr 12, 2017 1:28 am
Ultrabay battery prevents main battery from charging?
by ThorOfAsgard » Mon May 22, 2017 11:25 am » in ThinkPad T430/T530 and later Series - 8 Replies
- 269 Views
Mon May 22, 2017 8:50 pm
T400 - Ultrabay Battery won't work
by timtakpad » Mon Jan 30, 2017 6:20 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 9 Replies
- 1673 Views
Last post by TonyJZX
Fri Apr 07, 2017 1:39 am
