Thats another thing; I could not bring myself to like the start window either.ischg wrote:Pipelines: I don't know/care, but keep in mind that the fireGL might be running even hotter than my x1400 (idle at 67-72 deg).
SLED is the suse linux enterprise edition.
Live CD's: tried ubuntu 6.06.1 - fully functional. It detected everything except graphics (it was running vesa at reduced resolution). I still used the alternate install CD to get grub into the boot sector of a partition instead of the master boot record (I have a fully functional dual-boot with the rescue partition intact). As I said earlier, you have to make minor adjustments to get everything running.
Main differences? I'm used to ubuntu and like the way it's structured. SLED appeared cluttered in comparison (I didn't like their new start window at all). I guess it's a matter of taste.
What's your favourite distro?
smugiri
Steve
Dead1nside
Well the ATi FireGl T2 is quite old, I'd say they're probably around the same heat disappation. A bit of arctic silver 5 usually brings it down 5 Degrees or so.
I mean are their different structures like I hear people talking about Debian based distributions etc. is it the package management that is the main difference?
Sure, I totally forgot about this aspect. Ubuntu is debian based, SLED is rpm based. If you're just using some software package manager, you don't really feel the difference. But working under the hood it's another world. I've converted rpm's to deb's before (using 'alien'), and they installed fine. I honestly don't have experience the other way around.Dead1nside wrote:I mean are their different structures like I hear people talking about Debian based distributions etc. is it the package management that is the main difference?
And, as I've said in some older post, if you just use the GUI's, they feel about the same (basically personal preference). Under the hood I feel that ubuntu offers more freedom (but that might be just because I'm used to it).
Why don't you just create a couple of partitions and create a multi-boot system to see what you like? A base install of linux is really small (10 gig gives you more than enough space to experiment), and if you happen to run out of space, you can always mount a different partition into your file system. As an example, I have my system set up like this:
/dev/sda1 ... winXP
/dev/sda2 ... linux swap (2 gig)
/dev/sda4 ... extended partition (contains GRUB)
/dev/sda5 ... ubuntu root file system (12 gig)
/dev/sda6 ... SLED root file system (12 gig)
/dev/sda7 ... linux /home directory (19 gig mounted on ubuntu)
/dev/sda8 ... vacant (haven't decided what to do with it yet)
/dev/sda3 ... thinkvantage rescue/recovery
(dev/sda's are the harddrive partitions as seen by the machine)
The advantage of the linux file system is that you can start on a smaller footprint and expand it as you need.
Linux distro for Thinkpad T23 in 2017
by gnutemberg » Thu Mar 30, 2017 10:23 am » in Linux Questions - 6 Replies
- 727 Views
Last post by jaspen-meyer
Tue Jun 20, 2017 2:33 pm
What operatings systems are y'all using on your vintage ThinkPads?
by goldeneagle » Thu Jan 05, 2017 4:00 pm » in ThinkPad Legacy Hardware - 15 Replies
- 2402 Views
Last post by w0qj
Sat Mar 11, 2017 9:12 am
Computrace and who REALLY owns your ThinkPad?
by Digitalhorizons » Fri Jan 13, 2017 5:55 am » in GENERAL ThinkPad News/Comments & Questions - 3 Replies
- 677 Views
Last post by MikalE
Fri Jan 13, 2017 10:40 am
When Autocorrect screws your eBay listings.
by Thinkpad4by3 » Wed Jun 14, 2017 8:43 pm » in ThinkPad Legacy Hardware - 2 Replies
- 221 Views
Thu Jun 15, 2017 11:02 am
