Fingerprint reader and website access
domi
Contributing Member
Contributing Member
#31 Post by domi » Fri Aug 25, 2006 12:23 pm
Nick Y wrote:Does Thinkpads.com show up in PM 'Password Manager Entries'?
Yes. But I can't access its properties with RMB.
Nick Y wrote: Under the menu Set Preferences/ Advanced, is Mozzilla ticked? (I have all of the first 4 in the list ticked:
Enable Password Manager;
Internet Explorer;
Mozilla;
Windows Applications;
Yes, I have the same.
Nick Y wrote: Also I have Default Policies of
Windows Apps: Convenient;
Website Entries: Secure;
Scratch Pads: Convenient;
Autofill: By domain
Other: Enable hot keys.)
I had the same, except for Web entries, which was set to Convenient. I changed it to Secure, to no avail.
Nick Y wrote: Don't know if this will help you; I hope so.
Still stuck, but thanks for your kind help anyway!
Btw, I have CSS 7.00.0022.00, Password Manager 2.0.0, R&R 3.10.0022.00, Firefox 1.5.0.6 and WinXP with the latest everything applied.
Cheers, Dominique
X301 (2776-3JG) | Core2 Duo U9400 1.4 GHz | 8GB | 128GB SSD | Win 7 Pro
als814
#32 Post by als814 » Fri Aug 25, 2006 11:55 pm
I still can't figure out how to get the password manager back into the system tray after updating to CSS 7.
domi
Contributing Member
Contributing Member
#33 Post by domi » Sat Aug 26, 2006 1:39 am
als814 wrote:I still can't figure out how to get the password manager back into the system tray after updating to CSS 7.
I guess you have to check "Enable Password Manager" in the CSS Setup Wizard. You can re-run the setup wizard...
Nick Y
#34 Post by Nick Y » Sat Aug 26, 2006 2:03 am
domi wrote:Btw, I have CSS 7.00.0022.00, Password Manager 2.0.0, R&R 3.10.0022.00, Firefox 1.5.0.6 and WinXP with the latest everything applied.
I have the same.
Perhaps it is something in the CSS preferences, in the CSS dialog, but what I have no idea. (All Programs/ThinkVantage/Client Security Solution; Advanced menu) Also, run the Audit Security Settings in the CSS dialog and see if that suggests anything..
IBM ThinkPad T43-2668-F5G,
als814
#35 Post by als814 » Sun Aug 27, 2006 11:27 pm
Wrong topic, how did that happen. Anyway, i still can't get that Password Manager to work. I didn't see any check box for that.
Users browsing this forum: axur-delmeria and 4 guests
