vlyne
#31
Post
by vlyne » Thu Nov 16, 2006 8:40 pm
fr0zenmon wrote:I ty to plug in usb device into the port and nothing happens. I need to get my usb activiated.
Have you checked the USB port to make sure the pins are OK?
Cheers
fr0zenmon
#32
Post
by fr0zenmon » Thu Nov 16, 2006 8:40 pm
ok so i have the 600e 2645-55u model.
What is the max ram i can install?
1 slot occupies a 128mb card. Can I add a 256mb card? thereby boosting to 128+256. Or can I add 2x256 cards on this model to get 512 total.
600e
128+128 = 256 (i believe this is the answer, can someone confirm it)
256+128 = 384
256+256 = 512 (my ideal, is there a way to do this? Easily?)
or can i go higher ( here's hoping)
Next is this compatible with this model:
128MB sdram PC66 144pin 66Mhz 8chip 16x8 1 inch tall laptop sodimm memory.
TP 600E 2645-55u PII/300mhz/128MB/ 6gb.
TP T20 PIII 700mhz/364mb/12gb
T61
fr0zenmon
#33
Post
by fr0zenmon » Thu Nov 16, 2006 8:44 pm
inside the usb port is a single pick that doesnt have any damage. It is in the center and is blackish/blue and below it are 4 columns with a golden metal spaced out. Outside the port is two screws that are on each side of a metal panel securing the port in the middle.
This is a hand me down so i dont know what work has been done on it.
T61
fr0zenmon
#34
Post
by fr0zenmon » Thu Nov 16, 2006 8:47 pm
since i have 128mb
what kind of linux distro would you recommend for a beginner to install to get a feel for the OS. I wanted to install ubuntu, but i will wait until after i get the memory. Once i figure out which one it is that will work.
T61
vlyne
#35
Post
by vlyne » Thu Nov 16, 2006 9:13 pm
fr0zenmon wrote:inside the usb port is a single pick that doesnt have any damage. It is in the center and is blackish/blue and below it are 4 columns with a golden metal spaced out. Outside the port is two screws that are on each side of a metal panel securing the port in the middle.
All sounds fine (if contacts are nice and even and not bent) although I don't know if those two screws should be there or not - someone with a 600E can advise? Check the pins on the device you're plugging in as well (or test it on another PC). If all's well, and the device drivers are loaded, as Ray says, it's a hardware issue.
Cheers
newbie x220 screen upgrade
Can I do an upgrade to the X220 screen I have? My current screen is a LP125WH2SLB1 (FRU 04W3462). I've been Googling around and just cannot get a...
- 6 Replies
- 925 Views
Last post by jaspen-meyer
Fri Apr 14, 2017 9:06 am
Newbie with a question
Hey.
I have a Lenovo ThinkPad T410 Intel Core i5 2.4ghz 14.1 laptop. The original screen is cracked so I hooked an ACER X191W to the vga port and it...
- 8 Replies
- 724 Views
Sun Jun 25, 2017 4:10 pm
- 7 Replies
- 964 Views
Last post by Raidriar
Sat Apr 01, 2017 12:06 am
Sticky chassi on Thinkpad 600E
So I recently got my hands on a 600E, and I absolutely love it, it’s a fantastic retro machine. But there is one thing that really bothers me, over...
- 2 Replies
- 805 Views
Last post by Kaviar
Sat Apr 01, 2017 6:10 pm
