WTB - 2nd PATA HDD Adapter for UltraBay Slim
fbrdphreak
- **SENIOR** Member
Anyone suggest the best place to get one of these? I've found several for about $50 and I think the best I found on eBay is like $38 shipped. Can anyone do any better?
funny you should ask
Anyone use any mirroring software between dual drives?
Otherwise, I'll just pickup a 160gb drive and toss the 80 into the other slot.
What does Rapid Recovery get for a compression ratio typically? seems ~40% Or should I just use ghost instead?
It is described in detail on http://www-307.ibm.com/pc/support/site. ... IGR-4JW4XW
Comes with a backup utility disk. I never used the disk that came with mine.
Although the page says that the product won't be available after April 2006 (wtf?) it is available on direct sale here for $61.50. Ouch! You might also try big distributors like CDW they may have a better deal on a factory fresh unit.
Story about a x40 msata ssd, pata chinese adapter and southbridge...
by silca80 » Fri Mar 31, 2017 3:06 pm » in ThinkPad X2/X3/X4x Series incl. X41 Tablet - 6 Replies
- 617 Views
Last post by silca80
Sat Jun 24, 2017 7:04 pm
Recommended mSATA-to-PATA adapter for use in T4x?
by karotlopj » Sat Jul 01, 2017 6:05 am » in ThinkPad T4x Series - 1 Replies
- 44 Views
Last post by Johan
Sat Jul 01, 2017 6:41 am
Which Ultrabay Slim batteries fit which ThinkPads?
by bakery2k » Fri Apr 14, 2017 8:45 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 3 Replies
- 748 Views
Fri Apr 14, 2017 9:38 pm
WTB Ultrabay Hard Hard Drive Adapter
by taichi » Tue Jan 10, 2017 11:12 pm » in Marketplace - Forum Members only - 5 Replies
- 633 Views
Fri Jan 27, 2017 3:02 pm
