T60 - Boot Agent and PXE-E05 errors. Help!
Re: T60 - Boot Agent and PXE-E05 errors. Help!
#61 Post by ajkula66 » Tue Jan 20, 2015 10:30 am
brucehe wrote:Any other ideas? Do I need to replace the system board to get Ethernet?
Try booting a "live" Linux USB/CD/whatever and check whether you have LAN connectivity there. The cable should be plugged in the port while you're booting the system.
Good luck and let us know.
#62 Post by axur-delmeria » Tue Jan 20, 2015 12:17 pm
Have you tried disabling the Ethernet Boot ROM in BIOS setup?
RIP: 760XD 9546-U9E
Shadetree
#63 Post by Shadetree » Thu Feb 26, 2015 1:46 pm
This simple solution to PXE-E05 error worked on my T-60 with Win 7 SP1 (x64) BIOS v 2.27 laptop:
1. Press F1 to access BIOS during the ThinkPad splash screen.
2. Select CONFIG > Network > Internal Network Option
3. Select Disable and F10 to Save and Exit.
Users browsing this forum: el-sahef and 28 guests
