Any Power Managment advantages with new BIOS 1.11 ?
madana
Wattage after suspend/hibernation
#31 Post by madana » Mon Oct 30, 2006 3:11 am
I've figured out more on the issue of power consumption being higher after coming out of suspend or hibernate. I'm still trying to narrow down what is going on, but I'm a lot closer.
Rkuo, thank you for your investigation into the real cause of the wattage glitch. I have BIOS 1.11 installed and observe the same problem -- after fresh reboot my x60s consumes about 6.10-6.60W on idling, but after resuming from sleep mode/hibernations it gets stuck at ~ 8.0W level. However, if I reboot, I get lower wattage back.
However, I do not use Wifi and Bluetooth at all, so they cannot be the culprits, at least in my case.
I wonder if this is any different for other BIOS versions? 1.10?
As you mentioned above, you were going to try and communicate the problem to Lenovo BIOS developers so they could fix it in upcoming BIOS versions. In case you still are, you can have my voice as well, for whatever it is worth.
Regards,
Madana
x60s: 170444U, 100GB 5400 rpm, 1GB, WinXP Pro, 8-cell.
stuffinder
#32 Post by stuffinder » Mon Oct 30, 2006 9:23 am
I had installed BIOS 1.11 and it seemed to be operating fine UNTIL, I updated IBM Message Center with most recent update. Shortly after
installing new Message Center I got a Battery Error message on Startup's or Reboot's. Another symptom was that the Battery Image in the taskbar would appear as a blank outline with 3 dashes inside. When I hovered the cursor over the Icon it showed a battery not installed message! I'd run the recall software on both of my batteries but being somewhat concerned with the symptoms I immediately called IBM/Lenovo Tech support. The 1st thing they asked was whether I'd installed BIOS 1.11. Of course they had me check on startup even though I told them I had. They had me drop back to BIOS 1.10 and the Battery Error symptoms went away!
X60s 1702-94U w/Ultra Lite & 8 cell batteries.
Cheers from someone who repaired IBM computers w/60,000 vacumn tubes in the early 60's and still hasn't found a better keyboard than IBM's!
madana
#33 Post by madana » Tue Oct 31, 2006 1:16 am
I went back to BIOS 1.11.
Then I ran Sysinternals' Process Explorer after a fresh boot on batteries, saved the list of services. Wattage was about 6.3 W.
Then I suspended the machine, woke it up after a few minutes, ran PE and saved the list of services after suspend again. Wattage was predictably around 8.5W.
Then I opened both service lists side by side and carefully compared them. However, both lists were identical except for Counters Switch Delta figures.
Looks like the wattage issue with BIOS is somewhere deeper below the surface accessible to amateurs like myself.
Regards,
Madana
x60s (1704-44U): 1GB, 100GB 5400, WinXP Pro, 8-cell
thibouille27
#34 Post by thibouille27 » Sun Nov 12, 2006 7:01 am
On IBM site I only find 1.10 for my X60... nothing higher.
Normal ?
TP X23 +UBX2 +cdrw
TP X60 +UBX6 +dvdrw slim + floppy + 8cells battery
smvp6459
#35 Post by smvp6459 » Sun Nov 12, 2006 11:44 am
They withdrew 1.11...it's not clear why it was withdrawn. At least one person on the board posted that their computer would no longer boot after the update; maybe there was something wrong with the update.
thibouille27
#36 Post by thibouille27 » Sun Nov 12, 2006 5:42 pm
Thanks !
TP X23 +UBX2 +cdrw
