Windows Vista Drivers (no longer BETA)
coolsilicon
Badger,
maybe I wasn't clear enough. A while ago I installed that Beta BIOS and short after that had a bluescreen while burning a DVD-RW under XP. At that time I didn't investigate this any further since I was busy with other things. I just installed my old BIOS again and didn't think of that issue any more.
Now that you were going to install that Beta BIOS, I remembered and thought I let you know that /maybe/ you should look closely at how the Beta BIOS would behave. Anyway, I don't really think the BS I encountered was related to the BIOS, but due to XP messed up a little bit. I will do a clean install when I have the time to do so and I will also install the Beta BIOS again in order to check that out thoroughly.
X200 Tablet (7449); SL 9400; 8 GB RAM; 128 GB SSD (OCZ Vertex 2E), WWAN. Previously: T60; 320 GB HDD / 3 GB RAM / T7200 / x1300 / Bluetooth. Nice machine.
Well the Bios update ended up going fine and still everything looks okay. I went ahead and installed Power Manager for XP onto Vista and it appears to be working, although I seem to remember being able to select what speed the CPU worked at in XP and I don't see those options now.
I also installed IBM's Atheros wireless card drivers. This allowed me to switch from the default "low" output under the powersaving mode to XP's default "normal". This also made my connection normal (I am now at 100% signal strength where I should be, as in, Vista now reports my signal the same as XP and Acess Connections did).
I'm going to try XP's Access Connections right now.
EDIT: yeahhhh... Vista and Access Connections aren't getting along very well. at all.
Double-click on the battery icon in the notification area, choose Tell me more about power plans. Go to the bottom, and under See Also, click on What's new in managing power settings. Scroll about halfway down to the chart with the three Power plans. The text in that chart explains how the CPU speed is affected in each Power plan under AC power and under Battery power. There are three speeds, much as in XP; Adaptive, Slow, and Maximum.Badger wrote:I went ahead and installed Power Manager for XP onto Vista and it appears to be working, although I seem to remember being able to select what speed the CPU worked at in XP and I don't see those options now.
EDIT: Also, if you create or change a Power Plan, after you get to the first settings change page, click on Change advanced power settings. There you can change a multitude of settings.
DKB
coolsilicon
There you in fact get to the interesting part of it. Anyway, the interface is pretty scary. Another point that could be improved /vastly/, just like EasyTransfer, which is a joke, IMHO, interface wise.Also, if you create or change a Power Plan, after you get to the first settings change page, click on Change advanced power settings. There you can change a multitude of settings.
OK I downloaded and burned RC2, I installed it on my T60p, with the newest BIOS 2.01 79ETC1WW. And every time I try to go to the IBM vista drivers page, Internet Explorer crashes on me.
OK I thought that as ROM 2.01 is a 2.xx series it would incorporate the Vista changes. Not sure if it does or not, but I'm finding it very unstable, anyone else seeing this?
Thanks,
Thanks,
ThinkPad T60p T7600 4 GB RAM 320 GB 7200 RPM HD Vista Ultimate Service Pack 2 5.1 4.7 4.2 4.6 5.8For WWAN support:
http://forum.thinkpads.com/viewtopic.php?t=31777
X201s: 1440x900 LED backlit 2.13 GHz, 8 GB, 160 GB Intel X25-M Gen 2 SSD, 6200 a/b/g/n, BT, 6-cell, 9-cell, Windows 7 Ultimate x64 SP1, Verizon 4G LTE USB modem, USB 2.0 external optical drive, Lenovo USB to DVI converter
Previous Models: A21p, A30p, A31p, T42, X41T, X60s, X61s, X200s
wallybear
I have Vista RC1 and BIOS 2.01 (general release, not beta)
I have not had any crashing problems in any program, including IE. I've installed the Beta of OneCare Live and Nero 7.5 (Vista compatible). I've also installed Acrobat 7.08. I plan to download and install the Office 2007 Beta.
I'll report on any problems if I encounter them. So far, the general release BIOS 2.01 works fine with Vista on my T60.
I'm generally pleased with the performance but I know more RAM would help (I have 1GB, will have 2GB when I install the released Vista). I use a 512MB Crucial USB drive as a "ReadyBoost" cache. That made a noticable difference in program switching.
x100e (3508-CTO) 1.6 L625, 4GB RAM, 320GB 7200rpm HDD, Windows 7 Pro x64.
T400 (2764-CTO) 2.53 Core 2 Duo, 4GB RAM, 500GB 7200rpm HDD, 2GB Intel Turbo Memory, LED high-resolution LCD, Windows 7 Pro x64.
T60 (2623-D6U) 1.83 Core Duo, 3GB RAM, 80GB 5400rpm HDD, Windows 7 Pro x86.
Anyone have any luck with T42-series? I have a T42p with a FireGL T2 card, definitely supports DX9 and i'm running Vista RTM (MSDN account so I have it already).
not sure what drivers to use, there are builtins and they work but IME builtin drivers always suck.
Lenovo needs to get the various hotkey utils updated too, I want my FN+F5 back (i don't have a physical wireless switch the way the T60 does).
New Biz: 4062-27U - W500 C2D T9600, 15.4" 1920x1200 (FireGL V5700), 160G 7200rpm, 4G PC3-8500, DVDRW, Intel 5100, BT, TurboMem, T60p KBD
Old Biz: 2613-CTO - T60p Core 2 T7200, 14" 1400x1050 (FireGL V5250), 100G 7200rpm, 3G PC2 5300, DVDRW, Intel a/g , BT
T42 Display Flicker
I am using a Thinkpad T42 (2373-VMH, 14.1" LCD, ATI 64MB, 1GB RAM, New Bios 3.21) with Windows Vista RTM. Everything works fine except that there seems to be a problem a problem with the display which flickers regularly. I was not able to determine a regularity, sometimes it occurs after a reboot, sometimes after a normal startup too.
The display driver installed is the one Vista recognized automatically (for Radeon 9600/9700 WDDM). The monitor is the "Generic Plug and Play Monitor". The display refresh rate is set to 50Hz which is the only available value. Installing the Thinkpad LCD Driver does not solve the problem. Also reducing color depth and resolution or disabling Aero Glass does not help.
I tested the Vista on another T42 (2373-CTO, 15.1" LCD, ATI 64MB, 1GB RAM, Old Bios 3.12) which has a 15.1" display. Everything works fine and the display refresh rate is set to 60Hz.
Maybe I have to try the older Bios-Version...
Any solution?
dga
Any solution?
dga
techniware_au
dga,
Have you tried the ati released catalyst vista drivers? They suggest that the 9600 is supported.
www.ati.com
They don't work for my firegl, but might work for you.
Also, I am trying Powerstrip at the moment - forcing a refresh to a higher rate.
will let you know how it goes.
www.ati.com
Seems that the automatically installed Windows Vista Thinkpad Powermanagement Driver does not work:
Event-Manager:
Event-Manager:
Log Name: Application
Source: Microsoft-Windows-ApplicationExperienceInfrastructure
Date: 01.12.2006 10:36:38
Event ID: 1
Task Category: None
Level: Warning
Keywords:
User: SYSTEM
Computer: xx.domainname
Description:
The application (ThinkPad Power Management Service, from vendor Lenovo) has the following problem: ThinkPad Power Management Service is incompatible with this version of Windows. For more information, contact Lenovo.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-ApplicationExperienceInfrastructure" Guid="xx" />
<EventID>1</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>0</Task>
<Opcode>2</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2006-12-01T09:36:38.968Z" />
<EventRecordID>826</EventRecordID>
<Correlation />
<Execution ProcessID="832" ThreadID="836" />
<Channel>Application</Channel>
<Computer>xx.domainname</Computer>
<Security UserID="xx" />
</System>
<EventData>
<Data Name="DBType">15</Data>
<Data Name="AppNameCount">34</Data>
<Data Name="AppName">ThinkPad Power Management Service</Data>
<Data Name="VendorNameCount">7</Data>
<Data Name="VendorName">Lenovo</Data>
<Data Name="SummaryCount">118</Data>
<Data Name="Summary">ThinkPad Power Management Service is incompatible with this version of Windows. For more information, contact Lenovo.</Data>
<Data Name="SessionID">0</Data>
</EventData>
</Event>
I'm having problems with the power management driver as well - no crashes, but issues resuming from hibernate and sometimes suspend. I'm seeing the same error you quoted in the Application eventlog.
hibernate is the worst - it will come up, but the display will stay "dark" except for hte mouse pointer. If I look real hard I can see windows and the taskbar in the background, and clicking stuff WORKS, but there's no way to make it "brighten up" other than rebooting. What's odd is that when I tell it to restart, it will come back to normal for a split second while showing the "vista is shutting down" screen, but then it goes back to dark for a while before rebooting as normal.
It's suppose to mean Release To Manufacturing and it has many more drivers included with it than any other release of windows.noetus wrote:Does Vista RTM mean Release To Manufacturing or Return to Manufacturer?
ThinkPad T60p T7600 4 GB RAM 320 GB 7200 RPM HD Vista Ultimate Service Pack 2 5.1 4.7 4.2 4.6 5.8Me tooGomJabbar wrote:As far as Opera in XP goes, horizontal scrolling worked with version 8.x. It has not worked with version 9. I have Opera version 9 in my Vista install, and horizontal scrolling still doesn't work. I have to admit I really didn't expect it to.
Christopher_Wolf found out recently (courtesy of ramian) that it can work in Opera 9 (and I suspect Firefox as well) if the middle button is set to "smooth scrolling". I personally have not tried this. I believe I prefer the default behavior when the scroll style is set to "Standard". See thread below.
http://forum.thinkpads.com/viewtopic.php?t=28902
I've gone back to Opera 8.54 .
Java too is better with 8.54
Thinkpad T42p:
1.7GHz Dothan, 1,5 GB RAM, 128MB FireGL, 60GB 7K60, CDRW/DVD
Since the above quote is several months old, I want to restate FTR, C.W. replied to my post above with the following:Aramitz wrote:GomJabbar wrote:Christopher_Wolf found out recently (courtesy of ramian) that it can work in Opera 9 (and I suspect Firefox as well) if the middle button is set to "smooth scrolling"....
christopher_wolf wrote:Nnnno, that part I knew already; read it again. I thought he had gotten it to work with the default Thinkpad Scroll and *not* the Smooth scroll; which is simply an emulation of a middle mouse button and the default *Windows* four-way scroller. That I have known for awhile. <snip>
DKB
Re: T42 Display Flicker
There is a new ATI driver available. Seems that this problem has been solved! http://ati.amd.com/support/drivers/vist ... sta32.htmldga wrote: Everything works fine except that there seems to be a problem a problem with the display which flickers regularly.
u.vivarelli
t43p + vista RTM + driver video
I've a problem; In lenovo' site I read that for my graphic card (FireGL v3200) I must use video driver of windows vista
The following drivers are included with the Windows Vista operating system:
* Audio
* Bluetooth
* Video (not listed above)
* Wireless
I've tried windows vista' driver, ati driver, catalys driver, and my OS work fine, but I think than OpenGL don't work very well.
This is a screenshot of a cinema4D test
www.p04.it/screen.jpg
* Audio
* Bluetooth
* Wireless
Are those drivers for use on a Thinkpad?
I had understood that Catalyst drivers on ATI's site were just for use with desktop adapters?
Andrew
Andrew
dga wrote:There is a new ATI driver available. Seems that this problem has been solved! http://ati.amd.com/support/drivers/vist ... sta32.htmldga wrote: Everything works fine except that there seems to be a problem a problem with the display which flickers regularly.
[Solved] Yoga 2 Pro Model 20266 with Windows 10. Botched SSD upgrade (screen no longer works)
by prophetic » Wed Mar 29, 2017 12:39 am » in IdeaPad Series Laptops - 2 Replies
- 1282 Views
Last post by prophetic
Wed Mar 29, 2017 9:26 am
SL400 Battery No Longer Charges
by Imperatrix » Tue Mar 07, 2017 4:06 pm » in ThinkPad SL and L Series - 3 Replies
- 1894 Views
Last post by Imperatrix
Sun Mar 12, 2017 5:10 pm
Thinkpad T420 Windows 10 drivers
by suman09 » Tue Jan 03, 2017 11:30 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 938 Views
Wed Jan 04, 2017 12:28 am
X220 - windows 10 drivers for SD Reader vanish
by pellicle » Mon May 29, 2017 9:57 am » in ThinkPad X2/X3/X4x Series incl. X41 Tablet - 5 Replies
- 174 Views
Sun Jun 04, 2017 11:07 am
