Second USB port on 600E motherboard?
kocoman
Re: Second USB port on 600E motherboard?
#31 Post by kocoman » Mon Oct 19, 2009 10:51 pm
What does the 27 ohm resisters do?
el-sahef
#32 Post by el-sahef » Tue Oct 20, 2009 4:21 pm
I do not know if they are needed, but since there were 27-Ohm-resistors on the PCB inside the selecta-base, it should be safer not to try it without the resistors.
