I just saw this while looking for a case and thought I would post it; and no, I don't work for Targus.
Here is the new tip that works with the Targus Universal Adapters for the T60/X60.
http://www.targus.com/us/product_details.asp?sku=APT31[/url]
Why did IBM/Lenovo change the power adaptor's (rant)
beeblebrox
- **SENIOR** Member
I am sure, the new plug is just a scheme for Lenovo to make fresh money. The wires are thick enough to carry either 4.5 or 3.25 Amps. The high frequency power bricks don't care much about the voltage difference, although their efficiency is slightly higher with a higher output voltage. On the other hand you have to transform the 20V down to 1.3, 3 and 5V on the motherboard, where you just burn the excess voltage to heat.
The inverter doesn't care, it produces 1200V for the display. Which potentially might use LEDs backlighting in a few years anyway. LEDs run with 1-3 Volts anyway.
And the power usage? You had big, fat hot Pentium 4-M processors 3 years ago, that sucked more Watts than the Core Duo (check the Intel data sheets) and the power bricks were just fine.
So I guess, Lenovo wanted to reduce the brick size and the heat of the power bricks and changed the voltage. While making a new start on the accessory business.
The other useful explanation would be new ThinkPads with fat ATI chips and/or mobile Core 2 Quadro chips.
But then again, your max power is constrained by the max heat emitted from the thinkpads, which were kind of constant in the past 10 years.
I would not buy a ThinkPad that sucks 90W, and hot as an iron.
W530. Did i get a replaced 1080p screen? model number: Lenovo B156HTN01.1
by icuicy » Sat Apr 29, 2017 9:58 pm » in ThinkPad W530 and later Series - 8 Replies
- 332 Views
Last post by icuicy
Sun Apr 30, 2017 9:18 pm
IBM ultranav usb keyboard with numpad SK-8835, change to ISO?
by Ole » Fri Feb 17, 2017 3:35 am » in GENERAL ThinkPad News/Comments & Questions - 5 Replies
- 761 Views
Last post by micrex22
Thu Apr 06, 2017 9:42 am
did any T520 models have quad-core i7 with Intel (NOT nVIDIA) graphics?
by jthorn42 » Thu Mar 02, 2017 9:46 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 8 Replies
- 1155 Views
Last post by jthorn42
Sat Mar 04, 2017 12:02 pm
At which series level did this t series start coming with W7 Restore Discs?
by fefrie » Fri Apr 21, 2017 10:35 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 706 Views
Last post by w0qj
Sat Apr 22, 2017 5:18 am
