Thinkpad Dock II with PCI based graphic Card
noetus
#31 Post by noetus » Thu Nov 23, 2006 2:41 am
ambientscape wrote:well, thanks for the reply. I don;t need it to run Vista thou......just a descent graphic card that can play couple of games will do. So which card you guys talking about that can be really suitable?
(1) Regarding Vista, I have tried to run Vista on several graphics cards with the Dock II and a T42 and could not get it to run on ANY of them. In EACH case I got a device driver issue (possibly a conflict - Vista could not load/start the driver) for the Video card itself and for a PCI bridge device (so problems ALWAYS with two drivers). I tried 3 or 4 different cards. I finally gave up, after reading online about lots of people who could not get Vista to work with two installed graphics cards at the same time, with symptoms similar to mine. This was Vista RC2. I decided that a future edition of Vista might address this problem, and it seems that is the case, because ateece is reporting two video cards working at the same time with Vista RTM. (Incidentally, the problem was not solved by disabling the internal ATI graphics chip, a 9600 in my case - it could only be resolved, as far as I could tell, by physically removing the graphics card/chip, which of course is impossible with a laptop :lol: )
(2) The PCI slot is a LOW PERFORMANCE interface. Even with a powerful Vista-ready card in there, it still might not support the Aero interface. I would be interested to hear from anyone who has tried this. The best Vista solution for the kind of setup we are interested in having (laptop docked with 2 or more external monitors) would be to buy a T60/p and an Advanced Dock, which has the higher-performace PCI Express slot.
(3) I have tried several cards: the ATI 9250, the ATI X1300 (two of them), the Nvidia GeFroce FX 5200, the NVidia 6200 OC (by BFG, thogh Chaintech also makes one), and the Matrox P650 LP PCI card. Follows is a summary of my experience with each card - note that I am driving TWO analog monitors at 1920x1200 (two Sony GDM-FW900s), which is pushing the performance limit of the PCI interface. Also, this is 2D only, I have not tried anything 3D as this doesn't interest me.
(a) The ATI 9250 I tested was a no-fan (so quiet) edition, 128MB with a dual-DVI output via an adapter. I found the text quality poor, quite blurry and hard to read, and this was worse on one of the monitors than the other. It was also quite slow with my configuration - unacceptably so, as there was a noticeable lag when you maximised a window from the taskbar as you could actually watch it drawing the window. However, the card was very stable and never crashed out on me. Possibly the quality issue would be improved on other versions of this card, I don't know. And the performance issue would be less of an issue with less resolution to drive - if I switched my monitors from dual to mirrored (same screen on each), which effectively halved the resolution that adapter was being asked to drive, it speeded things up considerably. So if you're driving significantly less resolution than I am, and you got a different edition of this card with better video quality/sharpness, it would maybe be ok. The card I had was a DirectX 8 version, which most of them are, but there are one or two which are DirectX 9 capable (check Newegg). I was NOT able to get this card working concurrently with the internal card (so two monitors max, no LCD) - I had to disable the internal graphics card to get Windows to boot up without BSOD.
(b) The two ATI X1300 cards I had were better performing (faster, clearer text) but both had fans and so there was a bit of noise. One was 128MB, the other 256MB. I didn't notice any significant performace difference (in 2D) but with EITHER card, after a while my computer would simply freeze up. I'd be doing something, and suddenly the mouse cursor would freeze and that was that, the computer was rendered totally unresponsive, requiring a power-cycle via the power switch. (Interestingly, there was a pattern to this - with one of the cards, for example, I would get the system hang if I tried to right-click on a file. With the other one, attempting to install a program would cause the hang. If I avoided these activities, I could go for a fair while without any system hang, but it would always come sooner or later.) The system hangs rendered these cards useless for me, and pretty soon I sent them both back. If this is an issue not with the ATI chips but with the third-party setup, and you could find an X1300 card that is stable with the Dock II, it would be a pretty good solution. It's a fairly high-powered card, and is Vista ready (i.e. will run Aero, though possibly not through a PCI interface).
(c) I only tried the Nvidia FX 5200 briefly, not enough to know whether it works well with the Dock II. As soon as I bought it I noticed mine was not dual-monitor (despite the claim on the packaging) so I sent it back. I did try it once, and there was no video signal, but I'm not sure what this means.
(d) I have had the best luck with the NVidia 6200 OC by BFG, though this too has not been without its problems. First, the card is powerful (yes Vista Aero ready) and although it has a fan, it is quiet - the quietest fan on any of the PCI graphics cards I have tried by far. It's not loud enough to be annoying with my T42 docked right there on my desk, and I'm fussy about that (I unplugged the Dock II's fan as soon as I got the Dock because the noise drove me up the wall). The power of the card shows through the PCI interface - windows maximise promptly, and 2D video is fine at 1920x1200. It's perfectly adequate in that department for me. The quality is pretty good too, text is crisp and clear, and that's important to me. It would be the ideal solution, except I had the mother of a problem finding a good driver for the card (there are SO many versions of the Nvidia forceware drivers, it's not funny). I had two problems. One was that I would get a BSOD after an hour or two of uptime, which is a well-documented issue with NVidia cards in some systems. The other is that I could not get video to work - especially streaming video. The video player would grab all CPU cycles, would hardly play the video if at all, and the system would become unstable/unusable. The trouble was, if I found a driver that eliminated one problem, the other would appear. Finally I found a version that seemed to avoid both problems, but there are still some weirdnesses - for example, little flecks of 'missing' graphics data in some sorts of graphics objects (this is also a well-known and documented problem with Nvidia forceware drivers). I can live with the little oddities, though - at least I have a high-performance, pretty quiet card that will drive my two displays with almost no issues (in 2D).
(e) The Matrox P650 looked good on paper for what I want (good 2D performance, don't care about 3D, crisp, high quality text). But I could not get it to work in either of two Dock IIs I tried. Simply no video output, T42 would boot up with internal display, Windows would not find the device (or not load it correctly). I gave up trying to make it work when I heard reports of users finding the card noisy (fan) and slow in 2D, despite the nice crisp text. And this was the most expensive of all the cards!
Sorry for such a long post - I hope this is of some use to someone.
ambientscape
#32 Post by ambientscape » Thu Nov 23, 2006 6:32 am
Well, I think the conclusion to all this kinda experimenting and testing lead to unusable PCI graphic with the DOCK. What other options are there for the PCI slot?? A descent sound card maybe?
-Thinkpad T23 1.2Ghz (2647-4RG) with Docking Station (2631)
-512MB RAM
-60GB Western Digital HDD
-3Com X-Jack Wireless A/B/G
-Imation External Combo DVD/CDRW
-Windows XP Pro SP2
-External 160GB Maxtor HDD
Luccio
#33 Post by Luccio » Fri Nov 24, 2006 6:59 am
ambientscape wrote:What other options are there for the PCI slot?? A descent sound card maybe?
OH YES, you can put a great soundcard in. Like a LynxTWO or Lynx L22 (http://www.lynxstudio.com/lynxl22.html). Of course, you can try with a Creative X-Fi or a Terratec Aureon... Make your choice.
Regards.
Luccio . 8)
IBM ThinkPad T43p 2668G4G (320Go, 2GB Ram) + Dock II
noetus
#34 Post by noetus » Fri Dec 01, 2006 2:30 pm
[quote="Luccio
OH YES, you can put a great soundcard in. Like a LynxTWO or Lynx L22 (http://www.lynxstudio.com/lynxl22.html). Of course, you can try with a Creative X-Fi or a Terratec Aureon... Make your choice.[/quote]
You can also run a DAC from the USB, which for decent sound is really the only option. I have one of Scott Dixon's Tube DACs, yes, it has a TUBE! And the sound is just fantastic.
ateece
#35 Post by ateece » Mon Dec 11, 2006 4:05 am
Guys... it looks like we're up the proverbial stream without the proverbial paddle here.
According to MS http://www.microsoft.com/whdc/device/di ... Vista.mspx you have to use the same driver for all graphics cards!
This means that us with an X300, can't use a PCI adapter because the last one was the 9750, which uses a driver that comes with Vista rather than the current ATI/AMD release.
Maybe if enough people email ATI, they will extend driver support to the 9xxx series cards. After all, this problem will affect lots of laptop owners, and people with desktops too (how many people have 1x PCI-E card, and then 1 or more PCI cards?)
My only option, if possible is to use a TFT (which i hope someone can clarify). Could someone confirm either way if you can run an external VGA monitor, an external flat panel (DVI) and the laptop TFT all off the X300. Or do the VGA and DVI ports both count as the second monitor, and you use one OR the other, not both?
ateece
Solution for USA members
#36 Post by ateece » Wed Dec 20, 2006 9:04 am
Guys... it seems i was wrong when i said the 97xx series cards were the last ATI cards for the PCI bus.
VisionTek (and HSI) have both back-ported the X1300 256mb card to the PCI bus with a PCI-Express 2 PCI bridging chip. This appears to use the SAME driver as the native PCI-Express cards!
So, we can put an X1300 into dock, and use the SAME WDDM driver that Vista insists on for multiple monitor.
HSI also have a similar product, but they passively cool their card, which means it will not fit in the dock.
I am trying to get a friend to find one in the USA and bring it back to the UK for me because Visiontek dont sell the part in the UK :-(
_erazor_
#37 Post by _erazor_ » Wed Jan 03, 2007 8:55 am
Ok here I am, having a huge problem
I have the Dock II and an X31. I bought the GeForce 6200 - 256mb from PNY, ofcourse in plain PCI flavour. Thing now is, if I put that into the Dock II, then it does not work at all anymore. I can boot up the X31 via the power switch at the dock, but I get no screen on the videocard attached to the geforce in the dock. When booted up to windows, the x31 also finds _NO_ new hardware. Another thing is that the X31 thinks it is not docked. It behaves just like being undocked. The USB devices at the Dock II also do not function then. The complete Dock is basically out of function if the Geforce is plugged into it. The only thing that works is loading the battery of the X31. But remember, the notebook itself thinks it is not even docked at all.
So, does anyone have ideas? I get no signal from the PCI card, I get nothing to work at the dock II at all. If I pull the PCI card from the dock, everything boots up normally and works again.
I`d really love your ideas on this.
IBM T42p 2373-GYG|14,1'' SXGA+|2.1 GHZ|2048MB RAM|160GB SAMSUNG HDD|1000Mbit LAN|Atheros W-Lan II a/b/g|BlueTooth|
- IBM Dock II
- Tucano Second Skin 14,1"
noetus
#38 Post by noetus » Wed Jan 03, 2007 1:58 pm
_erazor_ wrote:I have the Dock II and an X31. I bought the GeForce 6200 - 256mb from PNY, ofcourse in plain PCI flavour. Thing now is, if I put that into the Dock II, then it does not work at all anymore. I can boot up the X31 via the power switch at the dock, but I get no screen on the videocard attached to the geforce in the dock. When booted up to windows, the x31 also finds _NO_ new hardware. Another thing is that the X31 thinks it is not docked. It behaves just like being undocked. The USB devices at the Dock II also do not function then. The complete Dock is basically out of function if the Geforce is plugged into it. The only thing that works is loading the battery of the X31. But remember, the notebook itself thinks it is not even docked at all.
I had this problem also, and it went away when I tried a different Dock. Have you tried other graphics cards? When I had this problem, it was a problem with all the graphics cards I tried. Again, suggests the problem is with the Dock, not the card.
_erazor_
#39 Post by _erazor_ » Wed Jan 03, 2007 4:48 pm
it`s not like dock II`s are so cheap that I can consider trying several ones :(
- IBM Dock II
cmc57
#40 Post by cmc57 » Sat Jan 06, 2007 12:25 pm
I just got a Visiontek x1300 that appears to be DOA. As far as I can tell the fan is not even running when it is in the Dock II PCI slot and the card does not appear in the device manager. On the positive side, it is not causing any errors. Is there anything I should try before I send this card back?
Great info in this thread. Best I have found on the Internet re: Dock II and video cards. It has led me to the conclusion that my Thinkpad R50p and Dock II are unlikely to ever work reliably with add-in video.
Thanks for your help,
Cathy
noetus
#41 Post by noetus » Sun Jan 07, 2007 12:37 pm
_erazor_ wrote:it`s not like dock II`s are so cheap that I can consider trying several ones :(
I know, I share your pain :cry: Out of two Dock IIs I tried, one worked with most of the video cards I tried (more or less), and the other didn't with any of them, and had the symptoms you described. By the way, I have the same video card as you, except mine is the overclocked version. I sent the faulty Dock back. I now have a third one to try, this one is brand new, so I'll report back on my experiences. In any case, I do have one (used, from eBay) Dock working ok with the card you have. And it does work really rather well, except for a driver glitch. You have to be careful which of the many drivers to use for that Nvidia card.
noetus
#42 Post by noetus » Sun Jan 07, 2007 12:42 pm
cmc57 wrote:I just got a Visiontek x1300 that appears to be DOA. As far as I can tell the fan is not even running when it is in the Dock II PCI slot and the card does not appear in the device manager. On the positive side, it is not causing any errors. Is there anything I should try before I send this card back?
I would try that card in a different machine, if you can, because unless you have had a video card working in the Dock then it _could_ be the Dock, and not the card. I have used an x1300 in a Dock II and though everything booted up fine and seemed to be working, I found it always to hang my system after about 10 minutes (sometimes more, sometimes less) of usage. I tried two different X1300 cards, from two different makers, with the same results. I can't be sure it wasn't something peculiar about my system, of course, so it doesn't mean you'd have the same problem. Best match I have had so far is the BFG Nvidia 6200 card, though even with that card there are some problems (with the drivers).
cmc57
#43 Post by cmc57 » Tue Jan 09, 2007 4:03 pm
I have reason to believe the card is damaged. It was blowing around in a snowstorm for a few days because the shipper delivered it to the wrong address. Just wanted to make sure there was not a jumper I should try before sending it back.
Thanks for responding,
-Cathy
ianf
#44 Post by ianf » Fri Jan 12, 2007 5:44 pm
hello
i have a t30 with dock the pci card i went for was an nvidea it had no name on box just nvidea . not anything to give a clue.
chipset fx5600 , 256mb ram with fan a very large card overall ,it works really well i can play quake 4, very slight lag but will tune settings to cure i belive this to be the best performer as the nvidea 6200 pci is not a 128 bit card this one the fx 5600 has dsub tv out and dvi ,cost less than £60 on ebay ,late nov 06 hope this helps plus no conflict with onboard ati
ianf
hero3616
VisionTek x1550 Works Fine
#45 Post by hero3616 » Wed May 09, 2007 9:21 pm
I use this card from VisionTek
http://www.visiontek.com/products/cards ... 0_PCI.html
and I purchased it from
http://www.circuitcity.com/ssm/VisionTe ... tDetail.do
I tested on Westinghouse LCM-20v5 20" monitor (native 1400x1050 just like my Thinkpad) and Samsung 42" HDTV using DVI-to-HDMI cable (native res. 1280x720). Both works fine. I couldn't figure out how to use both PCI and internal card at the same time but I didn't work on it long enough to say that it's not possible.
Game performance is not much different from my built-in laptop video card (ATI FireGL v3200) just because of dock's PCI interface.
This x1550 card has also a S-Video out which I am sure works fine but I didn't test.
Cem
hero3616
VisionTek PCI + FireGL v3200 works together
#46 Post by hero3616 » Wed May 09, 2007 10:23 pm
Hello again,
I just tested both cards (internal card + PCI card in the dock) at the same time and everything seems to be working fine.
FireGL in the Thinkpad 2668-PDU uses its own driver (or Omega driver)
PCI x1550 from VisionTek uses it's own catalyst driver (from amd.ati.com site) and connected to this is an LCD monitor (from VGA port 1400x1050) and Samsung HDTV (from DVI port to HDMI 1280x720).
The only problem is that the Catalyst software does not find the correct card as the primary card so it complains and does not allow modification. I am sure there is a workaround to this but I don't have time to figure out... Perhaps someone who has a similar setup can help.
Thanks,
Cem
sylme
What about the Matrox p690 ?
#47 Post by sylme » Sat Dec 01, 2007 12:04 pm
Hi all,
I'm using an X32 on a dock II and I was wondering if anyone has tried the successor to the Matrox p650. That is, the p690, Low Profile version.
I need to drive one 24" (1920x1200) & one 20" (1600x1200). Both DVI.
Maybe I'm overshooting with the latest Matrox and something cheaper would be enough. But I love the fact that it's passively cooled (no fan).
All advice welcome.
Best,
Sylvestre
sylme
#48 Post by sylme » Sun Dec 09, 2007 1:35 pm
Hello again,
Won't anybody help me ?! :)
I'm sure some of you have tried the p690 or can tell me if something cheaper would be enough for me (see previous post).
Thank you.
ConnorBehan
Re: VisionTek x1550 Works Fine
#49 Post by ConnorBehan » Sat Dec 20, 2008 1:07 am
hero3616 wrote:Hello,
Sorry for the thread necromancy, but I just got this card to work with the Dock II, and by work I mean that Linux and Xorg recognize it. I haven't actually used it yet because I only have old school VGA monitors and the VGA cables are bulky so they don't fit into the inset port. I'll need some clever extension cable (or a new monitor).
Is it possible to use this (or any docked PCI video card) to drive the internal LCD? I've heard a few people ask it but it sounds like everyone was too preoccupied with driving multiple external monitors which is much more exciting. I know it would be possible if I opened up my case and did some very clever soldering of the LCD wires onto a VGA cable but I would screw that up horribly, and it would not make switching back and forth very easy.
So does anyone know a software or BIOS solution? My Thinkpad is an a22m 2628-S1U and I ran a BIOS update last year but my BIOS still says a ridiculously old date from 2001 or 2002. The options I have in Config>Display are HV expansion (irrelevant I suspect), brightness (irrelevant I suspect), boot display device and adapter.
I set the adapter to PCI. The description says a docked PCI card will be use to drive the boot display device if one is found. I then set the boot display device to LCD. This makes it sound like the BIOS will try to feed the image from my x1550 into my internal LCD correct? This doesn't work. It also doesn't work when I set boot display device to Both. The *only* way I can see something on my LCD when I've loaded an OS or before that is if the adapter selected is AGP. I can't get the x1550 to use my laptop's screen.
I'd gladly use an external monitor but this would be neat to figure out. Can anyone help me with this? Or do you think driving the interal display with a docked card is impossible and the BIOS is poorly worded due to a mis-translation or something? Thanks alot.
EDIT: Apparently I'm a fool for thinking this is possible. The BIOS just has options that are not compatible with eachother.
Tim M
#50 Post by Tim M » Sun Dec 21, 2008 12:06 am
I too have been eying a PCI graphics card for my recently-acquired Dock II (costing me all of $35), namely the nVidia GeForce 8400GS.
On another note, I have noticed that the USB hub in the dock isn't recognized by my PC most of the time.
T42(p) 2379-DXU | 15" FlexView, 2.0 GHz, 2 GB, 128 MB FireGL T2 mobo, UJ-842 Multi-Burner, 100 GB 7200 RPM, Dock II
T410 2516-CTO | 2.66 GHz i7-620M, 6 GB, 512 MB NVIDIA 3100m, 160 GB SSD
vpuleo
Re: Thinkpad Dock II with PCI based graphic Card
#51 Post by vpuleo » Tue Oct 20, 2009 11:36 am
Moved inquiry to ThinkPad T2x & T3x Series board (http://forum.thinkpads.com/viewtopic.ph ... 62#p536262).
