T60P with 15" UXGA ALL GOING AWAY
Are IPS panels, including high-resolution ones (UXGA and SXGA+) available from other manufacturers?
Aren't Dell and HP's non-glossy high-end high-resolution panels, based on IPS technology? All the manufacturers use a different name for these displays, but they tout the wide viewing angles you get with an IPS display.
This discussion is a little too technical for me, but as a practical matter, Lenovo is barely even offering any SXGA+ displays on the 15" T60's, much less the UXGA displays many of us want. And without fully understanding the underlying technology, I can see clearly with my own eyes the clearer, better-quality of the SXGA+ and UXGA screens, compared to the XGA ones. Somehow though the glossy XGA screens I've seen in stores seem to look very nice.
My T42 has an SXGA+ IPS screen, which is great. I did not get the UXGA screen because that would have required buying a T42p which was hundreds of dollars more. In retrospect I wish I had gotten the T42p, but the SXGA+ screen is still a great one.
For me the display is the most important component. Surely Lenovo will be offering more high-end panels soon, don't you think?
I don't know.. most new panels seem to be MVA or PVA (and TFT on laptops), which cannot approach the visual/color quality of an S-IPS display, the new(er) form of naturally-slow-to-refresh IPS technology.Even BOE has shifted away from IPS and developed newer, better Fringe displays.
I'm writing this on a 23" wuxga Sony S-IPS display; the colors look as good as or better than on my older CRTs. I would kill to have a display of this quality in a thinkpad. Isn't "fringe projection" technology used to make holograms from an LCD?
More information on LCD Panels:
http://en.wikipedia.org/wiki/TFT_LCD
Puppy
AFAIK no. It is all TN crap. Only IBM/Lenovo has (had ???) a courage to deliver decent displays. Others seems to be focused on "playstation" features instead of machine you can seriously use without getting sick looking on such ugly displays.chrisnyc wrote:Aren't Dell and HP's non-glossy high-end high-resolution panels, based on IPS technology?
My old R51 (Dothan 1.6GHz) was more than twice as expensive as current top R60 configuration. Still, I wouldn't exchange it because the essential component - the panel is worthless on R60 (no longer IPS).
beeblebrox
- **SENIOR** Member
What a nonsense!seeplus wrote:I don't know.. most new panels seem to be MVA or PVA (and TFT on laptops), which cannot approach the visual/color quality of an S-IPS display, the new(er) form of naturally-slow-to-refresh IPS technology.Even BOE has shifted away from IPS and developed newer, better Fringe displays.
I
At my desktop configuration I am using a 19" Samsung 193p screen on DVI. It is an a-siTFT/PVA display.
IT SIMPLY BLOWS THE IPS AWAY!
Contrast ratio is around 1000:1 and color reproduction is just outstanding. The newest PVA successor uses LEDs for background light and pixel overdrive, which probably will be the new reference class for TFTs.
IPS is getting old, sucks a lot of power, is heavy and expensive and contrast could be better with newer technology.
Another problem ist the "burn in", when crystals are stuck in the electric field and don't move anymore. I have seen this myself several times at T42p's. The picture looks completely washed out.
Though I haven't seen a 193p, I used to own its' predecessor (Samsung 192T) It's a great monitor, to be sure! PVA panels do offer the highest contrast and quick response, but sacrifice color accuracy and suffer from input lag problems inherent to the technology. For my needs, color accuracy is paramount.
... if you're referring to the Hydis IPS displays in Thinkpads, I absolutely agree. I have yet to see *any* laptop panel, ips or not, that can compare to a modern, high end desktop LCD. Apples to oranges as a result of power requirements, etc. Not to mention there have only been a handful of quality-minded laptop LCD panels ever manufactured.IT SIMPLY BLOWS THE IPS AWAY!
LED's as backlight will definitely be the future.. the only two LED backlit LCD panels I know of are manufactured by NEC for color-critical applications, cost >$6k, and use an SA-IPS panelThe newest PVA successor uses LEDs for background light and pixel overdrive, which probably will be the new reference class for TFTs.
...and yet, as I tried to point out in my last post (which sadly did not receive a responsebeeblebrox wrote: What a nonsense!
[snip]
Until we see PVA offered *on* *a* *ThinkPad*, this discussion is pretty much pointless.
Not only that, but although colors might look vibrant and stunning on a high-contrast display technology like PVA, it appears that not everyone is in agreement on how accurate the color rendering is. I would really, honestly, sincerely like to know how true that statement is on Wikipedia's LCD article. If it's wrong, someone (maybe from here?) should point this out to the staff there and offer to rewrite it!
-- Nathan
NathanA -
Who said IPS on ThinkPads was discontinued? All of these models still have a 15" SXGA+ IPS display.......
200755U
200758U
20075BU
200772U
200774U
200773U
200776U
20075RU
20075SU
20075TU
20077DU
20077GU
20077JU
2007C6U
2007C7U
200704U
These are readily available models. Where did you see that IPS was discontinued? All of these in tabook and lots of stock in the channel.
200755U
200758U
20075BU
200772U
200774U
200773U
200776U
20075RU
20075SU
20075TU
20077DU
20077GU
20077JU
2007C6U
2007C7U
200704U
T60p widescreen
My salesrep tells me the T60p widescreen will be announced Dec 1, with a 15.4 inch 1680x1050 widescreen IPS display.
BillMorrow
- *Senior* Admin
the OP said the 15 inch 1200x1600 IPS display was going away..
since i am on dialup at my ranch in georgia i don't have the bandwidth to look up those models listed above, BUT
there never WAS a 14 inch IPS display.. only 15 inch sxga+ and uxga.. 1050x1400 & 1200x1600..
Bill Morrow, kept by parrots
& cockatoos
Sysop - forum.thinkpads.com
~~~Mark Twain~~~
~~~Mark Twain~~~
MountainMan
christopher_wolf
- Special Member
That is a typo, there really never was a 14" IPS display, even on the T series; that used to be a subject of significant discussion in the T4X Conference.
Never figured out just why that was the case, though.
~o/
She does the things you do.
But she is an IBM.
~o/
But she is an IBM.
A couple of questions to follow up on this post about the availability of 15" UXGA screens :
First -- even though there are some 15" T60 Flexview SXGA+ models available -- I'm not talking about ones listed in the tabook rather ones listed on Lenovo's web site as available for purchase -- they are few and far between, only one or two, and none are top-of-the-line models (for example, no multiburner).
What gives with this? When is a full complement of 15" T60's (or their sucessors) going to be available? Will we have to wait for next year (just a couple months away now) when Windows Vista comes out?
Second -- aside from Lenovo, what current notebooks are available from other manufacturers (Dell, Sony, HP, Toshiba, etc), that have UXGA screens that are comparable -- not necessarily identical -- to the UXGA Flexview. and how are they different? I'm not just referring to "glossy" vs. "matte", I also want to know about viewing angle, brightness, fidelity, etc.
I'd appreciate if anyone can shed some light on these two questions.
Thanks !
Thanks !
It looks like a fair percentage of the 20" 4:3 external monitors are IPS-based -- even my Dell 2001FP is IPS (no wonder it looks better than my X31, then!). Smaller panels are mostly not IPS, though.seeplus wrote:I don't know.. most new panels seem to be MVA or PVA (and TFT on laptops), which cannot approach the visual/color quality of an S-IPS display, the new(er) form of naturally-slow-to-refresh IPS technology.
X230 i5 3320m not going going at full speeds
by TheMagicT410 » Wed Jan 25, 2017 2:05 pm » in ThinkPad X200/201/220 and X300/301 Series - 3 Replies
- 793 Views
Last post by TheMagicT410
Wed Jan 25, 2017 6:40 pm
New message notification won't go away
by dandreye » Thu Dec 29, 2016 1:52 pm » in ** HOW TOs & FAQs ** - 6 Replies
- 1770 Views
Last post by dandreye
Fri Dec 30, 2016 4:09 am
GIVEN AWAY: A big box of parts from T6x/R6x projects
by wujstefan » Tue Feb 07, 2017 5:04 pm » in Marketplace - Forum Members only - 7 Replies
- 815 Views
Last post by fefrie
Wed Mar 01, 2017 8:20 pm
Cranked up my T61 after many months away from the forum
by Hans Gruber » Sat Mar 04, 2017 5:26 pm » in ThinkPad T6x Series - 4 Replies
- 965 Views
Last post by E350
Thu Mar 09, 2017 12:14 am
