I don't believe that Vista runs the background defrag while on battery power by default.dfumento wrote:Is there a way to turn off the background defrag when on battery?
BTW, for those of you experiencing worse battery life on Vista, I suggest purchasing a cheap USB Key or Flash memory card for your laptop, and then enabling ReadyBoost on that disk.
ReadyBoost will cache frequently used contents from your hard disk and allow the laptop to spin down the drive much more frequently, thereby saving you a *lot* of juice.
Furthermore, when Hybrid disks come out, it will result in a dramatic increase in battery performance on laptops that have them. Microsoft's testing has shown that, with typical use, hybrid disks extend the battery life of most laptops by around 30% or more.
[/code]
