New Firefox 2 !!!
atomMan
#31 Post by atomMan » Tue Oct 31, 2006 11:16 am
@dsigma6 - don't sweat it, it's really easy. make sure FF is closed:
in your user profile directory, something like "C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles", navigate to the "chrome" directory and you should have a userChrome.css file. or userChrome-example.css which you can rename. make sure this is at the top:
 * Do not remove the @namespace line -- it's required for correct functioning
@namespace url("http://www.mozilla.org/keymaster/gatekeeper/there.is.only.xul"); /* set default namespace to XUL */
below that you can do a return to get a blank line, then just insert one of the lines i quoted above (i use the 2nd one). save > restart FF. you really can't screw anything up - it will either work, or it won't.
dsigma6
#32 Post by dsigma6 » Tue Oct 31, 2006 11:20 am
Thanks, that was easy. My holdup was that I followed instructions that didn't mention putting the file in the chrome folder, but in the profile folder. Hopefully this helps with the lack of VRAM on the T23.
Dan
PDX28
#33 Post by PDX28 » Wed Nov 01, 2006 12:19 am
Donn wrote:Thanks a lot for the info,
PDX, did the password manager work for you before you went to Firefox 2.0? I don't actually have 2.0 but I can't get password manager to activate within Firefox, I will edit the file and take a look.
It was working with the 1.5 version also. The only thing is that the Ctrl+F2 doesn't work.
Thinkpad Z60m and happy with it
atomMan
#34 Post by atomMan » Wed Nov 01, 2006 1:08 am
@dsigma6 - there's a lot of other FF optimizations if you want to cut down on the resources it uses. Since you mentioned memory problems, i would install the Leak Monitor extension. This will test for some memory leaks that are common with extensions. Also check your extensions here: http://kb.mozillazine.org/Problematic_extensions
Other advise would be to use only the extensions you need. If you're using AdBlock, don't. Switch to AdBlock Plus. I'd also recommend a visit here: http://www.tweakguides.com/Firefox_1.html
Koroush is a really good guy and, like me, he lives to tweak the living daylights out of everything :)
If you look around for FF tweaks, inevitably you'll run into "pipelining" tweaks. There are a few very good reasons to IGNORE anyone or any extension which tweaks pipelining. There are very solid reasons why it's not enabled by default. Also changing "nglayout.initialpaint.delay" to "0" is a bad idea.
dsigma6
#35 Post by dsigma6 » Wed Nov 01, 2006 8:25 am
atomMan- I had tested out leak monitor a few days ago, but nothing seemed to happen...
I am happy using adblock plus, as I was tired of having Victoria's Secret Ads prominently displayed on comcast.net while at work.
Thanks for the tips- I've been skimming through and "don't touch this value if you don't have a problem" seems to be the overwhelming theme.
edit: I've found "Cooliris" to be a very interesting add-on. It opens links just by mouse over (in a pop-up), and they go away when you move the mouse off of them. Very cool, but also quite a pain at times. I've got to adjust the delay time.
agarza
#36 Post by agarza » Wed Nov 01, 2006 1:50 pm
Any one noticed phpbb shortcut keys no longer work in Firefox.
Example, when you finish typing a message here in the forums, press left Alt + s and it will submit the message. But in Firefox that functionality is gone.
Also when you want to type in your reply something like italic text, I just used to press left Alt + i. but now, no longer works :?
Current
T440p:
