NMI Parity Error / Hard Lock with t60p + v5200
Since you have a repeatable situation, it would be cool if you could try the driver update first and see if that fixes it.
mitchellst
Hi, any update?mitchellst wrote:Yeah. I may do that.
mitchellst
mitchellst
Too bad!
I'm a bit unclear what you are doing to cause the lockup - maybe someone else can replicate it too if you explain it?
AlexanderT
Weird, I could have sworn it's the wireless network driver. I had the dreaded "NMI: Parity Error" only once and that was when I was actively using my wireless network connection. Normally I am hooked up to ethernet cable, and I never had the bluescreen again.
The newer drivers which supposedly fix the error (it's mentioned in the readme), are only available for Win XP but not for Win Vista yet.
mitchellst
Well... It seems to be happenning whenever I shut down now.
I'm running the diag tests from the recovery partition right now. I doubt it will find anything, but I feel I should try before ordering all new hardware for this unit.
The CD (UBCD) I was running to cause the lockup may be different from the direct download. I know we use it to write the DMI information on all the toshibas we rebuild, which I know was added on by one of our old techs. I'm not sure what the menus look like from the direct download of the CD, so I don't know if this will help.
When you boot from the CD, the first option on the menu is Launch Ultimate Boot CD for Windows. Once windows loads, on the start menu, it has "shut down options". From there, I pick "shut down and eject cd". The cd ejects, and I get the error.
I'm guessing there are several things that can cause this. I'll figure it out eventually... I was really expecting it to be the board though.
mitchellst
Well... It definitely has something to do with the wireless card. I removed all the unnessecary hardware from the board and the error went away. I put back the wireless card, and it came back.
I decided to retry installing the drivers that were supposed to fix this problem. Now, when I try to run setup, halfway through it, I get the error message.
I'm gonna order a new wireless card. I'll let ya know how it turns out.
Wow, weird. Thanks for keeping us posted!
mitchellst
Re: NMI Parity Error / Hard Lock with t60p + v5200
I'm experiencing the same thing on my T60p with 2x1gb sticks. I've updated the wireless driver and the display driver. Neither helped. For those of you who found that replacing the wireless card fixed it, what's a good replacement model?dodeca-t wrote:I have noticed a few failure modes:
1: What appears to be a VPU reset. This is the most rare. Screen will blank out, come back, WoW will continue to run.
2: Screen blanks, or image freezes on screen, and sound loops. this requires holding down the power button to restart the machine. Windows seems unaware that a crash occoured (no warnings, etc on next reboot) (this is the most common)
3: Blue NMI: Parity Error screen
Re:
I upgraded my T60p to Windows 7 and was getting the BSOD occasionally. The other day I found a new wireless driver for Intel Wireless LAN (bg, abg, abgn)/Windows 7 on the Lenovo support site. Haven't had a blue screen since, hoping that was it!WPWoodJr wrote:I haven't had any BSOD since updating the wireless driver (fingers crossed!)
http://support.lenovo.com/en_US/downloa ... MIGR-77063
The other day my wireless card stopped working and I had to reboot to get it back. Better than a BSOD though!
Sent from my DROID BIONIC using Tapatalk
New Wifi Driver
http://support.lenovo.com/en_US/downloa ... MIGR-77063[/quote]
Apparently you need to have KB932063 installed as a prerequisite for the new driver, which I, surprisingly, can't find in my installed MS updates and fixes.
The driver page links you to the MS page for KB932063, which I find the most counter intuitive and bewildering page I've ever been on. I can't find the simple link for KB932063. (I'm running Vista 32 Ultimate)
Also on the driver page it says you may have to reenter security information after installing the Wifi driver. Did you have to do that? Was it merely the information for your router?
I have Windows 7 so I did not need that hot-fix. However, the hot-fix page indicates that you should simply upgrade to the latest Vista service pack and the fix is included.
I have Vista SP2 6002. but when I look for that hotfix I don't see it in installed updates/fixes!WPWoodJr wrote:I have Windows 7 so I did not need that hot-fix. However, the hot-fix page indicates that you should simply upgrade to the latest Vista service pack and the fix is included.
That doesn't mean the fix isn't part of the service pack. I wouldn't worry about it.
Kensington ClickSafe Lock - Hard to unlock?
by Lucky#Slevin » Mon Mar 20, 2017 12:16 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 0 Replies
- 807 Views
Last post by Lucky#Slevin
- 7 Replies
- 1012 Views
Mon Feb 06, 2017 7:48 pm
WTB Ultrabay Hard Hard Drive Adapter
by taichi » Tue Jan 10, 2017 11:12 pm » in Marketplace - Forum Members only - 5 Replies
- 623 Views
Fri Jan 27, 2017 3:02 pm
Hard Drive won't boot and external USB Hard Drive enclosure/caddy/adapter for file retrieval
by E350 » Thu Apr 06, 2017 11:38 am » in ThinkPad T6x Series - 5 Replies
- 924 Views
Thu Apr 06, 2017 9:43 pm
Users browsing this forum: ElusiveRoberto and 26 guests
