Lowest wattage contest
Terrahawk
The same effect occurs when you don't turn your power management features to max. I notice the IBM driver sets max power savings as the default when you install it, but the Atheros generic driver doesn't. I had my IBM card set to normal power saving when I took those figures. When I set it to max power saving, the amount of power used when idle dropped considerably - it was quite difficult at times to pick it.
Geoff.
T60P 2007-8JM / T60 1951-A35 / Z60M 2531-E9M / Tablet 1838-23M / Tablet 2 3679-27M
T410 2522-CTO / X301 2776-A17 / X201 3680-FAG / T420 4180-AQ3
I just ran a quick test.marlinspike wrote:I think you'll find the wireless draws significantly more energy when it is actually in use (i.e. not just on but actually downloading/uploading)
14" SXGA, x1400, profile set to minimums, bluetooth disabled. WiFi connected, but idle settled down to about 11.5-11.6 watts. I transferred a 2GB+ file from my desktop and it settled at 15.5-16.0 watts. That's the cost of the WiFi and the hard drive accessing.
Still, surfing the web doesn't put much draw on the Intel card and it remains in the 12.5 range for me.
How do I reduce my consumption?
So I am struggling to get below 17W. I must be doing something wrong. Here is what I have done on my 2GHz T60p (1400x1050):
Power Plan: Maximum Battery life (Max CPU = lowest, Display level 1 of 7)
ATI Catalyst settings: PowerPlay adjusted for Maximum Battery Life, allowing refresh rate reduction and auto color depth reduction
laundromatt
Terrahawk
I think that it is a general trend to see the older models draw less than the newer ones, starting from the original Pentium-M models.
I had an X21 wnd that averaged about 8.6W idling with no wireless, display at 5/7 and hard drive running. My R40 averages about 9W idling with wireless on, display at 5/7, DVD/CDRW drive inserted and hard drive running. My current X31 idling with wireless on, display at 5/7 and hard drive running averages 8.2W. I normally use it with the display at 4/7 though, which brings the power usage down to 7.8W.
What I have noticed through looking over various generations of machines from Pentium-M Banias-based Centrino through Pentium-M Dothan, Core Duo and then Core 2 Duo is that the average power usage has been creeping up but the running times have been staying about the same. If my X31 or R40 were using 13.5W, they would be lightly loaded, maybe playing MP3s while actively surfing the net and visiting sites with a few small flash animations. I would not be surprised if a more modern machine such as a R61 or X61 would approach 20W while doing the same thing.
Geoff.
crashnburn
Do we have a winner yet? Maybe a couple of winning configurations.
Users browsing this forum: NonesensE and 17 guests
