New 802.11n wireless cards
MIMO adds speed, but not range. Assuming that you have channels available for the connection, 802.11n MIMO will simply transmit (or receive) on multiple channels to increase the throughput. That does not have a meaningful effect on the range, though.SHoTTa35 wrote:As for the 3 vs 2 antenna thing, you can use the card with just 2 antennas but you wont get the MIMO which is what N is all about, you get the range and speed since that's what the third antenna brings.
tomh009 wrote:MIMO adds speed, but not range. Assuming that you have channels available for the connection, 802.11n MIMO will simply transmit (or receive) on multiple channels to increase the throughput. That does not have a meaningful effect on the range, though.SHoTTa35 wrote:As for the 3 vs 2 antenna thing, you can use the card with just 2 antennas but you wont get the MIMO which is what N is all about, you get the range and speed since that's what the third antenna brings.
I remember MIMO will also increase range as well...
From wikipedia:
"MIMO technology has attracted attention in wireless communications, since it offers significant increases in data throughput and link range without additional bandwidth or transmit power. It achieves this by higher spectral efficiency (more bits per second per Hertz of bandwidth) and link reliability or diversity"
Pascal_TTH
I would like to buy Linksys WRT350N to upgrade my LAN to Gbig and Intel Wireless WiFi Link 4965AGN PCI-Express to speed up WAN to 802.11n.
But, I don't know if the Intel Wireless WiFi Link 4965AGN PCI-Express requierd tree antennas to work in 802.11g. I still haven't found Intel Wireless WiFi Link 4965AGN as a FRU for T6x.
Does some one already try Linksys WRT350N with any Thinkpad using 802.11N ?
Apple MacBook Pro MB133
Pascal_TTH wrote:I would like to buy Linksys WRT350N to upgrade my LAN to Gbig and Intel Wireless WiFi Link 4965AGN PCI-Express to speed up WAN to 802.11n.
Thinkpad a/b/g/n=42T0825
4965AGN=42T0865
FirstTimer
I have Atheros abgn and Linksys WRT350N
Here is my experience with this setup
The bottom line is that I use G network since it’s working faster than N in this setup.
I only have two antennas connected in my laptop so your experience maybe better
Lenovo Z61P- Atheros ABGN
Pascal_TTH
poky wrote:Thinkpad a/b/g/n=42T0825
4965AGN=42T0865
Thank you so much poky ! What more, they are in stock according to IBM website.
Thinkpad a/b/g/n=42T0825 => 80 €
4965AGN=42T0865 => 150 €
Intel 4965AGN cost nearly twice the price of the Atheros one ! I wonder if ii worth...
This hasn't been the case even with G devices for a while. Even with a B device connected most G devices get close to their normal speeds (while still a bit less than ALL G) but it doesn't slow the entire thing to B speeds so i wouldn't assume this is the case with N devices.bert wrote:In order to get .n speed, do all devices connected to the network have to be .n? Or can you mix .n .g and .b and have all devices run at their maximum speed?
Thanks poky for clearing that up
Well no wonder, as you saw from my post earlier (read the reply from tomh009 too), you need 3 antenna's to get the speed of N otherwise it'll just be the same as G.FirstTimer wrote:I have Atheros abgn and Linksys WRT350N
Pascal_TTH
Thank you all for your advice. I also apologize for misunderstanding (I not very good in english). I will cost a lot to upgrade T60p to 802.11n (a least 180 € for Lynksys unit and 80 € for Atheros) and with only two antennas, it can't work in n mode.
Thus a last question : can the WAN antenna be used as thirds antenna ?
If I can't, it's definitively the end of the project. I don't want to by an antenna and open the screen cover to mount it.
Broadcom BCM943222 and BCM43222 802.11n WiFi cards for T4x
by dandreye » Wed Jan 04, 2017 2:48 pm » in ThinkPad T4x Series - 5 Replies
- 2090 Views
Last post by dandreye
Sat Jan 21, 2017 1:17 pm
WiFi 802.11g for Thinkpad 380xd?
by bobclark86 » Sun Mar 12, 2017 12:19 pm » in ThinkPad Legacy Hardware - 7 Replies
- 1242 Views
Last post by Jackbee
Sun Jun 18, 2017 4:44 pm
Cheap 32MB DRAM cards for TP755/750/360, etc
by goldeneagle » Thu Jan 12, 2017 10:28 pm » in ThinkPad Legacy Hardware - 3 Replies
- 1522 Views
Last post by goldeneagle
Fri Feb 24, 2017 4:03 am
WTB: PCMCIA Sound Cards with SB emulation
by jeffbaichina » Wed Jan 25, 2017 11:25 am » in Marketplace - Forum Members only - 0 Replies
- 253 Views
Last post by jeffbaichina
