Uninstall Cisco wireless radio control?
uberT
#31 Post by uberT » Sat Dec 09, 2006 7:27 am
Beech200 wrote:Running access connections version 4.12 here. I have had a strange ongoing issue in that when unit comes out of Hibernation or Stand by Access connections seems to negotiate with access point and then drops the IP causing loss of internet connection and VPN.
I've always suffered with this...thought it was part of the design ;)...j/k.
Hard to explain but I remember the previous version I had of AC worked flawlessly.
One point of interest for you that I read on the net concerning our units is the bios problems some experience when installing non authentic IBM Mini PCI devices.
No trouble on mine what so ever but it seems to be a huge problem. I read that some T30's receive an unauthorized error messages immediately at power up. I also read of a hack program to overcome IBMs built in Proprietary code that prevents what I have had success with this unit and an R40.
I've read about this - I don't think I'll be affected based on others' comments.
I simply point out the possibilities for which I hope you don't experience.
One thing I was going to ask you is if you tried disabling AC and let windows built in WAN detect access points?
I did try this and status remains the same: No networks found, move closer to access point :(
T30 2366-85U
T43 2668-4DU
R60e 0657-3ZU
T61 7663-2EU
T420 4178-6VU
E420 1141-BTU
G570 4334-4QU
Acer Aspire 1430
Gateway Solo9300
