Windows OEM Cd-Key
pedromsouza
I'm getting tired of this...
Ok, IBM sent me Product Recovery CD's and I installed correctly. When Windows asks for activation through internet I get the msg "incorrect key". But that's the OEM key, from the COA ticket. I don't know what's wrong....
IBM Thinkpad T30 2367-DL2
Original configuration
Windows XP SP2
Windows XP SP2
A recovery with a proper set of CD's and a proper technique will never ask for activation.
1. Recovery CD's from IBM have been known to be bad. Happened to me twice on two different machines.
2. Improper technique can cause the recovery to fail. The cure (that I got from IBM) was to break out of the recovery at the first screen (Esc or F3) to a DOS prompt. Run fdisk to see and delete all partitions, then run fdisk /mbr. Then try the recovery again. That has worked for me.
I want to underscore that for T43 and below, a recovery that asks to be activated has not installed correctly. It would be pointless to proceed with such a build. Correct the problem and try again.
... JD Hurst
... JD Hurst
pedromsouza
- 1376 Views
Last post by TonyJZX
Tue Feb 07, 2017 2:44 am
Brand New Oem X230 Battery Losing Full Charge Capacity Fast!
by TheMagicT410 » Sat Feb 11, 2017 12:58 pm » in ThinkPad X230 and later Series - 5 Replies
- 831 Views
Last post by TheMagicT410
Sat Feb 25, 2017 3:04 pm
- 4 Replies
- 843 Views
Last post by glasair
Wed Apr 19, 2017 5:47 pm
- 3 Replies
- 623 Views
Last post by Brad
Tue Jan 03, 2017 1:27 pm
