access completely unresponsive...
Support for your LENOVO branded Laptop.
For those on the road to ThinkPad ownership..!
llama_thumper
#1 Post by llama_thumper » Sat Dec 30, 2006 3:58 pm
hi - am a thinkpad owner with 3 years experience of using my T40P. My girlfriend recently bought a Lenovo 3000 N100 laptop. It did not want to connect to the network of her parents, an ad-hoc network with static IP's (no DHCP). after some messing around by her dad, the problem was still not solved, so I uninstalled access, as well as the wireless drivers, and installed new drivers and the newest access (4.21 i believe).
unfortunately, access has become completely unresponsive - i tried removing access and the wireless drivers, and installing them again, but this did not help. the programme launches correctly in the system tray, but whenever i double click on it, or click on things in it (eg managing profiles), it takes AGES before anything happens.
what could be at fault?
truk
RE:access
#2 Post by truk » Fri Mar 16, 2007 9:58 pm
Check your firewall, this is quite often a cause of slow programs. If you disable windows firewall and any firewalls/spyware blockers does it still run slow?
http://www.truk.tk - 'Cause you've got nothing better to do.
RIP t30 2367-au5 October '07
t400 2764-CTO
7/OSX/Ubuntu
2.8GHz core 2 duo
4g DDR3
320g@5400rpm+160g@7200RPM
Led backlit and all the goodies
llama_thumper
#3 Post by llama_thumper » Mon Mar 19, 2007 3:11 pm
thx for the answer - a complete removal of the drivers and reinstall of access helped - not sure why it didn't first time round.
Return to “3000 Series Laptops”
