http://www.avsforum.com/avs-vb/showthread.php?t=759929
Erik - Can you / can I please change the Threat Topic. I know this is an old thread that should be reused but the SUBJECT / TOPIC does not do justice
Nice. You are the right person to talk to thenerik wrote:the 30" displays only need one dual-link DVI-D cable going to them to push the full 2560x1600. i think the confusion comes from the "dual-link" part as people interpret that as being two cables.
i've used both a 30" apple cinema display and dell 3008WFP with my former T61p using the advanced mini dock so i know they work. i didn't like either display as they seemed slow so i ended up with a thinkvision L220x. samsung has a 30" in the works with S-PVA panel, 1000:1 contrast, 300 cd/m^2, and displayport input due out later this year. that's what i'll get if i decide to upgrade as it will be just like having a larger version of the L220x.
regarding the thread title, i'm not sure what to change it to so that it's more appropriate. the info about 30" displays is scattered across the forum and this is one thread of many with answers to the various questions about using them.
correct.crashnburn wrote:So, all we need are the following:
- T6x with Discrete Video (Any Discrete Video card right?)
- T6x compatible Dock or Adv Mini Dock
- 30" Display
- The cable (no extra video cards needed)
Please elaborate on this a little more.i didn't like either display as they seemed slow
Whoa! Some professional photography.. Nice. I havent gone down that path yet. Do you supply to Digital Photo Libraries for licensing?erik wrote:dragging large photos around the screen on the 30" displays seemed slow. by "large" i'm talking about 100~300MB TIFF/ProPhoto images developed from a 21MP DSLR. the L220x is definitely faster in this department.
the advanced mini dock is all you need to drive a 30". the advanced dock can house a third-party graphics card but you need a certain card to work with your specific system. the card needed varies based on your machine's GPU so i can't answer this question if you asked me.
nah... it's just a hobby right now. i do get paid once in a while to shoot product photos for clients though.crashnburn wrote:Whoa! Some professional photography.. Nice. I havent gone down that path yet. Do you supply to Digital Photo Libraries for licensing?
yes, the advanced mini dock will work. the card needed in the advanced dock must match the GPU in your T60p/T61p for the drivers to work correctly, plus the card has to be a half-height PCI express card with matching bracket to fit in the dock.crashnburn wrote:Let me get this right.
- Adv Mini Dock will work
- Adv Dock has ability to add Video Card >> Question can it drive as well without the extra video card? OR It HAS TO HAVE a specific video card based on the GPU?
I got past that. I dug up a lot of older threads and those were resolved.erik wrote:crashnburn - please clarify what you are confused about. you've now confused me.
crg7 - a T60p/T61p with an advanced mini dock will drive a 30" @ 2560x1600 via the dual-link DVI-I port on the dock.
VGA can only drive up to 2048x1536 and therefore cannot drive a 30" at 2560x1600.
hope that helps.
