Dropped wireless connections requires reboot
ThinkTay
#31 Post by ThinkTay » Tue Feb 06, 2007 12:31 am
anyone test disabling LAN?
creed_mty
#32 Post by creed_mty » Tue Feb 06, 2007 1:06 am
ThinkTay wrote:anyone test disabling LAN?
I always have wireless and ethernet together, so i have had a similar problem when resuming and all i did is to turn off the wi-fi switch and turn it back on and i recover connection after several secs. i think for about 10+ secs.
T60 >>>2613 HNU (CTO). > 15" SXGA 1400 x 1050 > Windows XP Pro > Core 2 Duo T7200 2.0 GHz
> 2 GB RAM > 128 MB ATI X1400 (hyper Memory)GPU > 100 GB HDD @ 7200 rpm. SATA > DVD Multiburner > Intel a/b/g. - Bluetooth - Finger Reader > 9 Cell Battery
gere123
#33 Post by gere123 » Tue Feb 06, 2007 11:02 am
RaviN
#34 Post by RaviN » Tue Feb 06, 2007 1:50 pm
I tried the equivalent for my T60 which has a different wireless card than the one in the document above. No change in behavior on plug/unplug - still conks out with regularity.
Ravi Narasimhan
Redondo Beach, Calif.
dlp
#35 Post by dlp » Tue Feb 06, 2007 2:05 pm
I did it for the ethernet, even though I have an Atheros wireless card in my T60p widescreen. It seems to have done the trick.
gere123
#36 Post by gere123 » Tue Feb 06, 2007 3:49 pm
I'm trying it now also... so far, no disconnects. Will check in again if anything else happens.
sega
#37 Post by sega » Tue Feb 06, 2007 9:46 pm
Well, I bought new widescreen T60p back in December 2006. I've got Intel 3945abg wireless card and I had exactly the same problem with dropped connection as many people here have. Only reboot could help me to restore the connection. By the way I didn't notice any correlation between the wireless connection issue and plugging/unplugging AC.
But then I've read the post above and followed all recommendations. It looks like in my case it fixed the problem. At least I don't have any issue with the wireless for about a week.
jordanjw23
so far so good
#38 Post by jordanjw23 » Wed Feb 07, 2007 12:23 am
so far so good....i tried it and it worked....i think its got to be an atheros issue cause of the pre N
lets see if it lasts
thanks
RaviN
#39 Post by RaviN » Wed Feb 07, 2007 12:54 am
Hmm. This seems to work. >20 power connect/disconnect cycles and, so far, no loss of wireless connectivity. I would previously lose connectivity sometime between the first and fifth plug/unplug. System also appears to reconnect after Standby and Hibernate. LAN connection establishes when connected and wireless picks up after LAN disconnect.
Setup: T60 widescreen, wireless managed under XP, Access Connections software uninstalled, LAN card driver adjusted per document, Atheros wireless card adjusted equivalently to card described in document (Atheros driver does not offer as many options).
Not declaring victory yet but am encouraged for the first time in a long while!
Ravi Narasimhan
Scratch
#40 Post by Scratch » Wed Feb 07, 2007 8:37 am
Step #10 seems to be the culprit per this thread from last week
I had made the other settings changes some time ago for solving other problems with license management software, etc. I had disbled this power mgmt feature before, but somewhere along the line it was changed back to the default to allow power down by some unseen force.
T'Pad 600e, 770x, A20p, A21p, A30p, A31p (2653-H3U), T43p (2668-Q2U) & T60p (2623-DDU)...it's an addiction.
jordanjw23
atheros different
#41 Post by jordanjw23 » Wed Feb 07, 2007 9:16 am
Scratch
on the atheros card, It seems as in the atheros card there is no power management....step 10. Instead, you have to turn the wireless power save value to OFF and the ethernet power manager to disabled. That did the trick for me
Scratch
#42 Post by Scratch » Wed Feb 07, 2007 12:51 pm
Good point jjw23. I sometimes forget the differences. I have a few systems with the Atheros/IBM card and had to go down that tweak path as well.
I'm still amazed by the number of difficulties that I've had with these systems that all revolve around something as basic as Power Mgmt on a laptop.
RaviN
I think it is fixed
#43 Post by RaviN » Wed Feb 07, 2007 3:41 pm
I think the comprehensive power management disabling fixed the problem. Many thanks to the group.
Ravi Narasimhan
ugo
access connections
#44 Post by ugo » Thu Feb 08, 2007 12:54 pm
I exeperienced a frequent wireless drop when using battery with an X60s.
I disabled
"Enable automatic wireless LAN radio control"
in Access Connections -> Configure -> Global Settings.
In my case this solved the problem.
Hope it helps.
tyito2000
#45 Post by tyito2000 » Sat Feb 10, 2007 11:29 pm
I think I have isolated the issue to the OS, Win XP. The same connection problems happens with my Thinkpad and my three year old Sony VAIO desktop. The problem appears to be caused by Win XP while running bluetooth. When I disconnect the bluetooth adapter, everything runs fine and there are no connection issues.
I understand this is not the perfect solution, as I rely on bluetooth peripherals. But, since the same problem happens with two different hardware manufacturer's, this appears to be a bug/issue with Microsoft's bluetooth stack. So far, I have scoured Microsoft's KB and Google with no pertinent solutions.
My only workaround is to change power states with the bluetooth adapter disconnected. The internet connection will remain connected.
ThinkTay
#46 Post by ThinkTay » Sun Feb 11, 2007 1:09 am
I believe many of us experienced the problem with the bluetooth antenna off actually. It works fine for me now, after the above advice, however I found that by turning off the LAN I also circumvented the problem.
Seems to be plenty of work arounds
drwho9437
Has there been a definitive solution?
#47 Post by drwho9437 » Sun Feb 25, 2007 1:36 am
I have a WS T60 with atheros N card. (8744-5BU)
This is what I have noticed, coming out of hibernation the wireless sometimes is disabled. Typically when this happens it finds no networks at first, then finds all the networks but the one it was logged onto before the hibernation cycle.
I would like to know a reliable way to reproduce the issue, so that I can definitively test solutions.
The closest I have come to this is a restart plugged in to AC power. This results in wireless that works. Then I place the machine in hibernation (still plugged in). I then remove the AC power and turn it back on. This at least sometimes results in the type of loss noted above, log out and log on/disable/repair will not fix the issue once this has happened.
This method does not seem 100% reproducible. I would speculate that it causes the problem because of the state of the machine is not the same before and after hibernation, and something misses the state change and then goes off and panics or dies. (software)
If you have a definitive way to reproduce it or have fixed similar behavior on your machine of same spec, I would be interested.
I have removed Access Connections after trying a few settings with the method outlined above in the Access Connections software. I also tried disabling the "allow this device to be turned off" for the wired Ethernet. It however still disappears from the device manager when the system is unplugged from AC power. I believe this removal of device without notice that is often in the windows error log could in principle be the source of the problem as it might corrupt the network stack.
Does anyone know what causes it to be removed from the device manager?
I have not tried power setting on my atheros nic yet but might try that next.
Again, I am looking for a way that reproduces the problem ideally 100% of the time, and any solutions people think work.
I am asking this because I found the thread up to this point full of confusing information and "I think this works" ideas.
Thanks very much.
drwho9437
So far...
#48 Post by drwho9437 » Sun Feb 25, 2007 3:53 pm
After my last post I continued experimenting.
The "deep smart power down" listed in the PDF is was appears to let the Gigabit disapear from the system. Since this is done on plug/unplug and affects the network stack I am hoping this is the culprit.
I am still interested as to the post above's info, but I'm not going to keep trying to make it die unless someone posts some definitive way of doing so. So far after disabling the power management on the Gigabit adapter, I have not had any wireless deaths.
I also removed Access Connections, but there were several wireless deaths after, that so I do not believe that was the cause. It certainly cannot be the sole cause.
For now power management is still on for the wireless card.
laundromatt
#49 Post by laundromatt » Sun Feb 25, 2007 4:20 pm
why don't you guys try an intel card, with the appropriate drivers? maybe that'll fix the problem.
T60: 2623-D6U
X41: 2526-A29
drwho9437
I guess I could
#50 Post by drwho9437 » Sun Feb 25, 2007 7:26 pm
I do have an old intel wireless mini-pci in my old laptop, but I'd rather find the source of the problem of course.
That will of course be my method of last resort. I have some hopes that it is completely cause by the deep sleep function of the gigabit Ethernet. But without a systematic test it is hard to know for sure.
mtomd
#51 Post by mtomd » Sun Feb 25, 2007 9:30 pm
With the XP pre-install I always had this problem with the wireless not working with my Artheos A/B/G/N card. I installed Vista 3 weeks ago, and I haven't had a single issue with the wireless not working and needing to reboot. Maybe it's the XP drivers?
T60 (2613-HKU), 14.1 SXGA+, T7200 2GHz, 2x1GB, x1400, 7200RPM 100GB, IBM Wireless A/B/G/N, 9 Cell Battery
drwho9437
yes
#52 Post by drwho9437 » Sun Feb 25, 2007 10:56 pm
Clearly it is a driver power management issue, so if you are running Vista it could indeed fix if the driver code base is different, or Vista could just handle power management differently enough never to cause the sequence of things that tigers the problem. In any case that is nice to know but does not solve the issue for those who do not have Vista available yet. But thanks for noting it. It good to know if and when I move to vista these problem might disappear.
Overlord66
Re: So far...
#53 Post by Overlord66 » Mon Feb 26, 2007 1:17 am
drwho9437 wrote:After my last post I continued experimenting.
I was having the same problem as you with my laptop when i first got it. I followed the instructions in the link above and have not had a single issue since the changes. The issue is very strange but it's fixed now so I'm not going to worry about it.
hoya
#54 Post by hoya » Tue Jun 26, 2007 10:23 pm
same problem on my 87445BU - oddly enough installing the 2005 C++ Redistributable Package fixed the problem for me:
http://www.microsoft.com/downloads/deta ... laylang=en
note: I was seeing SidebySide errors in the event log before installing this update. if you are not seeing SidebySide errors it might not be worth installing the package.
