Help! Need smaller replacement AC adapter for T43.
I need to buy a second AC adapter/charger. Was wondering if there was a smaller, easier to transport, option than the one that came with my T43?
Ideapad purch Oct 2013. Cannot recommend.
T410S Purch July 2010
T43 2687D3U; XP Pro; Pentium M 750 1.86 w/915PM Express Chipset; 1GB+1GB DDR2; 14.1" SXGA+ screen w/64MB video; 60HS drive (320GB External added); DVD±RW; Intel 11a/b/g w/Bluetooth added; Finger reader. Purch July 2005
If it is the ubiquitous 16 Volt, 4.5 Amp, (=) 72 Watt power brick that came with your machine, then the answer is No. Additionally, my brick (same as described) goes easily in my bag alongside my T41 and takes up very little space. I recommend just using what came with the machine as IBM *does* know how to engineer these things on a machine-by-machine basis. ... JD Hurst
davidspalding
You might find third party ac adapters, from APC or Belkin for example, but I dunno if they'd be smaller. (You were hoping for, say, one of the Powerbook hockey pucks?) And of course, YMMV as to performance or utility of a non-IBM power brick.
Your second alternative is ... bigger battery ... more batteries ... or a second charger at your destination, if applicable. (E.g., I usually have 2-3 adapters for a laptop, one for home one for office and one for bag.) There are a couple of venders who sell Ultrabay Slim batteries (used, refurbished, or NOS [new old stock]) from time to time, keep an eye peeled.
2668-75U T43, 2GB RAM, 2nd hand NMB kybd, Dock II, spare Mini-Dock, and spare Port Replicators. Wacom BT tablet. Ultrabay 2nd HDD.
2672-KBU X32, 1.5GB RAM, 7200 rpm TravelStar HDD.
underclocker
- moderator
FYI-
I've used an older X-series 56 watt AC adapter to power/charge a T40 without any problems (some say this can be an issue and it certainly takes longer to charge the battery).
The 56 watt adapter is smaller and lighter - maybe 10 ounces with cord. However. the 72 watt adapters seem to get smaller and lighter every year. They are nearly half the size they were initially. You may need to have a few together to notice, but the most recent T43 and R52 adapters are nearly as small and light as the 56 watt adapters.
Alternately, you could pick up a Chinese clone IBM adapter from eBay. They are the size of the newer 72 watt adapters and much lighter than any adapter I've seen from IBM - maybe 7 or 8 ounces. HOWEVER, I wouldn't EVER use one with my machines. They are definitely not UL Listed (as they say on their labels) and I'm certain they are dangerous. But many do sell on eBay.
Geez... I've gone in the opposite direction. I've been using one of the first-generation AC/DC adapters around the house. Almost twice the weight of the AC-only 72 watt adapter, but it seems to run slightly cooler, plus it has a power LED
Seriously, I'd stick with the genuine IBM adapters. The 72 watt ones really don't take up all that much space (or weight). Using an aftermarket supply, if you don't take the time to measure the voltage and verify the polarity of the plug or check the current ratings, can be dangerous.
I agree. The cost difference is minimal between the adapters. I would go with something made by IBM. They made your laptop, they know how to power it.
davidspalding
Power adapters ain't rocket science ... basically a transformer circuit converting AC to DC. My p/y 02K6746 outputs 16V at 4.5A -- you wouldn't want a third party adapter that deviates from that, or even an "older IBM" adapter that does, just because it says IBM on it.
What you pay for is the quality and any included warranty for your adapter, or your TP should something go wrong. Saving $20 on an adapter doesn't make sense when what you're getting is lower quality. But that's just my shopping rationale, I spend more for quality that I can rest on.
I think you might not mean "transformer". If you did, transformers have never been used in power bricks that I know of. So there is quite a bit of technology in those things to bring in grounded (two wire) high voltage AC, lower the voltage, convert it to DC, and isolate it so as not to endanger anyone. It is that overall technology that keeps me saying "use what IBM specifies" .davidspalding wrote:Power adapters ain't rocket science ... basically a transformer circuit converting AC to DC. <snip>
... JD Hurst
davidspalding
I was thinking in the most simplistic terms of this:
http://en.wikipedia.org/wiki/Power_supply
In my avionics days, we referred units which changed AC to DC or transferred DC as "transformers." True, it's one of several components in a modern AC adapter.
Things have changed (I think). The power supply modules in my 7704 or 7104 scopes are relatively huge. Yet the main transformer is very small (smaller than a TP power brick). So any transformer in a power brick will be real small.davidspalding wrote:<snip>In my avionics days, we referred units which changed AC to DC or transferred DC as "transformers." True, it's one of several components in a modern AC adapter.
... JD Hurst
underclocker
- moderator
I think I have a spare 72W AC adapter. I think that it is pretty small. The only smaller ones are the 56W for the older X. I advise against using the 56W for the X as you will "ruin" your battery. Undecharging it therby limiting the battery life and capacity. I think ver the years there were various 72W adapters so newer ones should be pretty small.
WTB: Smaller form Thinkpads like X60 etc series
by dwilsonfl » Tue Feb 07, 2017 8:04 pm » in Marketplace - Forum Members only - 1 Replies
- 347 Views
Last post by emtee3511
Wed Feb 08, 2017 11:00 pm
Source of reliable replacement power adapter T520
by lemonstar » Sat Mar 11, 2017 9:12 am » in ThinkPad T400/410/420 and T500/510/520 Series - 1 Replies
- 722 Views
Sat Mar 11, 2017 9:23 am
Power cord and adapter for T43 made for the UK
by Sudevan » Wed Jan 25, 2017 4:44 pm » in ThinkPad T4x Series - 6 Replies
- 1535 Views
Last post by Sudevan
Thu Jan 26, 2017 5:15 pm
Need help with my thinkpad 380xd, IR network and pcmcia driver issues
by MichaelWeaser » Thu Apr 27, 2017 12:36 pm » in ThinkPad Legacy Hardware - 0 Replies
- 570 Views
Last post by MichaelWeaser
