Thinkpad T60p - CPU Upgrade to Core 2 Duo T7600
mjk
#31 Post by mjk » Mon Jun 11, 2007 4:25 pm
I have just replaced the T2500 in my 2623-DDU with a T7600. Slightly to my surprise the system no runs noticeably cooler. (I suppose it could be due to better/more cooling paste.) Definitely a plus.
The other odd thing is that now Vista does not seem to want to let me update the Windows Experience Index. In fact, it refuses to show me the values at all. I still get the original overall value on the Welcome Center page, but the Performance Information and Tools page no longer bears any trace of the values.
jgrobertson
#32 Post by jgrobertson » Mon Jun 11, 2007 9:58 pm
I too noticed that it runs cooler, but I put in just a T7400. More horsepower with the same load, should put fewer demands on the processor. However, when asked it can do more.
Today, I shut the lid and it went into suspend. Then I put it in the brief case and when I got home the whole thing was HOT and the fan was running at maximum.
Apparently, the logic went into suspend but the CPU did not. When I got it going again (remove battery etc.) it came up with a message about problems. One of which was that I did not have the IBM/Lenovo power driver installed (but I did ). I instlale it again and we will see.
I hope the high heat did not cook my CPU or GPU chips. It is running but that does not mean the cips were not damaged by heat.
jgrobertson
mjk
#33 Post by mjk » Tue Jun 12, 2007 12:33 pm
Just for the record, Windows Experience Index calculation was being suppressed by TweakVI, nothing to do with the upgrade.
Dbruyere
#34 Post by Dbruyere » Wed Jun 13, 2007 12:30 am
I just upgraded my T60 from the T2400 to the T7200. I'm not 100 percent sure it's recognized properly. When I go into my device manager it shows two processors as:
Intel(R) Pentium(R) M CPU 000 @ 2.00GHz
I'm assuming that his is wrong, although my machine is running fine. When I run CPU-Z it shows the T7200 but the "Specification" is the same as above.
mjk
#35 Post by mjk » Wed Jun 13, 2007 1:58 am
Mine now shows 2 entries as follows:
Intel(R) Core(TM)2 CPU T7600 @ 2.33GHz
jgrobertson
#36 Post by jgrobertson » Wed Jun 13, 2007 8:35 am
Be sure you have updated the BIOS. There was some bug in the previous ones about the Core 3 Duo processors.
jgrobertson
Dbruyere
#37 Post by Dbruyere » Wed Jun 13, 2007 10:15 am
I do have the latest bios. I'm wondering if I should go back to the previous bios and then update again. Unfortunately, I'm not sure how to do that, and I can't find a direct download for the bios, just the bios update utility.
Dbruyere
#38 Post by Dbruyere » Wed Jun 13, 2007 11:50 am
I rolled back the driver and it didn't do anything for me. I updated the driver again, didn't help. Hmmmmmmmm.
Dbruyere
#39 Post by Dbruyere » Thu Jun 14, 2007 8:40 am
Does anybody have any suggestions on this?
Harryc
#40 Post by Harryc » Thu Jun 14, 2007 10:11 am
Dbruyere wrote: Intel(R) Pentium(R) M CPU 000 @ 2.00GHz
Try going into Thinkvantage Power Manager and make sure that the 'effect of settings' is at max CPU speed (highest) for the AC adapter profile. Save, exit, and now look at the device manager screen.
Dbruyere
#41 Post by Dbruyere » Fri Jun 22, 2007 8:06 pm
Thanks for the reply, I couldn't find this thread again to get back to you. I tried it, no change. In Sandra Lite, it shows that it's performance is great though, outperforming the benchmark for the same chip. I'm concerned about the temp, but I have no idea what the temp should hover around. It shows at 62 - 63 celcius.
ekzidua
Re: Thinkpad T60p - CPU Upgrade to Core 2 Duo T7600
#42 Post by ekzidua » Thu Oct 20, 2011 5:38 am
I have Thinkpad T60p rev. 3.
Can I upgrade It from Core Duo (Yonah) T2500 to Core 2 Duo (Merom) T7200 ?
Will there be problems ?
edit: HERE is not listed :?:
efrant
#43 Post by efrant » Thu Oct 20, 2011 7:09 am
ekzidua wrote:I have Thinkpad T60p rev. 3.
Yes you can upgrade, with no problems. I upgraded from a T2600 to a T7400 on a T60p.
T60p: T7400, 4GB, 15" UXGA Flexview, V5200, Seagate XT 500GB 7200rpm hybrid, DVD-RW, Atheros AGN, BT, Win7 Ultimate x64
X200s: SL9400, 4GB, WXGA+ LED, 160GB Intel X25-M G2, WiMax/WiFi Link 5350, MC8781 WWAN, BT, Win7 Ultimate x64
TuuS
#44 Post by TuuS » Fri Oct 21, 2011 10:51 pm
I have an extra core2 cpu if anyone wants it. It's pulled from a T61, 1.8Ghz Meron. I can lookup the number. I think it's the base level cpu for a T61, but should be a significant upgrade for a T60 series, and I'll trade it for anything of equal value that I can use.
#45 Post by dr_st » Sat Oct 22, 2011 12:13 am
It's not a significant upgrade and it is not even compatible with a T60.
