BIOS Update 2.09
Kyocera
#31 Post by Kyocera » Tue Mar 27, 2007 9:38 am
I upgraded to 2.11 and have had no problems (yet). And I am running Vista Business and XPpro.
tockki
#32 Post by tockki » Tue Mar 27, 2007 9:38 am
I don't know why but after I downloaded BIOS 2.11 my fan control kicked up a notch running at 3400 instead of its usual 2800... Does anyone know how to erase 2.11 and revert the system back to the 2.09 bios that I had before? I'm not a comp whiz so instructions would be nice ^^. Thanks...
Army Chief
#33 Post by Army Chief » Tue Mar 27, 2007 9:40 am
Trouble-free upgrade here to the 2007 series machine running Vista Business.
Chief
ThinkPad 750Cs | 760E | 770Z (x2) | A31 | T41 (2379 DJU) | T60 (2007 76U) | X220 (4286-CTO)
tockki
#34 Post by tockki » Tue Mar 27, 2007 9:44 am
I was fiddling around with the power settings by switching the fan control back to balance parameters and then back to maximum performance... that seemed to revert the fan control back to 2800~ down from that noisy constant 3400... Hopefully it stays that way...
jjesusfreak01
#35 Post by jjesusfreak01 » Tue Mar 27, 2007 6:52 pm
tockki wrote:I don't know why but after I downloaded BIOS 2.11 my fan control kicked up a notch running at 3400 instead of its usual 2800... Does anyone know how to erase 2.11 and revert the system back to the 2.09 bios that I had before? I'm not a comp whiz so instructions would be nice ^^. Thanks...
No need to erase, just reinstall the old one. Erasing a BIOS would be really bad, luckily, its not one of those things you can accidentally do. The installer may mention that you are using an older version, but it doesnt matter either way, it will let you do it.
Lenovo X230 Tablet CTO modded with 128GB SSD and 8GB of RAM
Lenovo T60 2637-UN6 (Retired)
o1sowise
#36 Post by o1sowise » Thu Mar 29, 2007 5:11 pm
I was sitting at my PC yesterday, typing while on a conf call, when the frackin PC just turned itself off. Right there in front of me. :shock:
Sooo, I downloaded and installed the new BIOS (2.11). I figured, how bad could it get. :(
This morning, I find the PC in stand-by mode. :cry:
Aaaaahhhhhhhhhhhhhhhhhhhhhh :evil:
o1sowise
#37 Post by o1sowise » Fri Mar 30, 2007 5:12 pm
I posted an update here. :!: :!: :!:
barrywohl
#38 Post by barrywohl » Sun Apr 01, 2007 10:25 am
"2.16 is the current BIOS version." Wrong. My bad. I was looking at Z series downloads.
First Thinkpad 755CX in 1995. First IBM: PC 1982 8088 w 64K RAM, dual floppy. Currently in use:
X230T with Win8Pro x64, i7, 500gb ssd; W700 WUXGA RAID 1 Blu-Ray W7Pro x64, occasionally a T61p with Win7Pro x64
brentpresley
#39 Post by brentpresley » Sun Apr 01, 2007 11:28 am
barrywohl wrote:2.16 is the current BIOS version.
I only see 2.11 on the website. Got a link?
Custom T60p
2.33GHz 4MB 667MHz Core 2 Duo
4GB PC2-5300 DDR SDRAM
Bluetooth / Atheros ABGN
200GB 7k200 7200RPM Hard Drive
8X DVD Multiburner
15" UXGA - ATI FireGL V5250 (256MB)
http://www.xcpus.com
barrywohl
#40 Post by barrywohl » Sun Apr 01, 2007 12:07 pm
My bad.
The current BIOS for the Z series is 2.16. Sorry for the bad information.
Barry
