just did. see pic. but I want them spread out. I think I can fit 3 - 4 ramsinksgunston wrote: and then, you want to put the ramsink underneath your keyboard?
Might have solved heat problems
I just try to set the Wireless power settings as you mentioned and WOW!! it's cooler. My APS temp went from 53C to 47-48C.berlin wrote:Update: I upgraded to 1.41
I turned off my Wireless WAN the heat went away.![]()
the following may help:
Power Management: 1 notch from lowest
Roaming Aggressiveness: same as above
Transmit Power: 50%
Wireless Mode: a, g
But berlin, how do you know that. I've tried changing the Power Management to lowest and it's hotter than 1 notch from lowest. And i've also try set it to maximum and it's hotter. I mean that PM 1 notch from lowest may give lowest temp but i haven't tried other levels.
And I have another question that when i shutdown my thinkpad and turn on again, i found that the heat went back because the Power Management option is automatically set back to it's default (lowest), so i have to change it manually. And it's even worse if it comes back from stand by or hibernation because all the wireless power settings are back to it's default value.
Does anyone have the same problem as mine?
X60s 1702-4ET
proaudioguy
- 61 Replies
- 4768 Views
Last post by Muse
Wed Jun 14, 2017 8:20 am
- 1013 Views
Last post by TuuS
Sat Jan 28, 2017 5:42 am
X61 Penryn Tweaks - Heat, WWAN, Airflow questions
by xsixt » Wed Mar 29, 2017 7:51 pm » in Thinkpad X6x Series incl. X6x Tablet - 5 Replies
- 992 Views
Last post by jaspen-meyer
Fri Mar 31, 2017 8:19 am
SOLVED IDTech IAQX10 QXGA panel
by x3o2 » Sun Jan 15, 2017 8:20 am » in Marketplace - Forum Members only - 8 Replies
- 1053 Views
Last post by x3o2
Mon Apr 03, 2017 12:09 pm
