XXS, XS and XL are still available for $4.99
$4.99 vyper XM sleeves at Booq website!
i'm not sure what you mean -- the only sizes that seem applicable seem to both be 12" (one, the XXS is 10.9"x8.6"x1.18", the other, the XS is 11.2"x9.1"x1.4"). which one did you get?spectre wrote:I believe I got the 13 or 14"
I should have gotten the smaller size (like the 12")
but sale is over... it was well worth it for under $20 but there are others out there that are better quality for about the non-sale price.
alfio
I got the one that the whole thread was based on, the XMlittle a wrote:i'm not sure what you mean -- the only sizes that seem applicable seem to both be 12" (one, the XXS is 10.9"x8.6"x1.18", the other, the XS is 11.2"x9.1"x1.4"). which one did you get?spectre wrote:I believe I got the 13 or 14"
alfio
It is designed for the 14" macbook.
X31 (2672-58u)
P M 1.7GHz, 1.5 Gig RAM, WinXP Pro
802.11a/b/g MiniPci II 73P4301
Thanks for the tip.
By the way, you can save an additional 10% by using coupon code: pbzone07 at the step before order confirmation (pulled from fatwallet)
I'm in for an XS and an XXS
Thinkpad X60s / 1.66 GHz Core Duo / 2 GB RAM / 100 GB 7,200 RPM HD/ Bluetooth / Atheros WiFi/ 8 cell + 4 cell slim / Win XP Home
johnson
Received the Vyper XS (two of them) and like Ken said, they are just a tad bigger than the X31 and it will slide around a little. I keep a microfiber towel in it to help this. If this somehow got damaged, id look into getting something else more form fitting for the X31.
T23 (2648-1U6) : PIII-M 1.13GHz : 512MB RAM : Hitachi 7K60 : ORiNOCO Gold Classic 802.11b : IBM 1394 CardBus
X31 (2673-Y13) : P-M 1.6GHz : 2GB Crucial PC2700 RAM : Hitachi 7K60 : 2915ABG : BT : Vyper XS Sleeve
The XS is a little big in the height department. I glued a few mousepads to the top and bottom of the inside to keep my X32 from bouncing around inside the case.little a wrote:what size did you order and what size should you have gotten? i just picked up an X31 and i'd like to get one of these for it but, not being able to see how stretchy it is, i'm not sure if the Vyper XXS is too small (or if the XS is too big).
