How to Fresh Install Win XP (Step-by-Step Guide)
anyone receiving T42/T42p, or T42s[Finger-Scanner] with SP2 pre-installed, and recovery CD's including SP2?
many other notebook makers are now advertising their laptops come with SP2 pre-installed (not sure if their Recovery CD comes with SP2, though).
i've heard that T42s with Finger Scanner definitely comes pre-installed with SP2.
the T42/T42p not so sure, due to old stock at hand in many re-sellers.
Re: Problems
I have the same problem. I was following the instruction but it did not burn into a CD nor did it make an imagefile somewhere.alero546 wrote:I have gone through each step of this process, however when i get to the part where it is suppoed to burn the contents to the cd, it doesn't. The cd is empty. Is there anything I am doing wrong?
EDITED: IGNORE THIS POST, i downloaded an old .dll file.
What am I doing wrong here????
what old .dll file do i have to download???
EDIT: Never mind. Being stupid I am I put the .dll file in the wrong folder... Now it is working..
* T60 * X61 * X41 * T500 * ThinkCentre A58 *
I just finished clean install my thinkpad w/ SP2.
I must say it seem to be running faster and smoother. I have few more drivers that I have update from IBM website but so far I am very pleased with the result.
Thanks again to UCI_MECH for the helpful hints.
BillMorrow
- *Senior* Admin
the 2373Q1U i have here has SP2 and so does the 2373N1U..w0qj wrote:anyone receiving T42/T42p, or T42s[Finger-Scanner] with SP2 pre-installed, and recovery CD's including SP2?
both of these are fingerprint reader models..
and are new.. well, ok, open box..
but both have the thai keyboard..
Bill Morrow, kept by parrots
& cockatoos
Sysop - forum.thinkpads.com
~~~Mark Twain~~~
~~~Mark Twain~~~
Reinstalling drivers after clean install.
Hi. Does anyone know what "SM Bus Controller" is? That is the only device left in Device Manager with a question mark. If I knew what it is, I could probably find the correct driver. I've reinstalled all other devices after creating a Win XP SP1a CD per UCI_MECH's instructions (worked perfectly by the way). Thanks.
Kevin
Kevin
krosenstein
Ah - why don't we all just make wild guesses? (The SpeedStep Applet is for pre-WinXP and not for WinXP which already includes support. The GV3 driver in the XPSPDSTP folder is a patch/update for pre-XPSP2. It should not be installed after SP2 is installed)
SMB = System Management Bus
The IBM Client Security Software provides a driver for it. The security chip is located on the SM Bus (and requires its own driver as well).
If you don't want to use IBM Embedded Security System then you don't need this.
You can find the latest software at http://www-307.ibm.com/pc/support/site. ... MIGR-46391. Previous versions provided the two drivers and Client Security Software separately. This version provides a single installer for them all.
krosenstein
my first post in this forum
question: my t42 came preinstalled with xp pro and sp1, so can i just follow the guide and skipping the steps regarding integration of sp1 into /i386? or do i still have to integrate it assuming that it is not integrated?
just want to do a clean install to speed up my black beauty, not interested in sp2 cos there's some issues with it and my school's IT people...
This link brings me to the Intel® Chipset Software Installation Utility, which isn't related to this discussion (as relevent to the ThinkPad).
Are you just trying to confuse the issue? If not then please provide relevant and pertinent information. Specifically, what purpose does the SMBus provide on a ThinkPad?
SMB is an industry standard, but each platform may provide its own drivers as needed.
The ThinkPad requires the SMB for controlling its security chip (so you don't need to do it through the BIOS). If you install the CSS software you'll see it includes the SMBus drivers required. Previously you would install the SMBus drivers, Atmel drivers, then client security applications.
Installing the latest Intel infs does not provide a driver for the SMBus.
Once again - if you don't use the Embedded Security System you don't need to worry about the SMBus driver.
Also - If you check the ThinkPad Driver Matrix (T40, T41 at http://www-307.ibm.com/pc/support/site. ... MIGR-46258, T42 at http://www-307.ibm.com/pc/support/site. ... MIGR-55386) and scroll down to the "Intel SpeedStep Applet" section you will see that NO DRIVER is needed for XP as it is included with the OS.
The SpeedStep Applet allows mobile-technology Intel CPUs to run at multiple speeds for optimal battery lifetime without sacrificing performance.
krosenstein
Funny, this mentions nothing about SMBus controller being necessary only for the ESS
http://www-307.ibm.com/pc/support/site. ... MIGR-46058
Again - What are you talking about?krosenstein wrote:Funny, this mentions nothing about SMBus controller being necessary only for the ESS
Yet again you are referring to Intel Chipset Support (inf installation utility). Yet again I will say this has nothing to do with SMBus.
Please - before posting the same irrelevant references please go back and reread my post. Please follow the link and read the details.
If you find something else on a ThinkPad that uses/requires SMBus please point it out. (My ThinkPad certainly doesn't have any other SMBus devices but others may be different)
If not please do not continue to post meaningless confusing links. Just for your convenience I'll repost the link to IBM Embedded Security Subsystem and Client Security Software: http://www-307.ibm.com/pc/support/site. ... MIGR-46391
This is my professional field. I worked for IBM for a while. I've done research into this. I've rebuilt my T41 many times. I've used the recovery partition, recovery cds, vanilla XP, slipstreamed XPSP2, and Linux. I've verified the drivers and devices each time. I've used the IBM ESS and CSS and I've done research on it.
In your first post you stated "[You] think. . ." indicating that you don't know. If you don't know then why continue? If you do know then why not provide evidence?
Can we be done with this, Please?
Step 9: Get the Product Key
Hi all,
I have a question regarding the "Step 9: Get the Product Key". After I created the XP cd (slipstreamed with SP2), I tried to install it in the vmware to ensure my CD is working fine. I followed the tips in Step9 to use the product key given in "unattend.txt" instead of the key given in the back-sticker during the installation. At end, I had my XP up and running under vmware, however, XP still prompts to active the system within 30 days.
My question are:
1. I used the "unattend.txt" file which comes along with my original ThinkPad (under C:\I386), not the one in the final CD I created. Am I correct?
2. Is the problem of using vmware? Does it mean I must install the CD on the real ThinkPad machine so that the XP can recognize the hardware and bypass the activation?
3. Does any one successfully use the product key in "unattend.txt" to install the XP and bypass the annoying activation prompts? How?
Thank you for all reply on these.
My question are:
ThinkPad T42 2373KA4
PM 735 1.7GHz, 1GB PC2700, 14.1" SXGA+, 60G (5,400rpm), RADEON 9600 64M, Intel 802.11b/g, 6-cell
Thanks for the quick reply.
I remembered I tried the key from the "unattend.txt" on the final slipstreamed SP2 CD and during the installation it said the key is invalid. That's why I used the original key take from the very orginal "unattend.txt" to try. Do you know why?kevinh wrote:I think you need to use the key on the final SP2 CD created with the slipstream process.
Well, I haven't actually tried installing the SP2 slipstreamed CD, only the SP1a CD (which worked fine).
I also created SP1a and SP2 CDs from another XP Pro CD (no service pack) that I have for my workstation. The key in UNATTEND.TXT is the same for the original CD and the new SP1a CD, but different for the new SP2 CD. Perhaps it's some funky SP2 security feature that prevents you from creating a slipstreamed SP2 CD with a valid key. Another reason to avoid SP2? Who knows.
Kevin
Kevin
There could be two reasons for this problem (the key from unattend.txt not bypass the activation):
1- Win XP is installed on a different machine, i.e. not the same ThinkPad that it came with.
2- The key product form "unattend.txt" in the i386 folder would bypass the activation only for SP1 (or what ever service pack your machine is originally came with).
Hope this helps.
Hope this helps.
no the key in the unattend.txt file will bypass activation for both SP1 and SP2.
To make it simpler you could make a WINNT.SIF file. From the older threads, I found this site. Oh yea, you need the original key from the unattend.txt file in your I386 folder. It's the bigger of the two unattend.txt files.
http://unattended.msfn.org/
Example
Example
[Data]
AutoPartition=0
MsDosInitiated="0"
UnattendedInstall="Yes"
[Unattended]
UnattendMode=FullUnattended
OemSkipEula=Yes
OemPreinstall=Yes
TargetPath=\WINDOWS
FileSystem=*
UnattendSwitch="yes"
WaitForReboot="No"
DriverSigningPolicy=Ignore
OemPnPDriversPath="drivers\001_INF;drivers\002_RAID"
KeyboardLayout="United Kingdom"
[GuiUnattended]
AdminPassword=*
EncryptedAdminPassword=No
OEMSkipRegional=1
TimeZone=85
OemSkipWelcome=1
[UserData]
ProductKey=XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
FullName="Aaron"
OrgName="Home"
ComputerName=COMPUTER1
T42 2373-M1U 1.8GHz / 1G / 60G / IBM a/b/g II
Yes, I indeed used the key given in the original unattend.txt. But no luck. I can pass the installation by using the key but the activation prompt was still there.ssdaytona wrote:no the key in the unattend.txt file will bypass activation for both SP1 and SP2.
The exception was I installed the slipstreamed XP (with SP2) in vmware rather than on the real T42 machine. As mentioned above, maybe that's the problem. I am not so sure.
- 566 Views
Last post by KingBubba
Sat May 13, 2017 11:26 am
SOLD: T430s FHD i5, 8Gb + fresh Ultrabay battery + DVDRW
by harryK » Wed Apr 26, 2017 10:41 am » in Marketplace - Forum Members only - 3 Replies
- 380 Views
Last post by vaggs
Thu Apr 27, 2017 3:34 am
AMD Catalyst Install Manager will not install video card driver on T60
by psun9999 » Mon Mar 13, 2017 1:33 am » in ThinkPad T6x Series - 1 Replies
- 1458 Views
Last post by zoltan87
Mon Mar 13, 2017 5:55 pm
- 10 Replies
- 3654 Views
Sun Jan 01, 2017 8:22 pm
