How to Fresh Install Win XP (Step-by-Step Guide)
ennma
#301 Post by ennma » Fri Sep 21, 2007 1:09 pm
I don't know about copyrights though, because I don't believe I seen any disclaimer to the documents, but since you mentioned it I think I would rather not post on the net, I don't want to be sued.
ennma
T60P-200784U
graywolf
#302 Post by graywolf » Sun Jun 15, 2008 4:21 pm
This tread has a lot of old information in it. Let's see if we can not come up with something a bit simpler:
1. Backup My Documents (if you want to save your personal data).
2. Find your old Windows XP Pro CD.
3. Download N-Lite (freeware).
4. Download the latest service pack from microsoft (currnently SP3)
5. Use N-Light to copy your CD to the hard drive.
6. Use N-Light to slipstream the service pack into the copy.
6a. N-Lite has a lot of other options you may want to investigate.
7. Use N-Lite to burn a new bootable CD of the slipstreamed copy of Windows.
8. Boot up the CD and do a new install.
9. Install Thinkpad drivers from Lenovo's site.*
10. Install desired software (This is a good time to upgrade).
11. Restore My Documents if you backed it up.
I just did this for a HD upgrade on my X24 this weekend, so know it works. It would have been simpler if I had all the software in one place before I started. It has been the quickest full install, I have ever done (even figuring the N-Lite learning curve in).
*NOTE: I discovered that the only drivers I actually needed from Lenovo were the PowerManagement Driver, and the Display Driver. The others seem to be optional as Windows has something that works for everything else.
Marin85
#303 Post by Marin85 » Sun Jun 15, 2008 4:52 pm
Do you think it makes difference if you install Lenovo drivers after installing XP or just integrate them in the XP install CD using nLite?
Marin
califas
Re: How to Fresh Install Win XP (Step-by-Step Guide)
#304 Post by califas » Tue May 19, 2009 7:29 pm
Has anyone used a Dell XP Pro reinstallation disc instead? It is almost identical to a normal XP disc. I suppose I could extract the i386 folder from the Dell disc and use this guide to make a disc but if I can avoid doing this that would be great.
deepti123
#305 Post by deepti123 » Fri May 06, 2011 2:50 am
awesome guide ....
