T61 / 14" WS
yus9
#151 Post by yus9 » Wed May 09, 2007 9:40 pm
bontistic wrote:Not sure about the SD though. My guess would be the PC Card Slot & Media Card Slot [add $0.00] but it is definitely not the Smart Card slot.
You are correct, and Thanks!
The PC Magazine review provides the following info...
"With the T61, you now have options for four different card slots:
an ExpressCard 34 slot,
a PC Card slot,
a SmartCard reader,
or an SD card reader.
You can integrate any of these slots in tandem; my configuration came with both an ExpressCard and SD card reader."
The media card reader is the SD card reader.
BTW.. Seems like they are offering three modules.
The PC Card slot is standard & you can choose one of the three others.
kamaleon
#152 Post by kamaleon » Thu May 10, 2007 2:34 am
This is weird, there must be a catch somewhere as the configuration page on the lenovo shop only allows one to choose between:
System expansion slots
PC Card Slot & Express Card Slot
PC Card Slot & Media Card Slot [$0.00]
PC Card Slot & Smart Card Slot [add $25.00]
T60p 15" UXGA
X61t 1.8Ghz SXGA+ AIFF
ryengineer
#153 Post by ryengineer » Thu May 10, 2007 3:17 am
These are only preliminary startup models, models with more options will be available soon.
Media Card Slot is "memory card reader" slot in other words.
yus9
#154 Post by yus9 » Tue May 22, 2007 10:47 am
ryengineer wrote:These are only preliminary startup models, models with more options will be available soon.
Built-in cameras are now available as an option.
(May 21, 2007)
