Hi everyone! This is my first post here, as I was directed to this great site from someone at IBM. She said that you folks might be able to answer my questions, so here I go.
A while back, I had a minor spill at my office and some liquid got onto the back of my X40. There didn't seem to be any damage, and I dried it off as quickly as possible. But now there appears to be some sort of copper oxidation on the pins in the back of the laptop. Everything works fine, except when I plug it into the docking station. Then it freezes up or doesn't recognize the fact that it is docked.
The advice I did receive was to clean the pins with a Q-Tip and alcohol. Do you think this will take care of the oxidation? Or should I be looking for a new motherboard?
Any information you can provide would be most helpful.
Thanks so much!
-Alex
Corrosion on the docking pins
BillMorrow
- *Senior* Admin
hi and welcome to the club..
those pins are VERY small and fragile..
also i think that plug is soldered to the system board so it is a very costly repair job and its NOT under warranty..
the Q-tip and alcohol might work if there is only surface corrosion..
but i think those pins are gold plated and if the gold plating is gone...
Bill Morrow, kept by parrots
& cockatoos
Sysop - forum.thinkpads.com
~~~Mark Twain~~~
~~~Mark Twain~~~
FOUND: Docking station for the T410
by Whitieiii » Sun Jan 22, 2017 7:23 am » in Marketplace - Forum Members only - 1 Replies
- 236 Views
Last post by Whitieiii
Sun Jan 22, 2017 5:15 pm
FS: docking station for t440p/t440/t440s/ect
by Whitieiii » Mon Jan 23, 2017 11:44 pm » in Marketplace - Forum Members only - 3 Replies
- 474 Views
Thu Feb 02, 2017 9:32 pm
- 14 Replies
- 1871 Views
Last post by jcvjcvjcvjcv
Fri Mar 31, 2017 3:36 pm
Waking up T460 on docking station problem.
by Darrell456 » Sat Mar 04, 2017 5:35 pm » in ThinkPad T430/T530 and later Series - 0 Replies
- 1031 Views
Last post by Darrell456
