Upgrade to Vista or Not?
jdhurst
#31 Post by jdhurst » Mon Apr 09, 2007 11:00 am
Pirx wrote:<snip>
I have a suspicion that there will be no services packs anymore, as updates will be rolled out more often through Microsoft Update.
Hard to say, and I do not know about Vista. However, Microsoft has stated that Service Pack 3 for XP will be available in 2009. SP2 was a re-write of XP so who knows what SP3 will bring.
... JDH
#32 Post by pianowizard » Mon Apr 09, 2007 11:03 am
jdhurst wrote:Microsoft has stated that Service Pack 3 for XP will be available in 2009.
And that means Microsoft will continue to provide updates for XP for at least two more years. That's great!
Pirx
#33 Post by Pirx » Mon Apr 09, 2007 12:33 pm
jdhurst wrote:
Pirx wrote:<snip>
... JDH
Arrgh, I meant - no SPs for Vista. My bad, I wasn't clear enough.
As to the SP3 for XP - highly doubt they'll do a rewrite, given that 2009 will be 2 years since the release of Vista and next-gen OS in works. BTW, could you provide the link to this MS statement?
Pirx
#34 Post by Pirx » Mon Apr 09, 2007 12:34 pm
Isn't that what they always do - provide updates for older systems? I mean - they still release patches for Windows 2000, given that it's been 7 years already :)
jdhurst
#35 Post by jdhurst » Mon Apr 09, 2007 12:58 pm
I was clear about your question as it pertained to Vista, but I don't know about andy Vista Service Pack strategy from Microsoft.
I read about SP3 for XP in one of the many articles about Vista. It was meant to allay fears about being forced into Vista. I don't have a link, however, as the articles are long gone from any history in my browser.
... JDH
gt5l
I did
#36 Post by gt5l » Mon Apr 09, 2007 1:46 pm
The first thing I did with my T60p out of the box was to insert the Vista DVD and boot the computer, I chose new install which formatted the hard drive and installed Vista Ultimate. After that I downloaded Lenovo's update utility which found and installed all the necessary drivers and Lenovo based programs (Access, protection, backup ... etc). Then I noticed a weak signal strength , I went to Intel’s website and downloaded the most recent driver (Still not showing in Lenovo’s website) which resolved the signal strength issue. Then I proceeded to install MS Office 2007, Endnote X, JMP 6, KasperSky AV, Napster, PocketMirror (for palm device) and few other programs and never looked back. I noticed (with other computers I worked with) that a clean install is always the best way to go for stability, and the Lenovo system update utility makes it easy to update drivers so you don’t have to search for them.
IBM T60p 2613HQU- 2.33 GHz T7600, 2GB RAM, 100GB 7200 HD, 14" LCD SXGA+ TFT, 256MB ATI FireGL V5250, CDRW/DVDRW
Intel 802.11abg wireless, Fingerprint, BT, and Vista Ult.
#1 Laptop
deeastman
#37 Post by deeastman » Mon Apr 09, 2007 5:24 pm
Pirx wrote: As to the SP3 for XP - highly doubt they'll do a rewrite, given that 2009 will be 2 years since the release of Vista and next-gen OS in works. BTW, could you provide the link to this MS statement?
Take a look here in the third column labeled "Next Update and Estimated Date of Availability":
http://www.microsoft.com/windows/lifecy ... packs.mspx
Don
arni
#38 Post by arni » Tue Apr 10, 2007 1:27 am
I have used Vista on my TP for the last 4 month. Had many problems regarding the hardware at first but after Lenovo released their Vista drivers it was way better.
Now after 2 month since consumer release things are stabilizing and if you only use latest software i would recommend moving to Vista.
I'm using it for ensuring my programms run well on Vista. But for now i have reverted back to XP as there are still some annoyances which all add up and slow down my productivity.
Especially i had bad experiences with Adobe, Macromedia and some other special software which had some glitches here and there. But most important i couldn't successfully use my Cisco vpn with Vista. Even that they are now on RC builds but there are still issues with it.
Just my 2 cents.
