Netstumbler and Vista
mk1 black limited
I know, it's not supposed to work in Vista. Yet people have made it work on other laptops with Vista, so - anyone have it working in Vista on a Thinkpad?
T60p
mk1 black limited
This forum (and probably the whole world) remains overwhelmlingly NOT vista at this point. Of course that will change but that is another topic.
So I am not surprised you haven't found a reply. Did you try Compatibility mode to install? That sometimes (not always) worked with XP when it was new six years ago.
... JDH
... JDH
mk1 black limited
stephenyeong
earl@greerdata.com
Netstumbler problems
I can get Netstumbler to run on a t60 with Vista Business, it sees the Intel 3945abg adapter in the devices list, but shows "No AP's active" at the bottom of the screen.
I kind of think I saw this on my older t42 running Win XP, and was able to address it by not letting Thinkvantage Access Connections have control over the wireless connections.
In XP there was a checkbox on the wireless networks tab of the wireless network connection properties titled "Use windows to configure my wireless network settings". If I remember correctly (not really a 100% safe bet) I used to check this box, which kind of disabled Thinkvantage Access Connections, and allow NetStumbler to see the WLAN traffic.
I cannot seem to find a similar option in XP, so I cannot check to see if that will work. I am considering unloading Access Connections but hate to do it as I really like the applet.
If I take the plunge Ill post the results.
Earl
Earl
T60 2623DAU
Vista Business Edition
Closed: Vista Business recovery discs for X61t
by fultontech » Sat Mar 18, 2017 9:36 pm » in Marketplace - Forum Members only - 0 Replies
- 203 Views
Last post by fultontech
Microsoft Provides New Security Update For XP, Vista
by BillP » Sat May 13, 2017 2:14 pm » in Windows OS (Versions prior to Windows 7) - 3 Replies
- 514 Views
Last post by shawross
Mon May 15, 2017 4:56 am
Can Windows Vista be installed on an IBM Thinkpad R50e?
by ThinkDan2004 » Sat Jun 03, 2017 3:54 pm » in ThinkPad R, A, G and Z Series - 14 Replies
- 579 Views
Last post by ThinkDan2004
Tue Jun 13, 2017 3:06 pm
- 23 Replies
- 1314 Views
Tue May 02, 2017 8:18 am
