Ubuntu Feisty packages for ThinkPads
Alexander Heß
Is it just me, or is the xorg-driver-fglrx_8.36.5-1_i386.deb corrupted?
When I install using dpkg I get following output:
When I extract the deb and try to extract the data.tar.gz I get:
Could you please fix this, if it's not a problem on my side?
(Reading database ... 133812 files and directories currently installed.)
Preparing to replace xorg-driver-fglrx 7.1.0-8.34.8+2.6.20.5-16.28 (using xorg-driver-fglrx_8.36.5-1_i386.deb) ...
Unpacking replacement xorg-driver-fglrx ...
dpkg-deb: subprocess paste killed by signal (Broken pipe)
dpkg: error processing xorg-driver-fglrx_8.36.5-1_i.386.deb (--install):
short read in buffer_copy (backend dpkg-deb during `./usr/lib/xorg/modules/drivers/fglrx_drv.so')
Errors were encountered while processing:
gzip: stdin: invalid compressed data--format violated
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
thanks for notifying
seems like the root of the problem comes from googlepages, which for some reason corrupted some files over time.
Just in case some other files are corrupted, I re-uploaded all of them.
Let me know if there is any other problems
Alexander Heß wrote:Is it just me, or is the xorg-driver-fglrx_8.36.5-1_i386.deb corrupted?
When I extract the deb and try to extract the data.tar.gz I get:Code: Select all
(Reading database ... 133812 files and directories currently installed.) Preparing to replace xorg-driver-fglrx 7.1.0-8.34.8+2.6.20.5-16.28 (using xorg-driver-fglrx_8.36.5-1_i386.deb) ... Unpacking replacement xorg-driver-fglrx ... dpkg-deb: subprocess paste killed by signal (Broken pipe) dpkg: error processing xorg-driver-fglrx_8.36.5-1_i.386.deb (--install): short read in buffer_copy (backend dpkg-deb during `./usr/lib/xorg/modules/drivers/fglrx_drv.so') Errors were encountered while processing: xorg-driver-fglrx_8.36.5-1_i386.debCould you please fix this, if it's not a problem on my side?Code: Select all
gzip: stdin: invalid compressed data--format violated tar: Unexpected EOF in archive tar: Unexpected EOF in archive tar: Error is not recoverable: exiting now
Alexander Heß
Alexander Heß
I don't mind sending it to you, but it's a few hundred megs, I don't know where to host it.
If you want to compile your own modules, normally you only need the header files, even you need the source you can just install the original unpatched -15 source.
Hope it helps.
Hope it helps.
Alexander Heß wrote:@axiom:
Any chance of getting the sources of your custom-kernel? I need vmware-player and copying the 2.6.20-15-kernelmodules doesn't work...
The Newest GPD Pocket with Z8750 CPU Windows 10 System or Ubuntu 16.04
by laozhu » Thu Jan 12, 2017 5:02 am » in Off-Topic Stuff - 12 Replies
- 1435 Views
Last post by QWERTY Andreas
Wed Feb 15, 2017 3:52 am
How to improve audio on a Thinkpad T530 under Ubuntu?
by wrybread » Sun Mar 05, 2017 2:14 am » in Linux Questions - 1 Replies
- 1193 Views
Last post by wrybread
Fri Apr 07, 2017 5:38 pm
What operatings systems are y'all using on your vintage ThinkPads?
by goldeneagle » Thu Jan 05, 2017 4:00 pm » in ThinkPad Legacy Hardware - 15 Replies
- 2407 Views
Last post by w0qj
Sat Mar 11, 2017 9:12 am
What is a good Linux OS for legacy thinkpads?
by Blender » Sat Jan 07, 2017 1:47 am » in ThinkPad Legacy Hardware - 26 Replies
- 2628 Views
Last post by Farro
Thu Jan 19, 2017 11:55 am
Users browsing this forum: axur-delmeria and 0 guests
