T61 + R61 are out!
MCheiron
#121 Post by MCheiron » Sun Apr 29, 2007 5:21 pm
ryengineer wrote:
MCheiron wrote:In the IBM pdf, there is no word about blue ray as an option in July.....
In the pdf doc they don't, however on this notebookreview link the guy does talk about the blue-ray option at the very end of the his article.
By accident I found another article that supports my fear that there won't be a blu ray option for the T61. According to Gizmodo there will be only blu ray available for the R61 in July. This was the same for DVD burner with the T40 and R40.
I just hope, I will be proven wrong.
nxman
#122 Post by nxman » Sun Apr 29, 2007 7:18 pm
I see a webcam in the T61 picture however its not mentioned in the specs?
Growly
#123 Post by Growly » Sun Apr 29, 2007 11:53 pm
Don't get me wrong, I won't disagree with anything anyone has said (much wisdom).
I just feel like I've missed out, and because I am but a petulent child, I will whinge and moan about it.
My biggest moan is that I was less than a month from buying the 15" IPS UXGA T60p before it was withdrawn, then before I resigned to having a 1400x1050 one the IPS models were withdrawn - and after that heart break, I went to get a 15" 4:3 model and they were all gone too! What's worse, when i finally decided that I'd better hurry up and get a 4:3 while I still can (less than a month later), Lenovo here told me sorry, no can do.
Absolutely, my dream is in tatters.
So I wll now spend countless hours trolling the internet for second hand ones.
I'm also keen to see what people think of this model when it comes out :D
PS. Sighh.
In my loving care: X201, T410, W500, T61p, T60p, T60, T43p, T43p, T43, T43
Seeking: X301, W520 w/ i7 2760XM & modem, W510 w/ i7 920XM, X220
Sent to other homes: W510 x4, W500, X300, X201 x2, X201t, X61t, X61, T61 x2, T60 x5, T400 x2, T510
Sent back to Lenovo: W520
RIP: T23, T21, T21, 380ED
seeplus
#124 Post by seeplus » Mon Apr 30, 2007 12:18 am
Growly: Take a look at this link (15" T60 IPS Core Duo New In Box)
T60 On ebay
- Chris
2613-CTO
ryengineer
#125 Post by ryengineer » Mon Apr 30, 2007 12:41 am
seeplus wrote:(sorry for the long url..)
You can use http://tinyurl.com/
darrenf
#126 Post by darrenf » Mon Apr 30, 2007 12:46 am
Or put text inside the URL tags and change the opening tag from:
URL
to
URL=http://link.here
(in brackets of course).
-darren
Dead1nside
#127 Post by Dead1nside » Mon Apr 30, 2007 11:38 am
What is the likelihood of a turn around on certain design features on the T61? For instance the mic/headphone port placement? Presumably, that would require a redesign of certain areas of the casing, perhaps not the motherboard, but internal chassis redesign also?
Presumably, these parts must be being manufactured currently in order to build up supplies for the May launch?
Am I just being too hopeful?
Growly
#128 Post by Growly » Mon Apr 30, 2007 7:14 pm
seeplus wrote:Growly: Take a look at this link (15" T60 IPS Core Duo New In Box)
http://cgi.ebay.com/TP-T60-NB-CD-2-0-1G ... dZViewItem
Thanks for the link seeplus, but they explicitly declare that they do not accept international orders (I'm in New Zealand) :( Cheers again though.
FRiC
#129 Post by FRiC » Tue May 01, 2007 3:34 am
Rose wrote:I also would like to know if the new 4-cell battery is equal in Ah/power to the old 6-cell. Why is this changed? Did the redesign of the chassis require smaller batteries? Or is there some new kind of cell composition with higher voltage/current?
I'm wondering about this too. The Z61t series have a standard 4-cell battery. Could the T61 be using this battery? But the Z61t's extended battery is 7-cell.
I'm looking to buy a T60 and I'm a little surprised to find out that ATI graphics use more battery than integrated graphics. In my old Pentium M laptops, having ATI actually means longer battery life.
X230 | i5-3210M | 8GB | 500GB | WWAN
seeplus
#130 Post by seeplus » Tue May 01, 2007 4:01 am
Graphics Dorks/Professionals:
I did some digging around for information on the discrete graphics in the T61 that was spec'd at the beginning of this thread (the nvidia Quadro NVS 140M.) Thought I'd share.
From what I could find, seems that it's based on the Nvidia G36 (which is also the hardware behind the coming Nvidia Go 8400/8600.) This should mean that the T61p variants will have some sort of stepped up Quadro NVS solution also based on the G36.
(= Good)
- Chris
2613-CTO
Dead1nside
#131 Post by Dead1nside » Tue May 01, 2007 8:22 am
From what I gather, as nvidia does not have an actual listing for this particular chip, it is 8400 class, perhaps a bit more. But I wouldn't call it mid-range (8600).
I'm hoping that there will be a plain non-Quadro 8600 available, as well as a high-end quadro at least on the T61p.
Users browsing this forum: karotlopj and 31 guests
