Dead1nside wrote:
Maybe I'll move to HP.
I use a laptop every day for my work, I haul it around with me whereever I go. I hate dealing with multiple machines to do my work, so really my laptop has to be a desktop replacement.
This is the reason I bought the Z61p (I like WUXGA), instead of a T60p. I was dissapointed when I opened up the box and found a laptop that look relatively cheap when compared to a T60p. The frame is noticably thicker (and I found out a cheaper material -- ABS), and it didn't have the rubberized paint that I think makes a TP a TP.
However, after using the Z61p for a bit and comparing it to other laptops I have owned/used. The ThinkPad line is still the choice for me. As I mentioned before, the Z61p uses a cheaper plastic for the cases, and definatly has a similar look as to what is shown in those pictures of the T61. But, it is sturdy -- I have been really impressed with it -- I have had no issues with the system -- and even after four months of pretty heavy wear It still looks new.
I can't say this is the same for other laptops I have recently used/own:
Mac Book Pro - New machine -- I like it, but for numerous personal preferences I will stick with the ThinkPad
5 HP nc5000 - Just over a year, and 2 had their LCD backlights replaced under warrenty, another LCD backlight died recently, but we are not getting it fixed as it is out of warrenty, and the machine has other problems.
Compaq Presario V2000
Held it for about five minutes by the right corner for the base for about 10 minutes -- the flex damaged the trackpad and it never worked correctly again -- I owned this one for just over a year.
Gateway Tablet -- I know three people who use this laptop -- all of them have had a stress fracture appear on the LCD side of the hinge that connects it to a base.
So, overall I am not really sure there is a price effective equal to the ThinkPads. I mean, the sad truth seems to be that even if the quality of things have gone down to the ThinkPads, they are still seem better then the competition.
What do people around here recommend as a replacement, that acutally surpass the Thinkpads quality?
