aoitenshi
#1081 Post by aoitenshi » Sun Aug 03, 2014 5:53 am
alesanremo wrote:Excuse me for the question, but reading all the posts about this matter I'll get a little bit confused, so I ask to the experts if this ssd hd works fine and if needs other hardware to run into my x41 or I've just to plug it and play?
http://www.ebay.it/itm/KingSpec-1-8-IDE ... 70a&_uhb=1
Alessandro M. Sanremo (ITALY)
My suggestion would be using an adapter like this one :
http://www.ebay.it/itm/Adattatore-mSATA ... 9a2&_uhb=1
and a msata ssd like this one :
http://www.ebay.it/itm/ADATA-Premier-Pr ... bb0&_uhb=1
so if you need to do 'secure erase', you can take the msata ssd from msata to ide adapter, into another adapter like these :
http://www.ebay.it/itm/New-50mm-mSATA-S ... 2fa&_uhb=1
or
http://www.ebay.it/itm/Mini-SATA-mSATA- ... em43c3827e
and perform secure erase on another laptop / pc with sata connector ..
a friend of mine in indonesia already done this and the X41 is now running on Linux
Hello world.
alesanremo
#1082 Post by alesanremo » Tue Aug 05, 2014 2:06 am
Thanks in advance for your answer; Do you think that the kingspec 1.8 ide is not reliable for the x41?
There are no room problems in fitting into the x41 sdd and adapter?
And finally, i haven't understood what is the "secure erase"... :(
Bye
edivad
#1083 Post by edivad » Thu Aug 14, 2014 11:36 am
Ciao Alessandro ;),
... there are different solution for use ssd HD on a X40 X41, in my X40 I'm using a 3.3v 1.8" pata to mSata adapter, you will find this here and a Crucial M4 64GB "CT064M4SSD3", you can search it on amazon.it... or ebay.
For my X40 everything work well without any problems, I'm very satisfied about this upgrade, in the X41 system you should check the compatibility (disk not recognized from the bios),but as I remember Crucial M4 SSD are compatible also with X41 models, you can find in this forum some experience with this setup.
Ciao
Davide
Now
X40 ssd - T43 -X200s AFFS mod - T440 i7
fedeb777
#1084 Post by fedeb777 » Tue Nov 11, 2014 11:22 am
Hi guys
I need information about HD chanhe in X41
What ssd/pata recommendet to install in my x41?
Ciao
c0rv00
#1085 Post by c0rv00 » Thu Nov 19, 2015 12:06 pm
fedeb777 wrote:Hi guys
Ciao
i installed this:http://www.ebay.it/itm/KingSpec-1-8-IDE ... 70a&_uhb=1
it work fine , to cancel error mex on the boot "Error 2012" you need to change BIOS
byebye
