poweragemk
#211 Post by poweragemk » Mon Dec 10, 2007 3:36 am
Anyone tried this with one of these? I didn't see it mentioned, apologies if I missed it.
Transcend TS8GIFD18
http://www.newegg.com/Product/Product.a ... 6820208063
Current, past, and supported ThinkPads:
[A31p][X40][X41][X41t][X60s][X60t][X61s][X61t][R61i][T21][T40][T43][T60][T61p]
creed
#212 Post by creed » Mon Dec 10, 2007 8:54 am
My boot up time, from the grub menu to login screen, is about 30 seconds. This is a lot faster than before, which was at least a minute and more if I remember.
istel
#213 Post by istel » Mon Dec 10, 2007 9:24 am
I'm sure the 1.8 ssd from transcend has not been covered.
Maybe you can be the first one to try it, the connector looks good to me.
Creed,
Thanks for the heads up, though nowhere near as Slade's 1 second... Still wondering how it's achieved
seneca
#214 Post by seneca » Mon Dec 10, 2007 1:37 pm
Hey guys, an update...
I've now installed openSUSE 10.3 and I've used it for two days.
Two partitions (one on each of the cards) as raid0 /, 150mb /boot and the rest as dm_crypt/lvm /home.
No data corruption yet :)
It seems that openSUSE (2.6.22.13-0.3-default) doesn't have the same problem as ubuntu gutsy, but it has one caveat. One harddrive is running pio6.... :(
So my raid0 is worthless when one cf is running pio. The whole system is lagging when I copy files, both to /home and /.
hdparm -I /dev/sdb
sdb:
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 (?)
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
Write cache
* CFA feature set
* CFA advanced modes: pio5 *pio6
sda:
DMA: mdma0 mdma1 mdma2 udma0 *udma1 udma2 udma3 udma4
Commands/features:
Enabled Supported:
Write cache
* CFA feature set
hdparm -t /dev/sda
/dev/sdb:
Timing buffered disk reads: 10 MB in 3.01 seconds = 3.32 MB/sec
seneca@odysseus:~> sudo /sbin/hdparm -t /dev/sda
/dev/sda:
Timing buffered disk reads: 62 MB in 3.02 seconds = 20.53 MB/sec
Having a drive running udma1 versus pio6 makes a whole lot of difference.
Please post your benchmarks to compare!
Thinkpad x220 Li7-2620M 8gb/80gb mSATA intel 320SSD/160gb Intel 330 (didn't fit, had to remove the aluminium shell)
Linux Mint 17
DVormann
#215 Post by DVormann » Mon Dec 10, 2007 1:37 pm
poweragemk wrote:Anyone tried this with one of these? I didn't see it mentioned, apologies if I missed it.
Transcend TS8GIFD18
It was covered on page two:
DVormann wrote:
XIII wrote:Anybody tried this SSD <http://www.newegg.com/Product/Product.a ... 6820208063>
Could you please provide feedback? I really want to research more about it before purchasing.
Thanks,
That drive does not exceed mwDMA2 (16.6 MB/s). After reading that I decided not to buy one.
Random write is bound to be bad just like other Transcend products. If you are happy with mwDMA2 and only a single drive in X40 you can try TS8GIFD18. I would not.
With X41 another detail needs to be considered: Most SATA-PATA bridges support UDMA and PIO but not mwDMA. I do not know which bridge is built into X41. So I do not know if X41 supports mwDMA at all. If not the disk has to run in PIO mode.
mazzinia
#216 Post by mazzinia » Mon Dec 10, 2007 7:26 pm
http://www.dcviews.com/press/Delkin-16GB.htm
New toy... supporting UDMA natively, and 20 years of warranty
X31 2672-C6J
IBM 9401-P03 (As/400 "portable")
A crowd of assembled desktops, a jungle of cables... and a Palm m515
AvalonXIII
#217 Post by AvalonXIII » Mon Dec 10, 2007 9:21 pm
Transcend TS8GIFD18
DVormann wrote:That drive does not exceed mwDMA2 (16.6 MB/s). After reading that I decided not to buy one.
yeah, I tried that drive as well. It was painfully slow. NOw, I do not know what running in PIO mode means, but when I replace the original HDD with that, it takes over 5 minutes to start up. However, once windows boot, the time it takes to open applications is significantly faster than before. Battery life is the same, but there is no noise. Overall, not worth the money and I returned it
DVormann
#218 Post by DVormann » Tue Dec 11, 2007 3:49 am
mazzinia wrote:http://www.dcviews.com/press/Delkin-16GB.htm
Asked Delkin technical support four weeks ago if the card identifies as 'removeable drive' or 'fixed disk' in true IDE mode. Did not receive an answer.
Just like Microdia: Asking the same question regarding this 32 GB card. Two weeks passed. No answer.
aboveliquidice
#219 Post by aboveliquidice » Tue Dec 11, 2007 12:35 pm
Can this process be used to convert any removable drive to a fixed disk???
link
cchsiao
#220 Post by cchsiao » Sat Dec 15, 2007 2:26 pm
I wanna contribute my own experience with Super Talent's SSD.
I got a Super Talent FHD32GC18M and it doesn't work on my X41t. Not only my X41t cannot see this SSD, my T42p also doesn't see it, no matter where I put it (main HDD bay or ultrabay). I am almost sure that this SSD is not defect since somehow one can see this drive under T60 (but not before login into VISTA). So... no hope on a real SSD on X41/t.
Originally I think even my X41t might not work, it should work fine on my T42p which eats all the IDE HDD. However, it is not the case at all. So... the only possible SDD which might work on X41 will be the PQI one. However, I don't dare to try this again.
xosh
Q. Continuous Read/Write?
#221 Post by xosh » Sun Dec 23, 2007 1:53 am
Hi, I am testing Delkin 16GB UDMA CF with Addonics CF-to-IDE converter on my Thinkpad X41 Tablet.
Fortunately, I was able to install Windows XP Tablet 2005 without any problem. :) (I just formatted the disk NTFS, and installed Windows XP. I was worried about the "removable/fixed" problem - Even though it was shown as a "removable" device, after formatting the disk NTFS, I was able to boot from the CF card.)
The problem I'm having is after the booting, the HDD Read/Write light doesn't go off. I don't know what process is continuously writing (or reading) the disk, but it doesn't stop! :evil: (I waited for more than 20 mins...) and obviously, because of the HDD is continously being accessed, the system performance is terrible! :cry: [I'm not saying Delkin CF is really slow. I'm just saying something is wrong and keep trying to access the HDD.]
I installed Windows XP Tablet edition (Clean install). And turned off the page file (or virtual memory) option, indexing service. I have 1.5GB RAM.
After killing a svchost.exe process (and its child processes), it stopped accessing the HDD. But, it started again as I started the Windows Update process (since I just did the clean install). [After killing the process, the performance was increadible 8) ... but I cannot say it for sure since no programs nor drivers has been set.]
Do you have any ideas what the process is and suggestions on how I should fix it? (Otherwise, I'll just have to try another clean install - which by the way takes few hours - to see what happens with the default option.)
PS. I believe someone questioned what will happen if he/she uses two CF cards to Addonics CF-to-IDE converter on X41 (and X41 Tablet) model. And someone answered it'll only detect the primary CF card. :idea: - Yes, it is true. I tried it, and the secondary CF card is NOT detected.
qviri
#222 Post by qviri » Sun Dec 23, 2007 2:13 am
svchost is an executable used by the operating system to run its "services" (mostly servers, drivers, system functionality, and the like). You can't tell what's causing the hard drive accesses just by seeing svchost.
One thing I would suspect off the top of my head is a Windows back-up process running to provide recovery service. If you installed XP off the IBM restore disks, you could also be seeing the Rescue and Recovery functionality (but I am not sure if that would run under svchost).
If you could follow the information and procedure in this Microsoft KB article and post the results of Tasklist /SVC and Tasklist /FI that involve the instances of svchost it may be easier to tell what's causing the disk accesses.
X220/IPS, T60p/IPS
Nothing endures but change
DVormann
Re: Q. Continuous Read/Write?
#223 Post by DVormann » Sun Dec 23, 2007 3:07 am
xosh wrote:I was worried about the "removable/fixed" problem - Even though it was shown as a "removable" device, after formatting the disk NTFS, I was able to boot from the CF card.)
That is interesting. In your current setup, does Windows declare the system drive removeable or fixed?
xosh wrote:And turned off the page file (or virtual memory) option, indexing service.
You could turn off the "write last acsess time" NTFS-feature as well. Disabling "most recently used" writes is a good idea, too. I am not saying either of that is your problem.
Write cache for the drive is switched on?
JStock
#224 Post by JStock » Mon Dec 24, 2007 12:05 am
xosh wrote:Hi, I am testing Delkin 16GB UDMA CF with Addonics CF-to-IDE converter on my Thinkpad X41 Tablet.
I'm happy that you're as far as you got! How did you do the clean Windows XP Tablet install? I am about to start with an install. I have the X41 Tablet Rescue and Recovery disks, but I don't have a working hard drive to pull any files off of. My drive died for the second time and being fed up with the spinning platters, I'm opting for the CF route.
Thanks much!
John
xosh
#225 Post by xosh » Tue Dec 25, 2007 2:48 am
qviri wrote:If you could follow the information and procedure in this Microsoft KB article and post the results of Tasklist /SVC and Tasklist /FI that involve the instances of svchost it may be easier to tell what's causing the disk accesses.
First of all, thank you for you comments. After some investigations, I realized that the problem was in "wuauclt.exe" which is a part of Windows Update. Since I had a clean install (Windows XP Tablet SP2), I had to update the windows. So, I only installed the ethernet / wireless driver and then performed a windows update.
I'm not sure whether this caused a problem or not, but I chose to run the "Microsoft Update" instead of "Windows Update". After the first update (which includes Windows Installer 3.1, and some malicious software removing tools, and genuine advantage something, etc.) and a reboot, this problem started.
I was able to stop the hard read/writing problem by turning off the "Automatic Update" from the service. However, because of that now I cannot get the windows updated. I don't know why these Microsoft update causes so much pain . :evil: Since I didn't any updates other than the first few, I'm thinking about manual update. I'll update it if I found a better way....
Did anyone have similar problem by performing a clean install? Or is it just happening to me? [I've re-installed Windows XP more than 100 times, but this was the first time I had problem with Windows Update... ]
xosh
#226 Post by xosh » Tue Dec 25, 2007 2:56 am
DVormann wrote: In your current setup, does Windows declare the system drive removeable or fixed?
I ran "diskpart" to check it.
Initially, I put the disk to a USB 2.5" HDD case with FAT32 format. At that time, the system recognized it as "removable device". However, after formatting the disk NTFS, (and installing it as the primary IDE disk of my X41t,) it is now recognized as "partition" - think it means "fixed device". [Please tell me it's wrong if I'm wrong.]
Then, I'm able to boot from the CF. However, I have to see "2010 Error" whenever I restart the machine. Does anyone know how to make the "2010 Error" go away from X41t? [I have the latest BIOS updates.]
And yes, thanks for your comments, I checked the "write cache" option. But it didn't help that much.
qviri
#227 Post by qviri » Tue Dec 25, 2007 3:07 am
xosh wrote:I was able to stop the hard read/writing problem by turning off the "Automatic Update" from the service. However, because of that now I cannot get the windows updated. I don't know why these Microsoft update causes so much pain . :evil: Since I didn't any updates other than the first few, I'm thinking about manual update. I'll update it if I found a better way....
Are you seeing network activity while the hard drive is busy, or alternatively, does the problem not occur when you're not connected to a network? I think one of the settings for automatic updates are to download the updates in the background and then notify the user when they are done. I cannot remember if this is the default setting, though. On a clean install you'd have a lot of updates to download (and store on the hard drive). I don't know if this is the cause, but I can see it being one.
Running Windows/Microsoft Update (*) manually is not a bad solution for now. Maybe try getting your computer up to date with all the updates (heh), then re-enabling the service and see if it still messes with your drive?
(*) Microsoft Update is essentially the same as Windows Update except it also provides updates for some other Microsoft software if you have it installed. Office and Visual Studio are two programs I've seen updated.
X220/IPS, T60p/IPS
DVormann
#228 Post by DVormann » Tue Dec 25, 2007 5:27 am
xosh wrote:Initially, I put the disk to a USB 2.5" HDD case with FAT32 format. At that time, the system recognized it as "removable device".
That's normal for USB devices. It has nothing to do with the CF card.
xosh wrote:However, after formatting the disk NTFS, (and installing it as the primary IDE disk of my X41t,) it is now recognized as "partition" - think it means "fixed device".
So the Delkin cards are fixed disk. Good to know.
xosh
#229 Post by xosh » Tue Dec 25, 2007 11:18 am
qviri wrote:Are you seeing network activity while the hard drive is busy, or alternatively, does the problem not occur when you're not connected to a network?
I don't think the problem is related to network since I cannot see any traffic during the HDD Read/Write. If it had some network traffic, I'd believe that it's downloading updates from the Windows Update server. But, since it was not... I'm not sure.
I mentioned Microsoft Update since I read an article from Microsoft forum. Someone was having a problem because wuauclt.exe was taking all the system memory resources (up to 40+MB!). People answered that it happened because of some "error" on the wuauclt.exe and can fix it by using "Windows Update" instead. Even though I cannot see any difference at my system, I think it's still worth mentioning it. :)
Well, it's Christmas... Merry Christmas to you all~
xosh
#230 Post by xosh » Tue Dec 25, 2007 11:22 am
DVormann wrote:So the Delkin cards are fixed disk. Good to know.
I'm not sure since I wasn't able to boot from the CF drive when I installed Windows with FAT32 format. Since I think I'm the first one to review Delkin devices, I'd like to be really careful (not to post something that can mislead you)... Anyway, it WORKS! :)
xosh
#231 Post by xosh » Tue Dec 25, 2007 11:30 am
JStock wrote: How did you do the clean Windows XP Tablet install? I am about to start with an install. I have the X41 Tablet Rescue and Recovery disks, but I don't have a working hard drive to pull any files off of.
I believe there are lots of articles on extracting files from your HDD (which has Windows XP Tablet installed) to create a Windows XP Tablet install CD for clean install.
In your case, I think you would have to install the rescue & recover to any HDD, and then create the XP Tablet CD from that HDD. (Hope you have other machine to work on... ) I'm not sure whether you can rescue & recover the system on non-thinkpad machines, but I hope it'll work out for you.
Otherwise, you might be able to download the CD images somewhere in the internet or ask your friend how have X41t to create the CD for you. (I think the first will be illigal, :roll: but that's another option.) This case you don't have to mess around with your rescue & recover.
Anyways, hope you solve your problem!
j-dawg
#232 Post by j-dawg » Tue Dec 25, 2007 1:58 pm
Actually, while the legality of downloading a copy of WinXP may be dubious, nobody will come after you if you've got a valid SKU, which should be on the bottom of your PC. If the SKU checks out, your copy of Windows should register with Microsoft as "genuine."
This is akin to the debate about downloading music albums you already bought in a store. If you've already bought the physical media, do you not have the rights to the digital forms as well? Supposing you have no viable means of getting that media on your computer..how is it sensible to punish a listener for downloading to his hard drive an album he already owns when he would not be punished for ripping it from a CD?
I won't claim to be a lawyer, and I doubt if my arguments would hold water in a court of law, but there are too many Windows pirates who never paid for a license in the first place whom nobody goes after, so it's not like you'd get nabbed for it. I'm just trying to make you feel better about software piracy.
X61 Tablet - 1.6GHz C2D, SXGA+, 1GB RAM, 100GB HD, Vista Business.
i have other laptops but i'll be honest i never use 'em
p5ycho
#233 Post by p5ycho » Wed Dec 26, 2007 5:38 am
xosh, i think it's important we get some data on the running flash card first. please check if the card is running in udma, and which mode. Also, check transfer speeds with a tool like hdtach. Make sure the blocksize is set to 1024K in hdtach. Also, make sure no other programs are running during the tests.
Once we establish which cards work well with our x4x series we can leave the experimental stage and make this a proven solution. This makes it easier for alle X4x users to determine if going solid state is worthwhile.
p5ycho
#234 Post by p5ycho » Wed Dec 26, 2007 5:39 am
oops, classic 'quote instead of edit' mistake.
X41 owner
xosh
#235 Post by xosh » Thu Dec 27, 2007 11:37 am
xosh wrote: After some investigations, I realized that the problem was in "wuauclt.exe" which is a part of Windows Update. Since I had a clean install (Windows XP Tablet SP2), I had to update the windows. So, I only installed the ethernet / wireless driver and then performed a windows update.
Instead of performing a manual Windows Update, I solved the problem by installing the Windows XP Service Pack 3 Release Candidate http://www.microsoft.com/downloads/deta ... laylang=en. Well it took more than an hour to install it, but after the installation, I was able to turn on the Windows Update Service back without the continuous HDD read/write problem.
So, know I'm running Thinkpad System Update to install the important driver and utilities. I'll post the benchmark result once everything is settled. :)
beeblebrox
**SENIOR** Member
**SENIOR** Member
#236 Post by beeblebrox » Thu Dec 27, 2007 1:38 pm
j-dawg wrote:Actually, while the legality of downloading a copy of WinXP may be dubious, nobody will come after you if you've got a valid SKU, which should be on the bottom of your PC. If the SKU checks out, your copy of Windows should register with Microsoft as "genuine."
Ripping a CD on a computer is an "unauthorized copy"!
Came on the news last week. This is an official statement from the general lawyer of SONY BMG in the latest RIAA case.
According to the RIAA you should buy another electronic copy.
These are official statements, when you google after it.
Personally as a customer I think this is complete bu&/$&/§hit!
xosh
#237 Post by xosh » Sat Dec 29, 2007 3:03 pm
Hi all, I finally am going to post my HD Tune result on 16GB Delkin UDMA CF card (with Addonics CF-to-IDE) on my X41 Tablet.
The result wasn't as expected, and I believe there's more things that I could still do to improve it (otherwise Delkin has been bragging about their product...).
First, the drive was detected as UDMA-4 (not 6).
HD Tune result:
1) Original Hitachi 60GB HDD
Transfer rate
Min : 4.0 MB/s
Max : 22.4 MB/s
Avg : 17.8 MB/s
Access Time : 22.8 ms
Burst Rate : 71.0 MB/s
CPU Usage : 2.9 %
2) 16GB Delkin UDMA CF
Transfer rate
Min : 1.5 MB/s
Max : 31.6 MB/s
Avg : 30.3 MB/s
Access Time : 0.4 ms
Burst Rate : 29.8 MB/s
CPU Usage : 2.5 %
I did all the first 5 steps that "Lewster215" (on Page 5) suggested. I tried step 6 (which forces UDMA-6), but I only got UDMA-4. However, as far as I know UDMA-4 supports up to 66 MB/s, and hence, it'll not be the bottle neck. (But, I would appreciate if other CF card users could post their UDMA settings.)
Anyway, Delkin says it has transfer rate up to 45 MB/s and "Tekkaman_Slade" posted (also on Page 5) much better transfer rates with 8GB Lexar 300x cards (almost 40 MB/s).
Please post me any suggestions to improve the card speed. I'm still trying to find out.... Thanks.
DVormann
#238 Post by DVormann » Sat Dec 29, 2007 3:34 pm
xosh wrote: First, the drive was detected as UDMA-4 (not 6).
If the card itself cannot exceed UDMA4 then it never will, no matter what you try.
Some UDMA CF-cards (Lexar, Kingston) are supposed to support UDMA5. Most stop at UDMA4. With current transfer rates UDMA4 is sufficient.
xosh wrote:Anyway, Delkin says it has transfer rate up to 45 MB/s ...
Up to...
xosh wrote:... and "Tekkaman_Slade" posted (also on Page 5) much better transfer rates with 8GB Lexar 300x cards (almost 40 MB/s).
That is not surprising. With current controller technology speed is limited by the density of flash cells. Double capacity in identical volume has to affect speed.
qviri
#239 Post by qviri » Sat Dec 29, 2007 4:11 pm
xosh wrote:Instead of performing a manual Windows Update, I solved the problem by installing the Windows XP Service Pack 3 Release Candidate http://www.microsoft.com/downloads/deta ... laylang=en. Well it took more than an hour to install it, but after the installation, I was able to turn on the Windows Update Service back without the continuous HDD read/write problem.
Glad that's worked out for you. Silly Windows Update.
X220/IPS, T60p/IPS
DVormann
#240 Post by DVormann » Mon Jan 14, 2008 11:50 am
Could lay my hands on a 32GB SanDisk SSD UATA 5000 1.8. Not useable with X40/X41. It does fit into the slot but the connectors are blocked. No point building your own cable.
I do have an adaptor to 2.5" SATA. Fits into any Laptop with appropriate bay. Here are some pieces of information using my desktop:
# hdparm -I /dev/sdc
/dev/sdc:
ATA device, with non-removable media
        Model Number:       SanDisk SSD UATA 5000 1.8
        Serial Number:      XXXXXXX
        Firmware Revision:  1.27
Standards:
        Used: ATA/ATAPI-7 T13 1532D revision 4a
        Supported: 7 6 5 4
Configuration:
        Logical         max     current
        cylinders       16383   16383
        heads           16      16
        sectors/track   63      63
        CHS current addressable sectors:   16514064
        LBA    user addressable sectors:   61734912
        LBA48  user addressable sectors:   61734912
        device size with M = 1024*1024:       30144 MBytes
        device size with M = 1000*1000:       31608 MBytes (31 GB)
Capabilities:
        LBA, IORDY(cannot be disabled)
        Standby timer values: spec'd by Standard, no device specific minimum
        R/W multiple sector transfer: Max = 1   Current = 1
        Advanced power management level: unknown setting (0x0000)
        Recommended acoustic management value: 254, current value: 254
        DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5
Commands/features:
        Enabled Supported:
           *    SMART feature set
                Security Mode feature set
                Power Management feature set
                Write cache
                Look-ahead
           *    Host Protected Area feature set
           *    WRITE_BUFFER command
           *    READ_BUFFER command
           *    NOP cmd
           *    DOWNLOAD_MICROCODE
           *    Advanced Power Management feature set
                Automatic Acoustic Management feature set
           *    48-bit Address feature set
           *    Mandatory FLUSH_CACHE
                SMART error logging
           *    SMART self-test
Security:
        Master password revision code = 65534
                supported
        not     enabled
        not     locked
        not     frozen
        not     expired: security count
                supported: enhanced erase
        10min for SECURITY ERASE UNIT.
HW reset results:
        CBLID- below Vih
        Device num = 0
Checksum: correct
# hdparm -tT /dev/sdc
/dev/sdc:
 Timing cached reads:   1018 MB in  2.00 seconds = 508.51 MB/sec
 Timing buffered disk reads:  184 MB in  3.01 seconds =  61.20 MB/sec
HDtach results following soon.
