why is my HDD continually accessed on idle?
ucsdmike
#1 Post by ucsdmike » Mon May 28, 2007 3:23 am
Does your T60 do this? It seems to access the harddisk on the average twice a second for a split second. My z60t didn't do this. I basically went through and stopped every service I can stop, then I killed every process except the ones required by the system. It still keeps doing it. I also went ahead and disabled the swap files.
I have a 2GB of RAM in my T60. The 100GB 7200RPM drive.
My theories are that the 2GB of ram makes windows want to do some kind of checking or offloading on the harddrive (seperate from the swap files). or that its part of the harddrive's design of how it operates, and is doing some low level hard drive driven defragmentation.
I'm sure it definitely has an impact on the battery life, and I'm beginning to realize that my z60t is virtually silent compared to the t60.
Jimco
Re: why is my HDD continually accessed on idle?
#2 Post by Jimco » Mon May 28, 2007 8:12 am
ucsdmike wrote:Does your T60 do this? It seems to access the harddisk on the average twice a second for a split second.
Does this make a clicking sound like a clock ticking? I had a Toshiba that did that a few years back and I was able to resolve it using a setting in Intel Application Accelerator. The setting changed a particular IDE channel to full power instead of power savings.
Jim Cheshire
JimcoSoftware.com
JimcoBooks.com
Laptops I've Owned:
ThinkPad (unknown model - work machine years ago)
Four different Toshiba models
Sony Vaio
T61
RonS
#3 Post by RonS » Mon May 28, 2007 11:08 am
Run this free utility and get the definitive answer on what your hard drive is doing:
http://www.microsoft.com/technet/sysint ... lemon.mspx
brentpresley
#4 Post by brentpresley » Mon May 28, 2007 11:18 am
XP or Vista?
If it is Vista, it is probably A) indexing the hard drive for a faster search and/or B) prefetching programs into memory so they load faster when you click on them.
A will subside over time as there are fewer and fewer files to index.
B will not.
Custom T60p
2.33GHz 4MB 667MHz Core 2 Duo
4GB PC2-5300 DDR SDRAM
Bluetooth / Atheros ABGN
200GB 7k200 7200RPM Hard Drive
8X DVD Multiburner
15" UXGA - ATI FireGL V5250 (256MB)
http://www.xcpus.com
