tomh009 and SkiBunny:
I understand the increased width, but how on earth is a widescreen version deeper than the 4:3 model? I would have expected a depth under 10 inches for that one, but it actually got bigger in every dimension.
If you look in the tabook, the 4-cell T61 14.1W is listed as 13.2" x 9.3" x 1.09-1.26, which presumably represents the actual depth of the chassis. Note that I gave the dimensions for the 6-cell version - the 4-cell battery life seemed way too short to bother including that version - and the extra 0.9" is the battery projection.
The post had already seemed a bit long, so I left out the line about the 14.1W design not being able to shrink the bits inside the chassis commensurate with the screen height, so that the 6-cell battery wasn't able to actually, you know, fit inside....
Thanks for the weight update, SkiBunny. Getting accurate weights for ThinkPads of the various configurations out of the Lenovo/IBM is a real chore, with their utterly vague "starting from"s and "up to"s. If somebody could pull together the true weights of the different versions, that would be a great service!
What's the definition of "travel weight" as given by Lenovo? Going back to the links, I now see that, for the 15.4W they gave a weight of 2.5 kg and a travel weight of 2.58 kg, or 5.5 and 5.7 lb. What's the difference?
