Success...finally. I had to install the 100 GB HDD in the machine and use a boot CD (and cloning software that would allow me to clone when booted from the CD) to clone from the original 60 GB HDD in an external case to the fresh internal drive.Tim M wrote:^^ Thanks.
I've tried redoing the clone with the Pre-Desktop Area and Security Chip disabled in the BIOS with a reformatted 100 GB drive, but no dice. In fact, Acronis gives me an error on reboot regarding changed partitions.
Right now I'm going to try to reformat the new drive again (all with it in the external case) including elimination of the recovery partition on it. Unfortunately, I have the trial version of Acronis and so cannot do the clone outside of Windows; thus I am required to keep the "new" 100 GB drive in the external USB case.
I will attempt the fdisk/ mbr trick if I get the blinking cursor again as that seems to be the problem I'm having.
EDIT: It seems from reading further (this information is spread out all over the place, which is a bit annoying) that I must have the target drive installed in my machine for the clone to work correctly--something to do with "unique" consideration of drive geometry by IBM. I'll have to find some way to boot off a CD with the target drive in the machine so that I may clone from my source drive in the enclosure. This is very frustrating.
Upon rebooting and running diagnostics, I found that I would receive a RUNDLL error when trying to "Safely Remove Hardware," which is apparently related to Acronis as discussed here.
I uninstalled the Acronis trial version and updated the Generic Volume drivers as discussed and everything is working now. Frankly, Acronis 11 seems to be more trouble than it's worth.
