danny_isr wrote:Did you compare weights on T61 wide screen Vs a T61 4:3 ?
Various people published detailed measures both here and on other forums. Not comparing them with T61 standard, but with T6x and T4x. Not that there should be much difference, but the point is that with its smaller screen area T61 14.1" WS should be smaller.
danny_isr wrote:well that is your own opinion that 4:3 is "comfort".
No. It is a fact that to me, for the things which I do, superior vertical resolution is better. Combined with portability and dimensions, that makes 4:3 superior and more comfortable in my case.
This does not mean that my situation and my comfort apply to you or anyone else, just like the fact that someone is judging whether a new computer would be too bulky for him based on the case he is comfortable with doesn’t mean you have to do it too. You might consider it, though. I know I took it into consideration when thinking about T61 and going to 15.4” WS.
danny_isr wrote:i didnt say 1440x900 is superior , i just said i see benefits in a wide screen as well. it's not black or white.
Riiight. You only said that you get more real estate with WS, that you can't understand the issue and suggested that some people don't like changes, insinuating it's their fault that they cannot see the light. Fair enough, I apologise for drawing conclusions.
danny_isr wrote:and at least for me , it doesnt make sense to buy a computer by the case size i own. you "usually" buy a case for the computer and not a computer for the case
That's perfectly fine, if you are not too picky about portability. Personally, I can't see myself even considering a 17" notebook, unless the manufacturers manage to reduce current weight and height in half, and even then I might find it too big. 15" or 15.4" is barely acceptable, although I’m tempted. Considering what is currently offered, I wish Sony was offering better resolution on their 13.3" SZ series...
