Go with Flexview? Update: Flexview Delivered Today!
chadwicktr
#31 Post by chadwicktr » Wed Jul 11, 2007 3:29 pm
hoya wrote:now that I've been using this FlexView for the past few hours it literally hurts my eyes to go back to my old LG 15.4" widescreen. everything seems so washed out that the text seems difficult to read. as Puppy said, the contrast on this FlexView is extraordinary.
I'm also finding that the Atheros 11b/g adapter works much better than the Atheros 11b/g/n adapter. it finds more networks, connects faster, and generally seems faster connecting to 11g access points.
Thanks so much for you input. If I didn't keep the flexview, I was going to reorder a T61 SXGA+ and get an LG or reorder again until I did. My only reference point is a Samsung, so if you like it better than the better LG I definately think I will stick with this thing even though it is a bit larger than I would like.
T61 LG WSXGA+, 140m, CD2 2.0, Stock 7200.1, 2GB, Thinkpad A/B/G, UWB, DVD-RW, ALPS
chadwicktr
#32 Post by chadwicktr » Wed Jul 11, 2007 3:49 pm
Wow, I just took some pictures with my Sony DSC T5 and compared with a few other LCDs. Good grief the Flexview colors are amazing! What a night and day difference.
hoya
#33 Post by hoya » Wed Jul 11, 2007 4:38 pm
I just returned from the Post Office and the results are in:
T60 15" Flexview w/ 120gb 5400.3 & optical: 5lbs 12.8 oz (5.8 lbs)
T60 15.4" WSXGA+ w/ 120gb 7200.2 & optical: 5lbs 13.9 oz (5.869)
chadwicktr: I've had a ton of 14" T4x's & T60's so this 15" also feels a bit big to me but the screen seems worth it. also, now that I've switched from a courier style bag to a Tumi backpack I barely notice the weight on trips.
#34 Post by dr_st » Fri Jul 13, 2007 5:08 am
I recently got a T60 with 14" SXGA+ and was able to compare it side by side with my T42 15" SXGA+ Flexview.
Brightness: The 14" DOES seem brighter when looked at straight on (i.e white is whiter). Only slightly, but noticeably. But if you look slightly from below, the 14" darkens fast. Look from above and it washes out.
Contrast: The Flexview wins hands down - the black is black. On the 14" it's dark gray if you're lucky, bright gray otherwise.
Colors: As with most TN panels, the 14" has a serious blue shift.
Viewing angles: Everybody already knows it, nothing to say here.
Sparkle/Graininess - The Flexview screen IS noticeably more grainy. But it's not anything that bothers you during normal work, and you only notice it if you compare the screens side by side. However, it's a fact that the effect is present. It might be better or worse, depending on the exact panel or model. I wa never troubled by it, and all the artifacts inherent to the TN panel (14") are a bigger drawback than the graininess of the Flexview.
hoya
#35 Post by hoya » Fri Jul 13, 2007 8:02 am
dr_st wrote: Sparkle/Graininess - The Flexview screen IS noticeably more grainy. But it's not anything that bothers you during normal work, and you only notice it if you compare the screens side by side. However, it's a fact that the effect is present. It might be better or worse, depending on the exact panel or model. I wa never troubled by it, and all the artifacts inherent to the TN panel (14") are a bigger drawback than the graininess of the Flexview.
The first LG FlexView I saw two years ago was so grainy/sparkeled that it was unusable. fortunately, the LG FlexView I received a few days ago has a slight amount of sparkle but it's very mild (about the same as my LG 15.4" WSXGA+ panel).
hoya
#36 Post by hoya » Fri Jul 20, 2007 2:55 pm
chadwickr: I finally got around to uploading some photos:
http://picasaweb.google.com/murphyja2/MacBookT60
unhooked
#37 Post by unhooked » Sat Jul 21, 2007 7:29 pm
Thank you for great pictures.
I've noticed that the FlexView sometimes would exhibit a pinkish tint under certain conditions, as can be observed in this picture.
I've noticed the same phenomenon on my T60 Flex also.
http://picasaweb.google.com/murphyja2/M ... 3437486946
