good bluetooth mouse.. compatible with t60p
bill bolton
#31 Post by bill bolton » Sun Jul 29, 2007 7:31 pm
furrycute wrote:I have a Microsoft Wireless Laser Mouse 6000. It looks pretty similar to the 8000. I am quite disappointed by its build quality. After less than 6 months of use, the paint on the sides have already started to MELT away.
I have a MS 6000 BT mouse which I've been using for 18+ months (with a T43) and there are no finish wear issues at all with it.
Bill B.
NathanA
#32 Post by NathanA » Mon Jul 30, 2007 1:36 am
I have a Logitech MX900 Bluetooth that pairs up with both my T42p and T60p internal Bluetooth just fine. Great mouse. However, I still find that I don't use it as much as I thought I might...the TrackPoint is just too convenient and too natural. ;)
-- Nathan
blueblood
#33 Post by blueblood » Tue Jul 31, 2007 6:22 pm
one of the cool things i dicovered is that i can control my pc through my cell phone.
it has a multi media mode, a presenter mode and a regular mode where the cursor moves and have some other common key functiosn avaialble as well.
its way cool
8744-J2U
T60P C2D 2.00 GHZ , 2GB RAM, 100GB 7200RPM HD, 15.4 SXGA+, 256MB ATI FireGL 5250 and the rest of the usual stuff
snife
#34 Post by snife » Wed Aug 01, 2007 5:01 am
After years of being Trackpoint only (external Ultranav keyboard), i've decided to try a mouse again and the one I want is the Logitech VX Nano (mainly due to the scrollwheel) :
http://www.logitech.com/index.cfm/mice_ ... 1&cl=us,en
This mouse is not bluetooth but the only real reason for using bluetooth (as it is much more flaky that 2.4GHz proprietory tech) is the fact that you dont need a reciever but check out the size of the reciever for this mouse - you will be able to keep it plugged in and it
wont bother you.
GarryF
#35 Post by GarryF » Wed Aug 01, 2007 5:05 am
Still uses up a USB port permantly which used to be very annoying on my T43P with only 2 ports.
T61P (6460-6XG) T7500-2.2G 100GB WUXGA 15.4"
retired T43P 2668F8G, A31P P4-1.8
snife
#36 Post by snife » Wed Aug 01, 2007 6:09 am
Totally agree, I can never have enough USB ports and I couldn't cope with only 1 free but 2 free would be OK as on the T60.
GarryF
#37 Post by GarryF » Wed Aug 01, 2007 6:25 am
Yeah, I could live with that too, it used to be a real pain having to unplug my mouse to use my 2.5" usb HD cause it demanded both ports for power etc.
arthurcorell
#38 Post by arthurcorell » Thu Aug 02, 2007 4:05 am
I used have a Targus bluetooth mouse. It's ok.
Then I bought a Logitech bluetooth mouse. It's much better.
Forgot the name, the M/N number is: M-RBB93
Also, both have the on-off switch.
I use those with my T60.
Tholek
#39 Post by Tholek » Thu Aug 02, 2007 4:54 am
arthurcorell wrote:I used have a Targus bluetooth mouse. It's ok.
I got that Targus BT mouse too. I haven't opened it yet though. Is it the reported lag, that bothered you too?
rmarshll
#40 Post by rmarshll » Fri Aug 03, 2007 10:48 am
I have a Logitech MX900 Which is Very nice and if you want something even smaller.. I also have a IOGear GME554 Bluetooth mouse which is very portable and works well.. I use the IOGear when I go on the road and the Logitech at home because its a bit more comfortable. Both Mice have a On/Off Switch
T60p T7200, 2GB RAM, 60GB 7200rpm HD, 14.1in 1400x1050 LCD, 256MB ATI Radeon FireGL V5250, CDRW/DVDRW/DL, Intel 802.11abg wireless, Bluetooth/Modem, 1Gb Ethernet, UltraNav, Secure chip, Fingerprint reader, 6c Li-Ion batt, Vista Business
