X61 carrying case?
loyukfai
#61 Post by loyukfai » Sun Apr 20, 2008 2:50 am
The X-series Tablet with 8-cell will ***NOT*** fit into a 12" ZeroShock ***sleeve***.
See below photo link for the result.
http://picasaweb.google.com/loyukfai/Ze ... 0059396594
snots
#62 Post by snots » Sun Apr 20, 2008 7:59 am
loyukfai wrote:The X-series Tablet with 8-cell will ***NOT*** fit into a 12" ZeroShock ***sleeve***.
Thanks for that photo; I will have to cancel my order for the 12" sleeve.
What about the 13" Zeroshock Sleeve or the 14". Shouldn't one of those fit nicely?
loyukfai
#63 Post by loyukfai » Sun Apr 20, 2008 9:27 am
I'm using a 14" ZeroShock III SLEEVE myself.
Think the 13" SLEEVE doesn't fit. Because if otherwise, I should have bought it instead when trying in the store. But I can't be 100% sure from (bad) memory.
Currently looking forward to try the Sumdex Impulse Computer Sleeve.
Trekk69
#64 Post by Trekk69 » Sun Apr 20, 2008 9:30 am
Try emailing or calling the manufacturer with the X61T w/ 8cell dimensions and seeing if it will fit the bag you want.
X61 Tablet 7767....loving every moment of it
Justintoxicated
#65 Post by Justintoxicated » Mon Apr 21, 2008 4:55 am
loyukfai wrote:I'm using a 14" ZeroShock III myself.
Think the 13" doesn't fit. Because if otherwise, I should have bought it instead when trying in the store. But I can't be 100% sure from (bad) memory.
12" Zeroshock CASE fits my x61s with a litle room to spare.
crashnburn
#66 Post by crashnburn » Thu Aug 07, 2008 12:47 pm
Any updates?
loyukfai
#67 Post by loyukfai » Thu Aug 07, 2008 1:09 pm
Update of...?
crashnburn
#68 Post by crashnburn » Fri Aug 08, 2008 9:03 am
Updates on whether someone was able to find the Genuine IBM Sleeves made by IdeaStyle
loyukfai
Re: X61 carrying case?
#69 Post by loyukfai » Sat Aug 15, 2009 5:19 am
Sorry for bringing up an old thread. Since I'm in the process of finding another sleeve for the X61T again. The 14" ZeroShock is too large, and leaves too much wiggle room inside. While the replica IBM bag leaves some to be desired in terms of protection provided.
So, besides SFBags's 23-21 sleeve, what are you using?
A few photos of the replica.
#1, #2, #3, #4.
loyukfai
#70 Post by loyukfai » Tue Aug 25, 2009 10:01 am
Just wonder, anybody tried the Case Logic Reversible Laptop Sleeve on a X61T with 8-cell?
http://www.caselogic.com/14_1_reversibl ... lid=113544
The 14.1" model is said to fit 11.75" x 9.25" x 1.25" which is about an inch short on the width, but will there be enough flex...?
P.S. The X61T with 8-cell is about 10.5" both in length and width.
crashnburn
#71 Post by crashnburn » Thu Sep 17, 2009 1:31 am
loyukfai wrote:Just wonder, anybody tried the Case Logic Reversible Laptop Sleeve on a X61T with 8-cell?
Nice sleeve. I just got IBM Replica from Ebay (Chinese origins). Do let us know how this one worked out?
