Thanks EOMtp. It did sound a bit strange. One more question, would one need to worry about these drivers and BIOS settings if I 'cloned' the old hard drive to this new drive with a program like Acronis True Image or Casper, etc.?
Mark
Just installed my 7K200 7200 RPM 200GB Hitachi HD is FAST!!!
In order for the cloned SATA drive to boot -- assuming that the Master Boot Record (MBR) is "correct" (that's a different discussion and easy to fix if it is not "correct") -- one has to set the BIOS SATA setting to "Compatibility Mode" for at least one Windows XP startup. Once XP has started, one can provide XP the SATA drivers and thereafter the BIOS setting will not matter in the context of this discussion.Altadena_Mark wrote:...would one need to worry about these drivers and BIOS settings if I 'cloned' the old hard drive...
However, there is little reason, if any, not to run always with the BIOS SATA setting in "Compatibility Mode". I yet have to see any demonstrable advantage in doing otherwise given the current crop of notebook SATA drives, notwithstanding the "on paper" benefits that are supposed to accompany SATA native mode. Therefore, if one leaves the BIOS SATA setting on "Compatibility Mode", then one does not have to think about SATA drivers at all.
Brand New Oem X230 Battery Losing Full Charge Capacity Fast!
by TheMagicT410 » Sat Feb 11, 2017 12:58 pm » in ThinkPad X230 and later Series - 5 Replies
- 830 Views
Last post by TheMagicT410
Sat Feb 25, 2017 3:04 pm
SOLD!: X601 tablet SXGA+ bundle, must go FAST and priced accordingly
by ajkula66 » Mon Feb 20, 2017 3:56 pm » in Marketplace - Forum Members only - 1 Replies
- 373 Views
Last post by ajkula66
Tue Feb 21, 2017 10:15 pm
Modded Bios and Processor Fast Strings.
by Digitalhorizons » Tue Feb 28, 2017 8:46 am » in ThinkPad X200/201/220 and X300/301 Series - 7 Replies
- 1179 Views
Last post by Digitalhorizons
Fri Mar 03, 2017 6:36 pm
Can Windows Vista be installed on an IBM Thinkpad R50e?
by ThinkDan2004 » Sat Jun 03, 2017 3:54 pm » in ThinkPad R, A, G and Z Series - 14 Replies
- 578 Views
Last post by ThinkDan2004
Tue Jun 13, 2017 3:06 pm
Users browsing this forum: peshinga and 2 guests
